POV-Ray : Newsgroups : povray.general : Fogs Server Time
23 Apr 2026 15:04:06 EDT (-0400)
  Fogs (Message 1 to 8 of 8)
Subject: Fogs
Date: 15 Jan 2002 20:13:00
Message: <3c44d39c$1@news.povray.org>
Hmm... how come when I put two grey colored fogs in my scene, near the
horizon i get a pure white color? It seems to be adding the fog colors
together... I expected something more like an *average* of the grey colors.
Here's the fog I'm using...
fog {
 distance 40
 rgb <.7,.7,.9>
 fog_type 2
 fog_offset 3.5
 fog_alt 1.5
 turbulence .6
 octaves 8
 omega .6
 lambda 3
 turb_depth .6
fog {
 distance 40
 rgb <.9,.9,1>*.3
 fog_type 2
 fog_offset 60
 fog_alt 10
How can I keep it from getting white near the horizon?
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Subject: Re: Fogs
Date: 15 Jan 2002 20:34:58
Message: <3c44d8c2$1@news.povray.org>
Hmm, setting the second fog to black (rgb 0) and giving it a distance of
1e-10 still keeps the first fog visible. Is this really the intended
behavior?
- Slime
Subject: Re: Fogs
Date: 15 Jan 2002 23:21:19
Message: <chrishuff-C59E3A.23222015012002@netplex.aussie.org>
In article <3c44d8c2$1@news.povray.org>, "Slime" <noo### [at] hotmailcom>
> behavior?
If you want accurate results, use media instead of fog. Fog is really a
quick-n-dirty cheat, it only works for certain situations, though it's a
lot faster.
Subject: Re: Fogs
Date: 15 Jan 2002 23:39:40
Message: <3c45040c$1@news.povray.org>
> lot faster.
Yup, yup... I've resorted to media... although I'm having a tough time
getting the emission and absorption to work well together (as usual). Should
they be emitting and absorbing the same color, or opposite colors, or what?
It seems that if there's any absorption at all, then things turn black on
the horizon...
(note: I don't care about light interaction.)
- Slime
Subject: Re: Fogs
Date: 16 Jan 2002 06:17:31
Message: <g2oa4ucn0825ig4lkor50v5vhra6reoc04@4ax.com>
On Tue, 15 Jan 2002 23:37:28 -0500, "Slime" <noo### [at] hotmailcom>
Depends on the effect you're trying to achieve. In general, I wouldn't
use emission in this case because that's physically incorrect. Your
best bet is a thin scattering media or semi-transparent fog.
Peter Popov ICQ : 15002700
Subject: Re: Fogs
Date: 16 Jan 2002 11:21:07
Message: <3c45a873$1@news.povray.org>
Well, I was using emission to simulate scattered light without using
scattering, since scattering would require many, many samples (especially in
this scene) to keep from being grainy. Since I don't care about the
direction of the light or shadows, I figured emission would suffice.
It seems, however, that even if I have emission 100 and absorption .00001,
as the distance from the camera approaches infinity, the fog color becomes
black (absorption wins over emission). Could someone explain to me why this
is the case? I assume it's physically correct (even though it doesn't happen
with a simple fog declaration), but I'd still like to know why it happens.
If real fog consists only of absorption, then how come it doesn't become
black on the horizon? Or does it? (I live in a wooded area, so I can't tell
- Slime
Subject: Re: Fogs
Date: 16 Jan 2002 11:26:23
Message: <3c45a9af$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3c45a873$1@news.povray.org...
Off-hand, I'd say the answer is because it doesn't consist only of absorption,
if any. Scattering via reflection and difraction is a (RL) fogs main attribute.
Subject: Re: Fogs
Date: 16 Jan 2002 15:47:40
Message: <3c45e6ec@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c45a9af$1@news.povray.org...
tell
absorption,
attribute.
Yes, at some distance and thickness of fog you never see through it and only
see the fog itself at some point.  If in RL it only absorbed light it would
go black I guess, if only emitted it would go white.
Anyway, have you tried fade_distance for the light_source?  Together with
media_attenuation in that light to fade out the media might work, and try
leaving out the absorption part.
bob h
