POV-Ray : Newsgroups : povray.general : Background bitmap? Server Time
25 May 2026 03:45:54 EDT (-0400)
  Background bitmap? (Message 1 to 9 of 9)
Subject: Background bitmap?
Date: 4 Dec 2001 18:38:41
Message: <3c0d5e81@news.povray.org>
Hi everyone,
Is it possible to use a background bitmap in POV? I can only find
documentation for background colour etc
Thanx....
Subject: Re: Background bitmap?
Date: 4 Dec 2001 20:19:27
Message: <3C0D7581.9F110BA3@global2000.net>
I would use an image map on a polygon with the once keyword.  If the
bitmap tiles, putting it on a plane without the once keyword can work.
Use type 0 for planar image mapping.  If you tile the bitmap on a plane
the once keyword is not needed.
Brendan
polygon
   pigment
      image_map
         png "yourfile.png"	//there's also tga and others (sys for
system specific format such as bmp for windows)
         type 0			//the default, so it doesn't need to be typed
         once			//makes one copy of bitmap cover the whole polygon
Brendan
ReeF wrote:
> Hi everyone,
> Thanx....
Date: 4 Dec 2001 20:23:27
Message: <3C0D7671.4C0C620D@global2000.net>
> Brendan
Oh, sorry for repeating myself with the once keyword.  I referred to it
concerning planes twice instead of *once*! :)
I was thinking about what a bitmap would look like all stretched out on
a plane.
Brendan
Date: 5 Dec 2001 01:26:20
Message: <3c0dbe0c@news.povray.org>
Thanx Andrea, I'll try that
Date: 5 Dec 2001 12:30:54
Message: <3C0E59CD.FAEA4D5F@spiritone.com>
I have a method for doing this at:
http://www.spiritone.com/~english/cyclopedia/background.html
Josh English
eng### [at] spritonecom
ReeF wrote:
> Hi everyone,
> Thanx....
Date: 5 Dec 2001 15:01:21
Message: <MPG.16788db87ed63886989a6b@news.povray.org>
On Wed, 5 Dec 2001 16:30:06 +1000, ReeF wrote...
Umm, That was Brendan (I assume from the last word in his post)
Bye for now,
     Jamie.
Date: 7 Dec 2001 08:10:49
Message: <3c10bfd9$1@news.povray.org>
hi josh,
your tutorial is excellent.  but can you tell me what the
<span class="code"> stuff is?  i assume its an html tag
that somehow didn't get interpretted correctly by my IE6,
but i'm not familiar with it.
thanks, miker
"Josh English" <eng### [at] spiritonecom> wrote in message
news:3C0E59CD.FAEA4D5F@spiritone.com...
> Josh English
> ReeF wrote:
> > Hi everyone,
> > Thanx....
Date: 7 Dec 2001 15:05:50
Message: <8p$I1CAmASE8EwMh@econym.demon.co.uk>
Wasn't it MR who wrote:
>hi josh,
IE6 would interpret it correctly if he had typed it right.
It should be <span class="code">, but it actually says <span
class="code">, which gets displayed as <span class="code"> on the
browser rather than being interpreted as invoking the span.code style
from the cascading style sheet.
The same sort of thing happens with some of the links.
As a wild guess, I think he might have copied and pasted some of the
tags between two different editors, only one of which was HTML-aware.
Mike Williams
Gentleman of Leisure
Date: 7 Dec 2001 23:22:05
Message: <Xns9170EDB4FDF46CoridonHenshaw@204.213.191.226>
"ReeF" <ree### [at] netscapenet> wrote in news:3c0d5e81@news.povray.org:
It is possible to do this in camera in Pov with a minimum of hassle only in
situations where you can determine the exact extents of the camera
viewport.  In situations where you can do this, just put an image_mapped
plane or polygon behind the other objects in your scene.
If you can't easily determine the extents of the viewport (e.g. because the
camera isn't axially aligned, has a non-standard angle or isn't perspective
or othographic), by far the best option is to render to with alpha and
composite the background after rendering.
It is possible to composite images in Pov if you can't use or don't have a
suitable image editor.
