POV-Ray : Newsgroups : povray.general : Memory question - splines Server Time
25 May 2026 03:45:54 EDT (-0400)
  Memory question - splines (Message 1 to 10 of 11)
Subject: Memory question - splines
Date: 1 Dec 2001 09:34:45
Message: <3c08ea85@news.povray.org>
How much memory would it approximately require to declare and use 4000
splines each with 2000 control points?
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Subject: Re: Memory question - splines
Date: 1 Dec 2001 15:30:45
Message: <3c093df5$1@news.povray.org>
Too much?
I wonder how much time would it require to declare them by hand...
BTW, you can test it yourself with a simple loop: if your computer start
screaming then you'll probably need more memory.
Jonathan.
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
news:3c08ea85@news.povray.org...
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 1 Dec 2001 15:33:17
Message: <3c093e8d@news.povray.org>
Are you still using beta 7?
Rune wrote on '30th Novemeber 2001':
> Rune
Date: 1 Dec 2001 16:53:18
Message: <3c09514e@news.povray.org>
I wondered if anyone would figure it out... ;)
Rune
Date: 1 Dec 2001 16:53:21
Message: <3c095151@news.povray.org>
"JRG" wrote:
> Too much?
Correct answer!
I little test and a few calculations seem to predict that it would require
about 700 MB memory. The computer I'm working at most of the time has 16
MB...
Some people have suggested to me to redesign my particle system to *first*
calculate all the data for the particles for the entire animation, and then
render all the frames *afterwards*, based on that data. Seems like it's not
such a good idea...
Of course there might be some ideas I haven't considered, but I doubt that
the data amount can get down low enough for it to actually work.
Rune
Date: 1 Dec 2001 19:56:03
Message: <3c097c23$1@news.povray.org>
What if you did this:
write the positions of particles to multiple files, each file containing the
data for, say, 100 frames. Then, when rendering, figure out which part of
which file to read for the current frame, and use the data from there.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 1 Dec 2001 21:33:24
Message: <3c0992f4@news.povray.org>
> each file containing the data for, say, 100 frames.
> Then, when rendering, figure out which part of which
> from there.
I suppose that could be done. But still the disc space required would be
many hundred MB, which is perhaps not a problem for some, but it is on my
computer...
Rune
Date: 1 Dec 2001 23:39:12
Message: <3c09b070@news.povray.org>
Rune wrote in message <3c095151@news.povray.org>...
>"JRG" wrote:
>> Too much?
>Correct answer!
>MB...
I've looked at the spline code, and by: eliminating pre-calculation of
spline coefficients, limiting splines to 3-D vectors, and changing the
spline code from double-precision floats to single-precision floats, the
memory needed could be reduced to 128 MB.
On a more practical note, since you're using spline interpolation, you
probably don't need to put every point calculated into the spline -- you can
probably get away with only putting in every fourth point or so.
Mark
Date: 2 Dec 2001 07:45:53
Message: <3c0a2281@news.povray.org>
> interpolation, you probably don't need to put every
> point calculated into the spline -- you can probably
That method alone would bring it down at 175 MB or maybe even below 100 MB,
but that's still way too much for my computer with 16 MB RAM...
Combining it with Slime's suggestion could maybe get it down at 5 MB. Well,
I'll have to consider it some more...
Rune
Date: 2 Dec 2001 21:01:22
Message: <3C0ADC83.461DFC5F@gmx.de>
Well, just an idea I had:
What if you just collect the points where the particles rebounce, and save
the time it would
take to hit the next rebounce-position?
If you know the rebounce position, you can calculate the surface-normal
there, and based on
the particles initial settings of speed and direction, you can recalculate
the new direction and speed
as well.
Hm, but then, you'd have a lot of calculation to do near the end of an
animation...
How about saving direction, speed, rebounce-position and time until next
rebounce? You can
calculate the path pretty easily from there on, I guess.
Hope you get the idea...
Tim
