POV-Ray : Newsgroups : povray.general : Camera Question Server Time
30 Dec 2025 18:14:00 EST (-0500)
  Camera Question (Message 1 to 7 of 7)
Subject: Camera Question
Date: 10 Oct 2001 16:09:55
Message: <3bc4ab13@news.povray.org>
Heah all, I know I've read this somewhere before..
And I know I've fixed it.. but I can't seem to figure out this warning.
I mean, I understand it, but I'm not sure how to fix it:
Warning:  Camera is inside a non-hollow object.  Fog and participating media may not
work as expected.
Now I have my Camera at:
<0, 2, -10>
and only have two objects.. a plane that is -y*6, 1 and a sphere at the origin that
has a diameter of 3.
I'm not sure why I'm getting the message.. Any help would be great
Thanks
D
Subject: Re: Camera Question
Date: 10 Oct 2001 16:14:25
Message: <slrn9s9b12.9vb.ron.parker@fwi.com>
work as expected.
><0, 2, -10>
Why would you use a normal of -y*6?
In any event: the inside of the plane is the side away from the normal,
which in this case is every coordinate with y greater than -6.  That
includes your camera.  The easiest fix is to add the keyword "inverse" to
the plane.  The best fix is to change it to plane {y,-6} which will give
the same visual results but invert the insideness of the plane.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 10 Oct 2001 16:15:43
Message: <3bc4ac6f@news.povray.org>
Your plane's normal is pointing downwards, which makes your camera inside
the *interior* of the plane.
I would suggest you to use normalized normal, so that it's easy to know
where your plane really is.
I mean, simply use: plane {y, height_you_want_your_plane_to_be}
Jonathan
<dav### [at] intrepidvoygrcom> ha scritto nel messaggio
news:3bc4ab13@news.povray.org...
media may not work as expected.
> <0, 2, -10>
origin that
> Thanks
> D
Date: 10 Oct 2001 16:28:23
Message: <3bc4af67$1@news.povray.org>
If for some reason you *want* your plane to have the normal facing down (for
instance, if you want it to have something in the interior like an IOR or
media), specify "hollow" and media will work fine inside of it.
plane {-y,6 hollow}
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
<dav### [at] intrepidvoygrcom> wrote in message news:3bc4ab13@news.povray.org...
> <0, 2, -10>
origin that
> Thanks
> D
Date: 10 Oct 2001 16:28:33
Message: <3bc4af70@news.povray.org>
Thanks to all.. look for another message upcoming.. ;)
Dave
> Jonathan
>> <0, 2, -10>
> origin that
>> Thanks
>> D
Date: 10 Oct 2001 16:30:47
Message: <3bc4aff6@news.povray.org>
I realized I was thinking of PLANE wrong... I don't use it much, so I was just
mistaken
of syntax.. :)
Thanks
D
> Jonathan
>> <0, 2, -10>
> origin that
>> Thanks
>> D
Date: 10 Oct 2001 19:02:02
Message: <3bc4d36a@news.povray.org>
You have set the normal of your plane to point downwards rather than
upwards.
The plane should be y, -6
Hope that helps,
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
