POV-Ray : Newsgroups : povray.general : Slow CSG Server Time
10 Sep 2025 00:32:02 EDT (-0400)
  Slow CSG (Message 1 to 6 of 6)
Subject: Slow CSG
Date: 13 Sep 2001 11:46:20
Message: <3ba0d4cc$1@news.povray.org>
I created a shape by using the difference between a torus
and a union of many cylinders. This renders very slowly.
If I render the union of cylinders as the object it is much,
much faster. I am using bound_by.
Are there any other optimisations I can use for the difference?
Thanks.
Arnold the Aardvark
Subject: Re: Slow CSG
Date: 13 Sep 2001 14:21:06
Message: <3ba0f912@news.povray.org>
Turn off the "eliminate maunal bounding" option (-ur). POV always thinks it
can bound better than you can, but it is frequently wrong when trying to
bound a difference.
turn on the display of bounding boxes (+ud) and see if huge areas of the
screen are in the bounding box of a small object
"Arnold the Aardvark" <aar### [at] NOTTHIStubulidentatademoncouk> wrote in
message news:3ba0d4cc$1@news.povray.org...
> Thanks.
> Arnold the Aardvark
Date: 13 Sep 2001 16:28:23
Message: <Uj4+1HAGZRo7Ewlc@econym.demon.co.uk>
What happens is that when you do the union, POV can put a tight bounding
box around each cylinder, so for each ray it only has to perform
cylinder tests for the few cylinders that that particular ray comes
close to.
When you do a difference, POV can't use the bounding boxes in the same
way. For each ray it ends up performing cylinder tests for every single
cylinder. You can see the effects of this if you look at the stats in
the message window. You'll find that there are a *huge* number of
cylinder tests, of which only a very small percentage were successful.
Whereas the union has about the same number of successful tests but a
much lower number of unsuccessful ones.
I did a scene a while ago with hundreds of small cylindrical holes in a
flat slab (rather than a torus) and experimented with cutting the slab
into smaller pieces with just a few holes in each piece. It turned out
that the rendering was fastest when each piece was so small that it
contained only one hole.
The following one large slab took 62 times as long to render as 400
pieces with one hole in each.
#declare N = 20;
// One large slab with N*N holes
#declare Slab1 = difference
 box {<-0.5,-0.5,-0.5>,<N-0.5,N-0.5,0.5>}
 #declare xx = 0;
 #while (xx < N)
   #declare yy = 0;
   #while (yy < N)
        cylinder {<xx,yy,-1>,<xx,yy,1>,0.3}
     #declare yy = yy+1;
   #declare xx=xx+1;
// Declare a small box with one hole
#declare Box = difference
 box {<-0.5,-0.5,-0.5>,<0.5,0.5,0.5>}
 cylinder {<0,0,-1>,<0,0,1>,0.3}
// Glue together N*N boxes into one slab
// so it looks like one slab with N*N holes
#declare Slab = union {
#declare xx=0;
#while (xx < N)
  #declare yy = 0;
  #while (yy < N)
    object {Box translate <xx,yy,0>}
    #declare yy = yy + 1;
  #declare xx=xx+1;
The one-large-slab version made over 70 million cylinder tests of which
0.4% were successful. The 400-small-pieces version made 27 thousand
cylinder tests of which 31% were successful.
The resulting images are identical.
Mike Williams
Gentleman of Leisure
Date: 14 Sep 2001 09:21:58
Message: <3ba20476@news.povray.org>
Mike Williams wrote in message ...
bounding
>close to.
same
single
successful.
a
slab
out
Very informative; thank you! Throws a lot of light on some 'weird'
super-slow renders I've had .
Anoop
Date: 14 Sep 2001 11:08:39
Message: <3ba21d77@news.povray.org>
This should go in the docs, ot the VFAQ at least...
 -- Nikodemus
Date: 16 Sep 2001 15:58:38
Message: <nsp9qts1h8soc3tj90r9romribfukrnp1u@4ax.com>
On Thu, 13 Sep 2001 16:48:53 +0100, "Arnold the Aardvark"
Instead of intersecting the torus with the union of cylinders, make a
union of the intersection of each cylinder with the torus. POV will
then take much more advantage of autobounding and vista buffering than
it does with your current implementation.
The memory consumed with what I proposed is greater, but with "many"
being relatively sane, this shouldn't be a problem.
Hope this helps.
Peter Popov ICQ : 15002700
