POV-Ray : Newsgroups : povray.general : Arrays Server Time
25 May 2026 20:10:21 EDT (-0400)
  Arrays (Message 1 to 5 of 5)
Subject: Arrays
Date: 24 Jul 2001 18:22:03
Message: <3b5df50b$1@news.povray.org>
I think I may have just noticed my problem with arrays. I am sure I read
it once but I just noticed that the POV-Ray docs claim that arrays can only
be as large as array[5][x]. Is this true?!
    IOW, if I have a list of planetary data for 9 planets, listing their
name, radius, mass and distance from sun, I have to rearrange it into a list
of names, a list of masses, a list of radii and a list of distances? (I am
doing this anyway to see if it solves my problems, but I am mad that for all
this time I thought that I was just not understanding array initialization
and reading)
    Please tell me I am misreading things and that povray can take an
array[9][4]. Or, and this is the real question, that megapov can take arrays
of useful sizes.
    And -why- would someone bother to make an array function but only make
it good for [5][x]?
Subject: Re: Arrays
Date: 24 Jul 2001 18:28:17
Message: <slrn9lrtk3.p12.ron.parker@fwi.com>
I think you're misreading it.  The limitation involving the number 5 is
that arrays can have no more than 5 dimensions, so array[9][4] is okay,
but array[2][2][2][2][2][2] is not.
>and reading)
Note that once you fill in one value in an array, every other value in the
array must be of the same type.  Name and mass might not be the same type.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Subject: Re: Arrays
Date: 24 Jul 2001 18:41:08
Message: <3b5df984$1@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
read
only
    See, that's what I thought the first time I read it (from what I thought
the word "dimension" meant), but their examples led me to think otherwise.
    "Declaring Arrays...
     Multi-dimensional arrays
     up to five dimensions may
     be declared. For example:
     #declare MyGrid = array[4][5]"
    Your explanation makes more sense... I was just boggled that the pov
team thought that 5 items were all you needed...
list
am
all
initialization
> >and reading)
    Yeah, I was already planning to separate them into two arrays for my
purposes. Thanks for the quick reply. I am trying to finish off my gravity
well isosurface in the short times between dinner and work...
Subject: Re: Arrays
Date: 24 Jul 2001 19:53:24
Message: <3B5E42F2.58F59EC8@chesapeake.net>
On other projects I have "coded" the information so that the data stored
was all numeric but I made a decoding routine for displaying the
information.
Maybe you could do something like that with your project.
> read
> only
> list
> am
> all
> initialization
> > >and reading)
Subject: Re: Arrays
Date: 25 Jul 2001 09:59:22
Message: <3b5ed0ba$1@news.povray.org>
"Mr. Art" <mra### [at] chesapeakenet> wrote in message
news:3B5E42F2.58F59EC8@chesapeake.net...
> information.
    Right, make it all text or something and then re-interpret it when you
need it. Good Idea.
