POV-Ray : Newsgroups : povray.general : dxf files Server Time
10 Sep 2025 14:50:23 EDT (-0400)
  dxf files (Message 1 to 3 of 3)
Subject: dxf files
Date: 10 Jun 2001 07:39:05
Message: <3b235c59$1@news.povray.org>
So I am now using Blender to do som e modeling. I really like it, the
interface is a bit wierd but it does a fine job. Anyway, is there a way to
convert a .dxf file to a smooth_triangle mesh? I use 3dwin4 but I still see
the faces of my round objects. Any ideas?
-paul
Subject: Re: dxf files
Date: 10 Jun 2001 09:18:05
Message: <3B237447.73F0785E@inapg.inra.fr>
You can smooth it directly in 3DWin (see the "modify object" button). If this
doesn't work for some reason, it's also possible to do it in Crossroads, or
even after the conversion using Warp's mesh smoothing utility.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 10 Jun 2001 10:31:05
Message: <3B23842E.49800BDD@pacbell.net>
Failing all that you can always use a greater number of triangles inside
blender itself OR subdivde the resulting mesh from any of the above methods
using the SSS macros from -
http://users4.50megs.com/enphilistor/sss.htm
