POV-Ray : Newsgroups : povray.general : Tubular shape Server Time
25 May 2026 22:36:49 EDT (-0400)
  Tubular shape (Message 1 to 9 of 9)
Subject: Tubular shape
Date: 6 Jun 2001 17:43:07
Message: <3b1ea3eb$1@news.povray.org>
Can anyone tell me how I would make a bending tube? I am looking into making
a power cord for a pov'ed soldering iron.
Thanks!
Subject: Re: Tubular shape
Date: 6 Jun 2001 18:35:52
Message: <slrn9htc2b.5a1.ron.parker@fwi.com>
http://www2.fwi.com/~parkerr/traces.html
Look for the torus spline include file at the bottom of the page.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 6 Jun 2001 20:51:01
Message: <3b1ecff5$1@news.povray.org>
thanks..works like a charm!!!
"parasonic" <par### [at] homecom> wrote in message
news:3b1ea3eb$1@news.povray.org...
making
> Thanks!
Date: 7 Jun 2001 06:27:23
Message: <3b1f570b@news.povray.org>
parasonic <par### [at] homecom> wrote:
: thanks..works like a charm!!!
: "parasonic" <par### [at] homecom> wrote in message
: news:3b1ea3eb$1@news.povray.org...
:> Can anyone tell me how I would make a bending tube? I am looking into
: making
:> a power cord for a pov'ed soldering iron.
:> Thanks!
  Sorry about preaching once more about correct news writing, but
some recapitulation might not be bad. And this special article has
several mistakes.
  I'll tell you the mistakes in the form of questions:
  1. If you were responding to Ron's article, why did you follow up to your
own original question instead of his answer? People will not know who
are you talking to if you are responding to your own article but talking
to someone else (specially if it's a longer thread).
  2. Why did you quote the (=your) original article although you are not
in any way responding to it? When you quote something it's because you
are writing response to that specific quote.
  3. Why did you write your text at the beginning of the article and left
a useless quote at the end? You are not responding to the quote and you are
not using it in any way for your text. Why are you wasting server space
and bandwidth for a completely useless quote?
  (Of course the question in this particular case is not about physical
server disk space and physical bandwidth as the whole article is so short,
but people make the same mistake also with a lot larger articles and
besides the useless quote adds visual noise.)
  Why is it so common anyways that people write their answers at the
beginning of the article and quote the whole original article untouched
at the end? Don't they know how to delete a block of text?
  There are other mistakes people often do (although not in this case,
but I'll just list them as a reminder):
  - Answer first to a specific question and quote whole original article
after that. This makes no sense; people can't know what is the article
answering specially if the quote is long.
  - Too long quotes. It seems that some people don't know how to delete
bigger blocks of text (or for some reason are unwilling to delete anything
from the quote). Even when the answer is properly written after the quote
it's responding to, the writer still makes this mistake and leaves
unnecesarily huge blocks of quoted original text although he is answering
to just a few lines of it.
  - Not quoting anything although answering to a specific question. Although
this is not as bad as the previous ones, it's still better to quote at least
the original question and write the answer after the quote. This way people
will know what you are answering to.
  The only case where no quotes are needed is when the original article is
very long (more than 10 lines or so) and you are responding to the whole
article, to the general idea in it and not to a specific question inside it.
In fact, in these cases the quote _should_ be left out if it's just too long
(else it will be the previous mistake, ie. too long quotes). Another
possibility is to just quote few lines from the beginning and add a line
like "[SNIP]" or similar where the quote was cut out.
Date: 7 Jun 2001 08:23:43
Message: <3b1f724f$1@news.povray.org>
    I usually don't bother to lecture about this but I agree with almost
every thing you say. I don't care about a few diversions from standard
practice, but when someone is clearly habitually making the reading of their
post difficult, they should be told.
    One thing that your ideas don't take into account though, is that on
most news groups, propagation can be a problem. Sometimes you may want to
include the entire post at the bottom so that others can see the context of
the few snips you used in your reply to show the thread of conversation.
Date: 7 Jun 2001 13:27:44
Message: <3b1fb990$1@news.povray.org>
I know! I already caught my mistake, but that was right after I sent it, and
I couldn't move my posting obviously.
news:3b1f570b@news.povray.org...
> : making
> :> Thanks!
> several mistakes.
your
are
Although
least
people
it.
long
Date: 7 Jun 2001 13:33:46
Message: <3b1fbafa@news.povray.org>
parasonic <par### [at] homecom> wrote in message
news:3b1fb990$1@news.povray.org...
and
You can cancel and repost. Looks like you're using Outlook Express.
Click on the message menu and choose 'Cancel message', then repost
in the correct place
<really big snip>
Did you see Warp's comment about quoting unnecessary text?
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
Date: 8 Jun 2001 04:14:45
Message: <3b208974@news.povray.org>
: I know!
  But you still didn't read my text about useless quotes.
Date: 8 Jun 2001 18:01:29
Message: <3B2149A7.BE755265@faricy.net>
If ya really want you could go get MegaPOV
http://nathan.kopp.com/patched.htm and use a sphere_sweep.  Basically
you give it points and it connects them with smooth circular tubes.
