POV-Ray : Newsgroups : povray.general : POVRay Dreamcast port Server Time
17 Jul 2026 10:15:11 EDT (-0400)
  POVRay Dreamcast port (Message 1 to 10 of 14)
Subject: POVRay Dreamcast port
Date: 7 Apr 2001 13:43:44
Message: <3acf51d0@news.povray.org>
Straight from the news item on povray.co.uk
'I was amazed! Those povray guys write really portable code. Unfortunately,
its not very fast :(. The Dreamcast uses an SH4 processor. The NetBSD dc
port is using an SH3 compiler. The SH4 is backwards compatible w/ the SH3,
so it works, but I would imagine the SH4 can do a lot more than the SH3. I
am pretty sure the SuperH SH4 processor in the DC is supposed to have some
fancy floating point stuff. Once we get a compiler for the SH4 we'll
probably get better results. Plus, gcc probably optimises code much better
for x86s, PowerPCs, etc, than the SH3.'
While we are awaiting the actual benchmark figures, I think it will be safe
to assume that its around the 3 hours mark for the standard skyvase.pov at
640x480.
PGP Public Key
Subject: Re: POVRay Dreamcast port
Date: 7 Apr 2001 14:01:17
Message: <3ACF55F3.52EDD6C4@pacbell.net>
> 640x480.
3 HOURS !?!  My old XT could do it in 3 hours!
Ken Tyler
Date: 7 Apr 2001 15:17:14
Message: <MPG.1539782b51913029898ad@news.povray.org>
> > 640x480.
Yep, but IIRC the SH4 is a RISC chip, and I've never seen POV running at
any great speed on a RISC chip (Caveat: My experience of POV on RISC
machines is limited to Acorn Archimedes systems  which compared *Very*
poorly, even to my old 486DX2/66, and so may not apply to the SH4)
Bye for now,
     Jamie.
Date: 7 Apr 2001 18:28:02
Message: <chrishuff-88B0A4.17280307042001@news.povray.org>
In article <MPG.1539782b51913029898ad@news.povray.org>,
The PowerPC processors are RISC, and while they aren't the top
performers, they are far better than you implied. My 350MHz G3 rendered
skyvase.pov at 640*480, using adaptive antialiasing with a threshold of
0.3, in 1 minute 33 seconds.
The Dreamcast's processor runs at 200MHz, it should render skyvase.pov
in far less than 3 hours, even with an unoptimized compiler.
Christopher James Huff
Date: 7 Apr 2001 18:48:46
Message: <3acf994e$1@news.povray.org>
In article <chrishuff-88B0A4.17280307042001@news.povray.org> , Chris
Maybe (I do not know about the SH) the FPU only supports
single-precision floating point numbers in hardware?  If the compiler is
then forced to generate code for it you would get such a slowdown...
     Thorsten
Date: 7 Apr 2001 18:51:57
Message: <3acf9a0d$1@news.povray.org>
In article <MPG.1539782b51913029898ad@news.povray.org> ,
Even if you have not seen it, this is simply an incorrect
generalisation!
Because it didn't have an FPU?
    Thorsten
Date: 7 Apr 2001 20:30:58
Message: <chrishuff-2A5D3E.19305907042001@news.povray.org>
In article <3acf994e$1@news.povray.org>, "Thorsten Froehlich"
    I looked for specifications on it, and couldn't find any in-depth
information, but I did see a reference to a 64-bit floating point
unit...I interpreted that as a unit that handles 64-bit floats, though
it could be a vector unit handling 2 32-bit floats, or something similar.
    If it does double-precision through software, that would slow it
down a lot...nothing to do with it being a RISC processor, though.
Date: 7 Apr 2001 21:27:33
Message: <3acfbe85@news.povray.org>
don't forget that while a DC maybe able to handle very complex 3d geometry,
this is almost certainly handled by the gfx chipset to a certain degree, the
main cpu doesn't have to be (and probably isn't) up to much in terms of
actual computing power.
now if pov could figure out a way to use the geometry engines on 3d hardware
to do some floating point crunching :P
PGP Public Key
Date: 7 Apr 2001 22:52:33
Message: <chrishuff-896C23.21523407042001@news.povray.org>
In article <3acfbe85@news.povray.org>, "Rick [Kitty5]"
> hardware to do some floating point crunching :P
I doubt the geometry engines are any more capable at double-precision
calculations...and sending the information back and forth would probably
be even slower.
Date: 7 Apr 2001 23:59:21
Message: <3acfe219@news.povray.org>
 From what I can tell, the guy left it running at minimum priority because
that machine isn't just for rendering, but is also a webserver, and he
didn't want any slowdowns. So that benchmark is not accurate at all.
