POV-Ray : Newsgroups : povray.general : Request for enhancement Server Time
9 Oct 2024 16:13:12 EDT (-0400)
  Request for enhancement (Message 1 to 10 of 14)
Subject: Request for enhancement
Date: 2 Dec 2000 21:12:30
Message: <3a29ac0e@news.povray.org>
I'd really like it if PovRay had assignment operators,
so that it would know the difference between declaring
a variable and assigning a value to an existing one. It
would, in my case, signal a typo for the multitude of
variables used in some of my code. I like to declare
the default variables and then change them as needed
prior to calling macros.
#declare gl_XposAtMaxVelocity = 1.45;
later in the code:
#assign gl_XPosAtMaxVelocity = 2.00;
Then PovRay would check the existence of the previously
declared variable and issue a warning that the variable
does not exist. In the example above, I have a capital 'P'
where it should be lower case.
Currently, PovRay just creates the new variable and the
macro continues to use the old value and it's sometimes
difficult to find the error.
Just wishing...
Thanks again for making such a wonderful program!
=Bob=
Subject: Re: Request for enhancement
Date: 2 Dec 2000 21:56:02
Message: <3a29b642@news.povray.org>
> later in the code:
Why patch POV when you can do it with macros?:
#macro assign (Var, Value) #declare Var = Value; #end
Usage:
assign (gl_XposAtMaxVelocity, 2.00)
This should behave exactly as you want, issuing a warning when you try to
assign a value to a non-defined variable (and even showing you the mistyped
variable name!).
If you want to go one step further, you can create macros that allow you to
use named options with macro functions (so you don't have to declare/assign
all the options you want to use) - see my Spline Macro File at
http://www.geocities.com/ccolefax/spline for details.
Date: 2 Dec 2000 22:36:24
Message: <3a29bfb8@news.povray.org>
Hi Chris,
I was going to add in my post that a macro would
suffice to do the job, but I left it off as I was doing
three things at once. I do appreciate your solution
to my need, and will probably implement something
of the sort. It's just that it does puff up the code
quite a bit when you use hundreds of variables, and
the interpreter could do the job so much faster. Maybe
not as much as I think?
Thanks again, wishing you a wonderful evening!
=Bob=
"Chris Colefax" <chr### [at] tagpovrayorg> wrote in message
news:3a29b642@news.povray.org...
[My post and solution deleted]
: This should behave exactly as you want, issuing a warning when you try to
: assign a value to a non-defined variable (and even showing you the
mistyped
: variable name!).
: If you want to go one step further, you can create macros that allow you
to
: use named options with macro functions (so you don't have to
declare/assign
: all the options you want to use) - see my Spline Macro File at
: http://www.geocities.com/ccolefax/spline for details.
Date: 3 Dec 2000 03:25:40
Message: <3A2A0385.3E05A9FD@gmx.de>
Chris Huff's Megapov Plus has a new #set directive that does exactly this
(it produces an error if used with a not declared identifier)
Date: 3 Dec 2000 10:06:53
Message: <3a2a618d@news.povray.org>
Hi Christoph,
I just tried it and it works just like you said, that's
great! Do you know if this feature will be incorporated
into the next official release of PovRay?
Thanks again, have a great day!
=Bob=
news:3A2A0385.3E05A9FD@gmx.de...
[My previous post deleted]
: Chris Huff's Megapov Plus has a new #set directive that does exactly this
: (it produces an error if used with a not declared identifier)
: Christoph
: Christoph Hormann <chr### [at] gmxde>
: IsoWood include, radiosity tutorial, TransSkin and other
: things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 3 Dec 2000 11:22:16
Message: <3A2A7337.FDA1E19E@gmx.de>
=Bob= wrote:
> Hi Christoph,
> =Bob=
I don't think so, it was developed quite lately (just like the displace
warp :-) and therefore won't make it to the official version AFAIK.
BTW the current list with new features in 3.5 is in povray.announce.f-a-q.
Subject: POV-Team Status Report - September 1, 2000
Date: 4 Dec 2000 05:42:22
Message: <chrishuff-B26367.05430504122000@news.povray.org>
In article <3a29b642@news.povray.org>, "Chris Colefax"
Because you can't do this with macros? :-)
The #set directive works with both #declare and #local, and will be
faster than calling a macro, not to mention looking better in the scene
code...
Christopher James Huff
Date: 4 Dec 2000 05:46:36
Message: <chrishuff-DF6AD7.05471904122000@news.povray.org>
In article <3a2a618d@news.povray.org>, "=Bob=" <Bob### [at] threestrandscom>
It won't be, it is too new. As Christoph Hormann mentioned, the feature
list for 3.5 is in povray.announce.frequently-asked-questions.
It might make it into the next MegaPOV, whenever that comes out.
Date: 4 Dec 2000 09:03:14
Message: <3a2ba422@news.povray.org>
Thanks, Chris.
I checked out the list too. That's a feature that would
be rather nice to have. My only concern is making
something that can be used in all of the popular
versions. I guess that's not too easy.
Have a great day!
=Bob=
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-DF6AD7.05471904122000@news.povray.org...
: In article <3a2a618d@news.povray.org>, "=Bob=" <Bob### [at] threestrandscom>
: wrote:
: > Do you know if this feature will be incorporated
: > into the next official release of PovRay?
: It won't be, it is too new. As Christoph Hormann mentioned, the feature
: list for 3.5 is in povray.announce.frequently-asked-questions.
: It might make it into the next MegaPOV, whenever that comes out.
: Christopher James Huff
: Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
: TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 4 Dec 2000 09:11:42
Message: <3A2BA6E1.8E54FEF4@pacbell.net>
Careful ! Everytime I think something is impossible to do with
POV-Ray Mr. Colefax or Mr. Parker comes along and show just how
possible it really is :)
