POV-Ray : Newsgroups : povray.general : Water and oceans Server Time
25 Mar 2026 18:05:57 EDT (-0400)
  Water and oceans (Message 1 to 4 of 4)
Subject: Water and oceans
Date: 30 Nov 2000 23:50:43
Message: <3a272e23@news.povray.org>
I've been playing around with one scene I have. In order to give it a good
background, I have decided to add a body of water, but I'm at a loss over
how to model it correctly.
Should I try an isosurface? If so, any ideas on the function (RMF?)?
Thanks!
Yann
Yann Ramin                      atr### [at] atrustrivalieeuorg
Atrus Trivalie Productions      www.redshift.com/~yramin
AIM                             oddatrus
Marina, CA                      http://profiles.yahoo.com/theatrus
IRM Developer                   Network Toaster Developer
SNTS Developer                  KLevel Developer
Electronics Hobbyist            person who loves toys
Build a man a fire, and he's warm for a day.
Set a man on fire, and he'll be warm for the rest of his life.
"I'm prepared for all emergencies but totally unprepared for everyday
life."
Subject: Re: Water and oceans
Date: 1 Dec 2000 03:07:20
Message: <3A275C37.ED2581CA@gmx.de>
Yann Ramin wrote:
> Hi,
> Thanks!
> Yann
RMF is often a good idea for water, although some addidtional linear waves
are often better for sea water.  If you only need a background you do not
necessarily need an isosurface but can use a normal to speed things up.
There are some sample pictures on different finish settings for water on
my site.
Date: 1 Dec 2000 04:07:48
Message: <3A276BA4.844C56D6@unforgettable.com>
Yann Ramin wrote:
> Hi,
RMF makes good water; if you want something messier, you could modify
the function with wrinkles (or, depending on how you're using the water,
and especially how you're lighting it, wrinkles by themselves can work
pretty well).
-Xplo
Date: 1 Dec 2000 06:26:44
Message: <3a278af4$1@news.povray.org>
I posted an example of some isosurface water code to
povray.text.scene-files, title :'Isowater' on the 5th November 2000. It uses
an RMF isosurface, but you may want to add some other function probably
wrinkles if you are going for an ocean type scene.
I hope it's of use.
Kev
http://web.libertysurf.co.uk/kevin.ellis
