POV-Ray : Newsgroups : povray.general : Hierarchy in POV-Ray ? Server Time
3 Mar 2026 04:17:02 EST (-0500)
  Hierarchy in POV-Ray ? (Message 1 to 9 of 9)
Subject: Hierarchy in POV-Ray ?
Date: 1 Jul 2003 18:32:34
Message: <3F020CFD.5080606@free.Fr>
Hello,
Does POV-Ray support hierarchy of objects ?
I don't find anything about that in the doc.
Thanks.
Subject: Re: Hierarchy in POV-Ray ?
Date: 1 Jul 2003 18:47:45
Message: <3F02108C.4050205@free.Fr>
If you suggest me Union, where is the new centroid ?
Date: 1 Jul 2003 20:01:30
Message: <cjameshuff-599B0C.19004901072003@netplex.aussie.org>
    You'll have to be a little more descriptive with your
questions...what kind of heirarchy are you thinking of? Nested unions
can give you a hierarchical way of handling transformations and
textures, is that what you meant?
    I kind of doubt you are asking about the bounding heirarchies used
for optimization, but if you are, POV does support it. There is an
automatically generated bounding heirarchy for all finite objects, and
some objects such as blobs, meshes, and height fields support their own
internal heirarchies.
    That would depend on the objects you are using. POV doesn't know and
doesn't care. There are several ways you could define it, the method you
use depends in part on what you're going to use it for. I have a hunch
that you think transformations have something to do with the centroid of
an object...this is not the case, all transformations are relative to
the origin: < 0, 0, 0>
http://tag.povray.org/
Date: 1 Jul 2003 21:16:33
Message: <81MTTBANAjA$Ewwq@econym.demon.co.uk>
Whatever technique you use to determine the centroid of the parts will
presumably still work for the centroid of the union.
Mike Williams
Gentleman of Leisure
Date: 1 Jul 2003 21:57:53
Message: <3F023D19.9010107@free.Fr>
I mean a parent-child relationship, as in VRML.
If I move the parent, the child moves too.
If I rotate the child, it turns around the parent.
Are you talking about what I just described ??
I did think the centroid have something to do with transformations.
I meant that the transformations are supposed to be relative this point
(at least for me :-) )
Actually, I am doing a renderer for a school project, and I intended to
use basic POV files as input files. As I implemented a tree structure
for objects (geometry, cameras...), I was wondering if POV does use this
system.
Date: 1 Jul 2003 22:01:30
Message: <3F023DF2.1030605@free.Fr>
Well, suppose I want to do a solar system. All the planets are supposed
to turn around the sun (don't care about spin), and follow it when the
sun turns around the center of the galaxy.
I mean thiskind of hierarchy.
But there isn't any hierarchy in the union, I guess.
All the objects are equal.
Date: 1 Jul 2003 23:02:03
Message: <3f024b2b$1@news.povray.org>
Program ended abnormally on 2003-07-01 22:05, Due to a catastrophic
Oodini error:
I think the answer you're looking for, is yes.  Relative position of objects in
a union are kept when the transformation is applied to the whole union.
Date: 2 Jul 2003 02:28:50
Message: <jau4gv4qra1qp9v6dqd70fu4f5o67vfqaj@4ax.com>
Probably your question starts from misunderstanding that you can't create
object, then create orher object, then describe relation, then apply various
transformation selectively to various elements. But what are you looking for is
probably system like
#declare Earth_Globe=sphere{...};
#declare Moon_Globe=sphere{...};
#declare Earth_System=union{
                            object{Earth_Globe}
                            object{Moon_Globe transform{ ... }}
#declare Sun_Globe=sphere{...};
#declare Sun_System=union{
                          object{Sun_Globe}
                          object{Venus_System transform{ ... }}
                          object{Earth_System transform{ ... }}
                          object{Mars_System transform{ ... }}
#declare MilkyWay=union{
                        object{Sun_System transform{ ... }}
                        object{...}
ABX
Date: 2 Jul 2003 10:02:36
Message: <3f02e5fc@news.povray.org>
  Wrong.
union
{ object { Object1 }
  union // sub
  { object { SubObject1 }
    object { SubObject2 }
    union // subsub
    { object { SubSubObject 1 }
      object { SubSubObject 2 translate y /*this affects only this object*/}
      translate -y // this affects all objects in this 'subsub' union
    translate x // this affects all objects in this 'sub' union
  translate z // this affects all the objects
