POV-Ray : Newsgroups : povray.general : media interaction Server Time
31 Mar 2026 21:38:01 EDT (-0400)
  media interaction (Message 1 to 10 of 13)
Subject: media interaction
Date: 9 May 2003 19:58:11
Message: <3EBC4092.7080106@xith.net>
Good day to all,
I've just been teaching myself POVray in the last several days, and only
just started working with media. I'm trying to get an effect where one
light source is scattered and absorbed quite a bit by the media, but
other light sources are not affected. The result (which I don't know if
it's possible) would be that one of the objects in a scene has a bit of
a halo, while everything else is perfectly visible. Unfortunately, even
with "media_interaction off" in the other light sources, a high
absorption will black out the entire scene.
Does anyone know how to get around this? Can it be gotten around?
-M.C. ArZeCh
Subject: Re: media interaction
Date: 9 May 2003 20:14:42
Message: <cjameshuff-2FD5BD.20144509052003@netplex.aussie.org>
Don't use absorbing media. Use scattering media with an extinction of 0.
Actually, the way you're doing it is rather limiting and CPU intensive,
just putting emitting media around the object would be better.
http://tag.povray.org/
Date: 9 May 2003 20:22:29
Message: <3ebc4645@news.povray.org>
Alternately use scattering media and negative absorbing media.
e.g.
media{
   intervals 1
   confidence 0.0001
   variance 1
   ratio 0.5
   absorption   rgb<-0.5,-0.5,-0.5>
   scattering{1 rgb<0.5,0.5,0.5>}
Tim Cook
Version: 3.12
Date: 9 May 2003 20:44:21
Message: <3EBC4B64.1020800@xith.net>
The only problem I find with that is that you don't get the effect of
light pouring out of cracks in an object (which is really what I'm going
for; guess I should have been more specific), though I suppose I could
do something with manually adding emitting media in the proper shapes...
-M.C. ArZeCh
Date: 9 May 2003 20:58:58
Message: <cjameshuff-4DF01C.20585809052003@netplex.aussie.org>
Ah, I thought you were just talking about a plain halo effect. To do
this accurately you do need scattering, just set extinction to 0. If the
beams of light don't need to correspond exactly to openings in the
object, emitting media and a carefully designed density pattern might
work.
Date: 9 May 2003 21:07:06
Message: <cjameshuff-9B3C91.21070909052003@netplex.aussie.org>
In article <3ebc4645@news.povray.org>, Tim Cook <z99### [at] bellsouthnet>
Why? It's more work, possibly slower...what possible reason is there for
doing this?
Date: 9 May 2003 23:27:33
Message: <3ebc71a5@news.povray.org>
> doing this?
See my media wheel I posted a few ago in p.b.i ...negative absorption
and positive scattering give a scene that, if you don't have any
media-interacting lights, looks the same as (and afaict renders as
quickly as) the same scene without media, but you can turn on a media
interacting light and have it interact.
Tim Cook
Version: 3.12
Date: 10 May 2003 17:05:20
Message: <cjameshuff-2FBDE4.17052310052003@netplex.aussie.org>
In article <3ebc71a5@news.povray.org>, Tim Cook <z99### [at] bellsouthnet>
> > doing this?
Have you actually tried setting extinction to 0?
Date: 10 May 2003 19:06:28
Message: <3ebd85f4@news.povray.org>
Hmm nope, I'll play with that after my current render
finishes.
Tim Cook
Version: 3.12
Date: 10 May 2003 20:20:42
Message: <3EBD975A.9030305@xith.net>
> work.
Cool, I got the light beams workin'. Thanks :) What exactly does
"media_interaction off" do, then? Does it only apply to scattering effects?
And since it comes up, how exactly does one design a density pattern?
The documentation doesn't seem very clear on it.
-M.C. ArZeCh
