POV-Ray : Newsgroups : povray.general : Closest points on two circles Server Time
10 Nov 2025 23:20:19 EST (-0500)
  Closest points on two circles (Message 1 to 10 of 25)
Subject: Closest points on two circles
Date: 25 Mar 2003 07:22:37
Message: <3E804D3B.3070301@alphalink.com.au>
If this has been covered before then mea culpa, but I have searched the
links collection and the internet at large to no avail.
Does anyone possess a macro for calculating the points defining the
shortest path between two circles (not discs, circles) given the normal,
centre and radius of each circle, or some algorithm/formula from which
such a macro may be easily derived?
I am led to believe that the calculations involved in solving this
problem are reasonably difficult, so don't knock yourselves out trying
to work out a solution for me, unless you enjoy that kind of thing :?)
I'm really just hoping that someone happens to have the appropriate
information just lying around.
Thanks, Ed.
Subject: Re: Closest points on two circles
Date: 25 Mar 2003 08:47:40
Message: <3e805dfc$1@news.povray.org>
To get the vector for spheres:
#declare centerA=<10,5.0,-5.50>;
#declare radiusA=3.1415;
#declare centerB=<1.0,-45.0,15.50>;
#declare radiusB=0.1415;
#declare 1stpoint=  centerA+ radiusA*vnormalize(centerB-centerA);
#declare 2ndpoint=  centerB+ radiusB*vnormalize(centerA-centerB);
Then the vector in question is between 1stpoint and 2ndpoint.
A treatment for "circles"  is the same as that for spheres with coplanar
centers.
Date: 25 Mar 2003 08:53:44
Message: <3E806296.6090201@alphalink.com.au>
> centers.
Thanks, but my purpose requires a solution for pairs of circles with any
orientation and position relative to one another, not just coplanar circles.
Date: 25 Mar 2003 08:57:22
Message: <3e806042$1@news.povray.org>
To find the closest points on any pair of circles, simply draw a line from
center to center.  Then locate the points on each circle that the line passes
through.
Cheers!
Chip Shults
Date: 25 Mar 2003 08:57:59
Message: <fqn08vov70hujm7t7ihaepp17kaerr6kpl@4ax.com>
On Tue, 25 Mar 2003 08:47:08 -0500, "Greg M. Johnson" <gregj:-)565### [at] aolcom>
No. Being in 2D consider circle located at <0,0> with radius 2 and circle
located at <3,0> with the same radius 2. Closest points between circles are
located in intersections which are not between centers.
ABX
Date: 25 Mar 2003 09:00:27
Message: <3E80642A.3040301@alphalink.com.au>
> through.
This only works when both your circles are sitting on the same plane,
not when they may take any orientation in 3D space.
Date: 25 Mar 2003 09:03:38
Message: <3E8064E7.1090800@alphalink.com.au>
> ABX
Quite so, and furthermore my circles are not in 2D space, they are in 3D
space. However I'm happy enough not to consider cases where they
intersect one another.
Date: 25 Mar 2003 09:09:15
Message: <0do08v0h6ucslf7mli0f0dfo1q8lv4eoo9@4ax.com>
On Wed, 26 Mar 2003 01:14:02 +1100, Edward Coffey <eco### [at] alphalinkcomau>
You have to define distance as function and then find where it has minimum.
http://mathworld.wolfram.com/Minimum.html
ABX
Date: 25 Mar 2003 09:10:23
Message: <3E80667D.9040506@alphalink.com.au>
Sorry, I should have been more clear - when I specified that I was
dealing with circles not discs I did not mean to imply that I was
working in a 2D space, only that the path had to connect to the
circumference, not to any point within a disc.
My circles exist in 3D space and may take any position or orientation
relative to one another.
Date: 25 Mar 2003 09:19:19
Message: <3E806895.2050008@alphalink.com.au>
Yes, but as I stated in my original post, the mathematics of this is
quite complex, it's not as though you're finding the minimum of a
quadratic equation with one variable. Certainly the mathematics of it is
quite beyond my abilities, which is why I haven't asked anyone to solve
it, simply that if they happen to have access to a solution (or if
they're math mad and really want to create their own solution) to post
it here.
