POV-Ray : Newsgroups : povray.general : Help needed with Lissajous Knot Server Time
5 Aug 2024 04:16:57 EDT (-0400)
  Help needed with Lissajous Knot (Message 1 to 10 of 12)
Subject: Help needed with Lissajous Knot
Date: 31 Dec 2002 07:09:54
Message: <3e118912@news.povray.org>
Hi everyone,
      Firstly, a very happy New Year to you all. I hope it's a good
one for all of you.
   Ok, can someone help me out here? I can't seem to get Lutz-Peter
Hooges' Lissajous Knot Generator to work. PoV3.5 reports that a
'numeric expression' is expected, but ^ found instead. This happens
with #macro method3, but if I change the method, it happens with that
corresponding method too.
      The Generator can be found here:
http://news.povray.org/povray.text.scene-files/20596/135690/#135690
     Where am I going wrong with this?
      Thanks for any help.
      ~Steve~
Subject: Re: Help needed with Lissajous Knot
Date: 31 Dec 2002 07:29:15
Message: <3E118DC6.6040800@ibras.dk>
> 'numeric expression' is expected, but ^ found instead.35690/#135690
I don't think ^ is a legal operator in Pov. Try the pow(a, b) function
instead.
/Ib
Date: 31 Dec 2002 07:31:45
Message: <3e118e31$1@news.povray.org>
I made that script with a beta verison of 3.5 wich did still include the
"^" Operator.
Just replace any a^b in the script with pow(a,b), then it should work as
expected.
Lutz-Peter
Date: 31 Dec 2002 08:21:04
Message: <3e1199c0@news.povray.org>
"Ib Rasmussen" <ib### [at] ibrasdk> wrote in message
news:3E1### [at] ibrasdk...
 and...
"Lutz-Peter Hooge" <lpv### [at] gmxde> wrote in message
news:3e118e31$1@news.povray.org...
the
> "^" Operator.
      Ah, sorry, I should have guessed. I thought it looked different
from your first one.
work as
> expected.
   Many thanks both, but I still don't know where to change the
script. (I've tried everything apart from the correct places of
course...)  ;)
  Could you show me where and how please?
  Here's the part:
 #macro Method3(T)
  R*sin(A*T)*sin(B*T)^exp_X,
  R*sin(A*T)*cos(B*T)^exp_Y,
  R*sin(A*T)^exp_Z
   ~Steve~
> Lutz-Peter
Date: 31 Dec 2002 08:32:09
Message: <3E119C83.8060702@ibras.dk>
>   Here's the part:
>  #macro Method3(T)
>   R*sin(A*T)^exp_Z
> #end
That should be
  #macro Method3(T)
   R*sin(A*T) * pow(sin(B*T), exp_X),
   R*sin(A*T) * pow(cos(B*T), exp_Y),
   pow(R*sin(A*T), exp_Z)
if I understand it right. I haven't tested it, though.
/Ib
Date: 31 Dec 2002 08:59:03
Message: <3e11a2a7@news.povray.org>
> That should be
>   #macro Method3(T)
>  #end
      Thanks Ib!  :)  That works a treat!
       All the best.
      ~Steve~
> /Ib
Date: 31 Dec 2002 09:00:06
Message: <web.3e11a27556251e337d655a8f0@news.povray.org>
Ib Rasmussen wrote:
>>   Here's the part:
>>  #macro Method3(T)
>>   R*sin(A*T)^exp_Z
>> #end
>That should be
>  #macro Method3(T)
> #end
Ib, I think he is using the code Lutz-Peter Hooge
posted to povray.text.scene-files 8. Dec. 2001 for
his "Lissajou-Knot generator":
http://news.povray.org/povray.binaries.images/20597/
And if that is so, then he should rewrite the
macro like this (for the final POV-Ray v3.5):
#macro Method3(T)
    R*sin(A*T)*pow(sin(B*T), exp_X),
    R*sin(A*T)*pow(cos(B*T), exp_Y),
    R*pow(sin(A*T), exp_Z)
Tor Olav
Date: 31 Dec 2002 09:11:36
Message: <3E11A5C3.9010406@ibras.dk>
> #macro Method3(T)
> #end
Oops, yes, the R should be outside the pow-function. Thanks.
/Ib
Date: 31 Dec 2002 10:52:56
Message: <3e11bd58@news.povray.org>
> > #macro Method3(T)
> > #end
   I've just tried both ways, and both work??
     ~Steve~
> /Ib
Date: 7 Jan 2003 14:43:17
Message: <3e1b2dd5@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:3e11bd58@news.povray.org...
       Well, both DO work, but I've just discovered that I can't use
Tors' (correct) way unless I translate the object again and I'm not
doing that because it took *AGES* to get it where it is now with Ibs'
way. (Sorry Ib).
    So I now I have a new problem and it may be connected with the
above but I'm not sure. In Lutz-Peters' code, right at the very end,
there is the 'no_shadow' comment and of course, it produces no
shadows, but if I comment it out, it still produces no shadows. The
only way I can get shadows back in the *whole* scene is by taking the
Lissajous Knot code out and the shadows come back again.
  Any ideas about what's causing this?
    ~Steve~
