POV-Ray : Newsgroups : povray.general : Empty object Server Time
17 Nov 2025 18:47:31 EST (-0500)
  Empty object (Message 1 to 10 of 14)
Subject: Empty object
Date: 21 Nov 2002 09:38:03
Message: <3DDCF201.8E1826C9@frege.mathematik.uni-freiburg.de>
I occasionally (usually to feed parameters to CSG macros where) need an
empty object.
(This means that the spatial extension is empty.) Consider the following
approaches:
    #declare No_object1 = box {0 0}
    #declare No_object2 = intersection {box {0 0} box {1 1}}
    #declare No_object3 = quadric {0 0 0 1}
The first is quite fast but actually not correct: The object contains
one point.
It might happen that a stray ray accidentally hits this point, causing
artefacts.
The second remedies the problem, but causes a
    Warning: Degenerate CSG bounding box (not used!).
which I dislike for aesthetical reasons. The third, which I currently
use,
is fine. But it has no bounding box either and hence uses as much time
as the second. I might add a bounding box to the third approach, but I
still hope there might be a more elegant solution.
Any suggestions?
  Mark Weyer
Subject: Re: Empty object
Date: 21 Nov 2002 09:47:31
Message: <3ddcf203@news.povray.org>
> one point.
> artefacts.
  Add "no_image no_reflection no_shadow" to it, so it should be completely
ignored (at least in theory).
Date: 21 Nov 2002 09:59:33
Message: <3DDCF70D.3354F466@frege.mathematik.uni-freiburg.de>
Not if used in difference. Or do I get something wrong?
To be more precise:
difference {
  box {<-1,-1,0> <1,1,1}
  box {0 0 no_image no_reflection no_shadow}
I did not try this, but if the stray ray actually hits the 0-box, I think it
would decide not to have hit the surface of the defference yet. Hence
it would continue INSIDE the object.
  Mark
Date: 21 Nov 2002 10:04:23
Message: <u8tptu8n6u4u1tf3qrttrgss5sopp72vug@4ax.com>
On Thu, 21 Nov 2002 16:09:02 +0100, Mark Weyer
> To be more precise:
> difference {
Do you really need an empty object ? Can't you directly use first box object
then instead of whole difference object ?
ABX
Date: 21 Nov 2002 10:16:44
Message: <3DDCFB14.62D0D20C@frege.mathematik.uni-freiburg.de>
It seems I forgot to repeat the following information in my
second post: It need the empty object to feed it as a parameter
to macros using CSG.
Example: I might have a macro for doors. One of its parameters
is the key shape, so I can carve in (using difference) an appropriate
keyhole. Sometimes I might need a door without a keyhole. The I
would feed the empty object for the key shape. Following your idea
I would have to make a second copy of the door macro where I omit
the carving out of the keyhole.
  Mark Weyer
Date: 21 Nov 2002 10:26:00
Message: <3DDCFB05.CDBD2CD8@gmx.de>
If you are not up to maximum speed just use a poly or isosurface with no
solutions...
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 21 Nov 2002 10:27:43
Message: <68uptuc2ftpaajn57ltngrubigtm6vllhn@4ax.com>
On Thu, 21 Nov 2002 16:26:12 +0100, Mark Weyer
I already saw this but I intentionaly provoked you to more precise answer :-)
There is a lot of ways how you can do this without empty object.
For example:
// indexes to array
#declare DoorsId=0;
#declare KeyholeId=1;
#declare Key=2;
#macro Room(Elements)
  #local Door=Elements[DoorsId];
  #ifdef(Elements[KeyholeId])
    #local Door=intersection{
                  object{Door}
                  object{Elements[KeyholeId]}
    #ifdef(Elements[Key])
      #local Door=union{
                    object{Door}
                    object{Elements[Key]}
ABX
Date: 21 Nov 2002 10:35:23
Message: <3DDCFF73.C06ACF8C@frege.mathematik.uni-freiburg.de>
You are right. But I still prefer the empty-object-method for
some applications, because it is more elegant to my taste.
  Mark
Date: 21 Nov 2002 10:37:35
Message: <3DDCFFF8.96CF425D@frege.mathematik.uni-freiburg.de>
> solutions...
In fact, my third approach (quadric {0 0 0 1}) is quite similar.
What is your suggestion for maximum speed?
  Mark
Date: 21 Nov 2002 10:48:36
Message: <vevptu8f8emubfmiq27dba239m9rak6qoj@4ax.com>
On Thu, 21 Nov 2002 16:44:51 +0100, Mark Weyer
Wasting memory for not necessary CSG objects is elegant? I doubt.
ABX
