POV-Ray : Newsgroups : povray.general : Help changing background light intensity Server Time
6 Oct 2024 07:20:42 EDT (-0400)
  Help changing background light intensity (Message 1 to 10 of 18)
Subject: Help changing background light intensity
Date: 10 Oct 2002 17:46:40
Message: <3DA5F540.F2B3FA6E@ufl.edu>
I'm able to change the  intensity, but only if I also change the color.
Is there a way that I can change ONLY the intensity of the background?
Thank you for help ahead of time.
Subject: Re: Help changing background light intensity
Date: 10 Oct 2002 19:43:34
Message: <3da610a5@news.povray.org>
  You don't give enough information to give a proper answer.
  Are you talking about the background {} feature or the ambient_light
feature, or perhaps something else?
  Anyways, in order to change the intensity of a color, just multiply it
with a float.
Date: 10 Oct 2002 20:04:16
Message: <Xns92A414D28B47Eraf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3da610a5@news.povray.org
> with a float.
or use hsv2rgb macro (is that correct spellig ?)
btw.
how about ne future - types of colors interpolating :
colors_rgb
colors_hsv ?
i.e.
gradient color_map{[0 rgb <1,0,0>][1 rgb <0,1,0>] colors_rgb}
will give : red dirty-red dirty-yellow dirty-green green
gradient color_map{[0 rgb <1,0,0>][1 rgb <0,1,0>] colors_hsv}
will give : red red-yellow yellow yellow-green green
I will write try to implement this futre, do You think it would be usefull
Date: 10 Oct 2002 21:20:03
Message: <web.3da626df23ad0e644b26c9670@news.povray.org>
Take a big sphere instaed of a background {...} or a sky_sphere.
Then you have a finish definition also to play with. But it is not possible
to rise the ambient level and to not change the background color impression
imho.
Norbert
Date: 11 Oct 2002 03:18:58
Message: <fgucqu4mhn13aldspfkk016iom072qtuf3@4ax.com>
On 10 Oct 2002 20:04:16 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> > with a float.
CHSV2RGB(Color)
> btw.
> colors_rgb
> colors_hsv ?
Why ? If it is easy possible with macro (already included in official package)
then no need to waste time for coding. There will be no difference between
macro and builded feature. It have to be always converted to rgb internally.
No :-)
ABX
Date: 11 Oct 2002 08:18:27
Message: <3da6c192@news.povray.org>
  Why? That just slows down the rendering...
Date: 11 Oct 2002 15:40:42
Message: <chrishuff-7DF4DD.15370511102002@netplex.aussie.org>
In article <fgucqu4mhn13aldspfkk016iom072qtuf3@4ax.com>,
I think he is talking about different blending methods...currently,
color_maps do a linear interpolation of RGB colors, and will return <
0.5, 0.5, 0> with a pattern value of 0.5 with that color map, the user
might have expected < 1, 1, 0>. Doing a linear interpolation in HSV
space would give a very different blend...it would make it possible to
specify two colors with maximum brightness and saturation and get a
rainbow of hues all of the same brightness.
However, it would be slower. Not by a lot, the conversion of the color
entries could be done at parse time (assuming you will never want to
access the color entries directly, with something like an array syntax),
but it still has to convert back to RGB space. It may be faster to just
use an RGB map with more entries.
I have considered doing something related to this, along with different
interpolation types like cosine and cubic interpolation. Color maps are
very similar to splines in some ways, I've been thinking it might be
better to merge them into the spline feature.
Basically, all the *_map keywords would be replaced with "blend", the
parser would be smart enough to figure out what kind of blend is needed.
The color_map feature would be replaced with the spline feature.
Pigments would be vector functions. Something like that code could be
written as:
#declare colorSpline =
spline {
    [0, rgb2hsv(< 1, 0, 0>)]
    [1, rgb2hsv(< 1, 1, 0>)]
#declare theTexture =
    pigment hsv2rgb(colorSpline(bozo(x, y, z)))
Maybe an in-line syntax for splines too:
    pigment hsv2rgb(
        spline {//linear would be default
            [1, rgb2hsv(< 0, 1, 0>)]
        }(bozo(x, y, z))
Ok, that looks a bit wierd, but is much more flexible and could be
backwards compatible, it doesn't have to replace the existing syntax.
One thing I don't like, you have to watch for the differences between
code run at parse/scene setup time and code run at render time, but the
same problem exists now and it doesn't cause much trouble.
http://tag.povray.org/
Date: 12 Oct 2002 15:10:05
Message: <Xns92A5D713E8B18raf256com@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:fgucqu4mhn13aldspfkk016iom072qtuf3@4ax.com
>> btw.
>> colors_rgb
>> colors_hsv ?
> package) then no need to waste time for coding. There will be no
> difference between macro and builded feature. It have to be always
As Christopher pointed out, I was talking about different blending method.
HSV and even splines color map doesn't need to be slower, IF we would
optimize it - and i.e. precalculate 256 (with can be done even now - with
macro), or 4096 (or more) colors.
bozo color_map{[...][...] hsv_blending precalculate {4096}}
I have some more ideas for it, I will do some tests and post full hmm CFF
(Call For Feature ? maybe RFD ? is there some name for that documents :)
in near future :)
Date: 12 Oct 2002 15:12:10
Message: <Xns92A5D76E7C263raf256com@204.213.191.226>
"Norbert Kern" <nor### [at] t-onlinede> wrote in
news:web.3da626df23ad0e644b26c9670@news.povray.org
> possible to rise the ambient level and to not change the background
> color impression imho.
no,
background rgb A
sky sphere rgbf <B,B,B,f>
is same (but slower) as :
background rgb A*(f)+b*(1-f)
Date: 12 Oct 2002 15:40:59
Message: <Xns92A5DC51D488Fraf256com@204.213.191.226>
Christopher James Huff <chr### [at] maccom> wrote in news:chrishuff-
7DF### [at] netplexaussieorg
>     pigment hsv2rgb(
>         }(bozo(x, y, z))
IMHO I think that this syntax is wierd [1], better would be to extend
color_map by new keywords.
[1] this time it's me who is criticizing :P no offence :)
