POV-Ray : Newsgroups : povray.general : Blob problem? Server Time
16 Jul 2026 02:38:29 EDT (-0400)
  Blob problem? (Message 1 to 10 of 20)
Subject: Blob problem?
Date: 25 Aug 2002 13:46:25
Message: <3D693445.3020704@tuna.nl>
I have a very minimal scene with a blob that does not behave like I
expect it.
Basically it is the first tutorial scene from 3.6.1 with two extra
spheres added above the originals. It seems to render some artifacts
where the top spheres connect to the bottom ones.
I am new to POV-Ray and don't know the right way to do this. But I
expect just dropping the scene files into p.b.scene-files would not be
the way to go so I thought I'd ask here.
Thanks for your time,
Rob
Subject: Re: Blob problem?
Date: 25 Aug 2002 14:24:37
Message: <3d6920e5@news.povray.org>
"Rob Hoopman" <rob### [at] tunanl> wrote in message
news:3D6### [at] tunanl...
Have a read of Rune's blob tutorial:
http://runevision.com/3d/blobs/blobs.asp
Date: 25 Aug 2002 14:29:00
Message: <3d6921ec@news.povray.org>
> expect it.
A short, concise, sample of a problem scene file is fine posted as text here
in p.g.
Have you already tried sturm in the blob statement? If not then that's
something to check on. It could be a shadows on the surface normals thing,
the blob equation causing erratic changes in it. If that doesn't seem to be
it a posting of a render showing it would be good to see, at p.b.i. or at
least the blob + camera + light script so someone else besides you can
render it.
Date: 25 Aug 2002 15:11:10
Message: <3D694822.9060708@tuna.nl>
I did, allthough his site down at the moment, well not so much down as
having problems connecting to the database.
Rob
Date: 25 Aug 2002 15:46:33
Message: <3d693419@news.povray.org>
Blobs have artifacts, sometimes. This is still a problem with POV, but you
could try to move each blob component away from the others. They must not be
very close to each other.
Hugo
Date: 25 Aug 2002 16:13:07
Message: <3D6956A7.3020900@tuna.nl>
>>expect it.
> in p.g.
> render it.
I had a look at the docs regarding the sturm keyword and don't think it
would solve my problem. (Allthough I must say it is not exactly clear to
what values I would have to set it. What is a "boolean float value",
does this mean any float value that is not zero evaluates to true?)
If it helps I can also post an image to p.b.i.
Rob
Download 'us-ascii' (1 KB)
Date: 25 Aug 2002 16:56:42
Message: <3D694490.D5737AC4@worldnet.att.net>
> camera {
>   angle 15
>   location <0,2,-10>
>   look_at <0,0,0>
Narrow camera angles can make stuff show up wrong... try it with one like this
  location <0,0,-2.25>
  look_at <0,0,0>
Tim Attwood
Date: 25 Aug 2002 17:03:17
Message: <3d694615@news.povray.org>
I tested your scene and fiddled with the variables (if you remove "angle"
from camera, the problem will disappear in this particular case) but
basically, it's caused by the current limitation of blobs.  The blob bugs
were not fixed in POV3.5. If you wish, you can read about them here:
http://news.povray.org/search/advanced/?s=blob&bug&b=Search&g=povray.beta-te
st&a=0&p=0
- Hugo
Subject: Thank you and Tim, problem solved. [n.t.]
Date: 25 Aug 2002 17:22:09
Message: <3D6966D6.1020506@tuna.nl>
n.t.
Date: 25 Aug 2002 17:29:08
Message: <3d694c24@news.povray.org>
> well not so much down as having problems
What the...!??
I was not aware of that. I'll have to look into that. Problem is that I
don't have much time right now, but I'll see what I can do.
Rune
rune|vision:  http://runevision.com (updated July 12)
POV-Ray Ring: http://webring.povray.co.uk
