POV-Ray : Newsgroups : povray.general : POV crash Server Time
22 Apr 2026 15:24:18 EDT (-0400)
  POV crash (Message 1 to 7 of 7)
Subject: POV crash
Date: 12 Aug 2002 12:01:34
Message: <3D57DBDC.4070201@scifi-fantasy.com>
At 1% of image with code
sphere_sweep {
   //linear_spline                 // linear curve
   cubic_spline                  // alternative spline curves
   //b_spline
   600,                              // number of specified sphere positions
#declare Seed=seed(0);
#declare N=1;
#while(N<=300)
#declare Theta=rand(Seed)*360;
#declare Z=rand(Seed)*0.5+1.2;
#declare R=rand(Seed)*0.25+((Z-1.2)*0.5);
#declare X=R*cos(Theta);
#declare Y=R*sin(Theta);
<X, Y, Z> 0.02
#declare N=N+1;
#declare N=1;
#while(N<=300)
#declare Z=rand(Seed)*0.1+1.7;
#declare R=rand(Seed)*1+((Z-1.7)*2);
<X, Y, Z> 0.02
#declare N=N+1;
   texture{
     pigment{
       color rgb <0.55, 0.5, 0.45>
     finish{
       ambient 0.5
       diffuse 0.5
       brilliance 1.5
       specular 0.5
       roughness 0.01
       reflection 0.2
   texture{
     pigment{
       color rgb <1.0, 1.0, 1.0>
and while running the 'blank screen' screensaver, it gave the following
error:
The POV-Ray core rendering code caused an access violation exception.
It is STRONGLY RECOMMENDED that you save your work and exit the program
before attempting the render again.
(Note that if internal structures have been damaged POV-Ray may crash
immediately after you click OK).
What's up with that, and how do I solve the problem?
Tim Cook
Version: 3.12
Subject: Re: POV crash
Date: 12 Aug 2002 12:14:57
Message: <3d57df01$1@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3D5### [at] scifi-fantasycom...
<snip>
Seems okay here under win2000 - has it crashed more than once?
Date: 12 Aug 2002 12:16:36
Message: <3D57DF61.3030209@scifi-fantasy.com>
Not yet, I'm rerunning it with screensaver turned off to see if
that was the problem.
Tim Cook
Version: 3.12
Date: 12 Aug 2002 12:27:10
Message: <3D57E1DC.7030309@scifi-fantasy.com>
...yep, there it goes again.  Line 7 of 480 with 2x AA.
Tim Cook
Version: 3.12
Date: 12 Aug 2002 13:07:25
Message: <3D57EB4B.8050801@scifi-fantasy.com>
But it works when I turn off the cube that I've got everything inside of
in the moray scene...hmm...guess that's the problem.
Tim Cook
Version: 3.12
Date: 12 Aug 2002 13:34:54
Message: <3d57f1be$1@news.povray.org>
I got a similar problem when I tried overclocking too much.  Though it
resulted in *random* crashes.
Did iit crash after you clicked ok?  For me it did.
> sphere_sweep {
>    //b_spline
positions
> #declare N=1;
> #while(N<=300)
> <X, Y, Z> 0.02
> #declare N=N+1;
> #end
> #declare N=1;
> #while(N<=300)
> <X, Y, Z> 0.02
> #declare N=N+1;
> #end
>    texture{
>      pigment{
>      finish{
>        ambient 0.5
>        diffuse 0.5
>        brilliance 1.5
>        specular 0.5
>        roughness 0.01
>        reflection 0.2
>    texture{
>      pigment{
> error:
> Tim Cook
> http://empyrean.scifi-fantasy.com
> mirror: http://personal.lig.bellsouth.net/lig/z/9/z993126
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 12 Aug 2002 14:00:27
Message: <3D57F7B8.7050009@scifi-fantasy.com>
Nope...actually I think it might be a problem with the
random numbers it's trying to generate; I started to
play with the formula for my R and was able to incur
the error on several different formulas...I think the
seed number has something to do with it, when I upped
it to > N the problem in the instance I was working
with went away...
Tim Cook
Version: 3.12
