POV-Ray : Newsgroups : povray.general : Positioning orthographic camera - error ? Server Time
23 Apr 2026 13:22:12 EDT (-0400)
  Positioning orthographic camera - error ? (Message 1 to 8 of 8)
Subject: Positioning orthographic camera - error ?
Date: 31 Jan 2002 04:03:45
Message: <3C590842.6AC3D10D@psi.ch>
Hello,
I am new to this group and browsing through the messages, I find that I
am pleased you are all here. I have been using POV-Ray for some time
now. There is a problem that I have with the orthographic camera which I
could not find mentioned anywhere else.
The problem is as follows.
This works:
camera { orthographic location <0,0,-10> right <4,0,0> up <0,3,0>  }
This does not work:
camera { orthographic location <10,0,0> right <0,0,4> up <0,3,0>  }
Both should be possible, but the latter gives an error:
"Cannot use non-perpendicular camera vectors with vista buffer".
I worked around it by rotating the scene, but that is not a satisfactory
solution.
The system I am using is:
-Povray 3.1 for Windows
-Windows NT
Is there a way to get the second version of the camera
positioning to work? I find that most directions
and positions that deviate from the first version give the same error
message
even when the vectors are perpendicular.
Finally, the solution that is offered in the help file to add the
command "look_at" is also not satisfactory because that can rotate
the camera around it's own axis resulting in to a completely
different setting than "right" and "up" were set.
Ralph
Subject: Re: Positioning orthographic camera - error ?
Date: 31 Jan 2002 04:24:30
Message: <3c590d4d@news.povray.org>
Hi Ralph :
> This works:
> This does not work:
> solution.
> message
You don't mention "direction" at all, and this is very important. The
viewing direction has a default value of <0,0,1>, then the message must
mean that "right"  is not perpendicular to default "direction". Both "up"
and "right" need to be perpendicular to the viewing direction, I think.
So, perhaps you need also to specify "direction <-1,0,0>"  to override the
default viewing direction.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 31 Jan 2002 05:54:29
Message: <3C592237.BA5608C0@psi.ch>
Thanks Jamie!
That was as accurate as fast :) It works now that I set the
direction vector. It is so much nicer to have the scene set and
just move the camera about.
All the time I was assuming silently that the orthographic
camera did not use the direction vector... now I know it does.
Furthermore, I would like to add that it will not even work for
camera { orthographic location <4.33013,5,-7.5>
                direction <-6.01900,-6.95016, 10.4252>
                right <3.72831,0,2.15254>
                up <-0.807203,2.79623,1.39812> }
but will for this:
               direction <-0.433012701892,-0.5,0.75>
               right <3.72831275528,0,2.15254237288>
               up <-0.807203389831,2.79623456646,1.39811728323> }
so 6 significant digits are not good enough some times.
Ralph
Date: 31 Jan 2002 06:04:14
Message: <3c5924ad@news.povray.org>
  I think you are going the hard way... I prefer to think that up and right
have nothing to do at all with camera position or direction, but rather
with the "film" or "visualization window" size. I prefer to have it fixed
at the default orientation, only sizing them for ratio purposes, and then
using only location, direction (some prefer angle) and look_at to control
the camera. It's much more easy this way for me, but I rarely need to
accurately positioning the camera, tough.
Date: 31 Jan 2002 08:07:53
Message: <3C594179.F139A166@psi.ch>
> <...> I think you are going the hard way... I prefer to think that up and
> right
> the camera. <...>
You are right. It is the hard way. Using the "position" and "look_at" vectors
is much simpler to imagine. But how do you work around the jump in orientation
from
camera { orthographic location <0,1,0.01> look_at <0,0,0> }
to
camera { orthographic location <0,1,0.00> look_at <0,0,0> }
That is the only reason I chose "up" and "right": to avoid discontinuities...
when the
camera is pointing in directions close to the y-direction. I'd gladly switch to
"position" and "look_at" if there was an easy way to get
round the jump (perhaps with angle? but when will the camera flip round?).
Ralph
Date: 31 Jan 2002 11:30:16
Message: <3c597118@news.povray.org>
> to avoid discontinuities... when the camera is
> I'd gladly switch to "position" and "look_at" if
> there was an easy way to get round the jump
Try looking at the sky vector.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Date: 31 Jan 2002 16:20:41
Message: <3C59B503.614A18FC@spiritone.com>
Ralph Muench wrote:
> Thanks Jamie!
I think that it needs the direction vector for the direction, but it
ignores the magnitude with orthographic projection
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Date: 1 Feb 2002 08:56:10
Message: <3C5A9E4A.A4C43BB9@psi.ch>
Josh, Rune and Jamie. Thanks for your input.
You have been a great help. I believe to have the
orthographic camera sorted out now :).
Ralph
