POV-Ray : Newsgroups : povray.general : Layered Texture problem Server Time
19 Oct 2024 06:18:57 EDT (-0400)
  Layered Texture problem (Message 1 to 3 of 3)
Subject: Layered Texture problem
Date: 27 Jan 2002 17:15:55
Message: <3C547C71.8030002@web.de>
Hi there...
Im currently working on a model converter for Q3A .md3 models but I
found a problem(?) with layered textures.
I got the following:
#declare tex =
   pigment {Cyan}
   finish {specular 1 reflection .25}
     image_map {
       tga ....
   finish {
     ambient .15
     diffuse .9
The tga file has transparency info so there are cyan spots which should
reflect a bit. The thing is that the whole texture reflects, even the
parts of the image map (same with the specular). - using linux.beta10
Is this something I missed in the docs or is something wrong with Pov.
Sebastian H.
Subject: Re: Layered Texture problem
Date: 27 Jan 2002 18:08:07
Message: <et195useue0rjqadhamam7ao83gfpbjtp4@4ax.com>
On Sun, 27 Jan 2002 23:17:21 +0100, "Sebastian H." <seb### [at] webde>
This is expectable. Use a patterned texture instead of layered
texture.
Peter Popov ICQ : 15002700
Date: 28 Jan 2002 09:51:12
Message: <3C5565B8.2010404@web.de>
> texture.
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
This is what I wanted to avoid, is there no other way?
The tga file has a alpha channel that i would have to convert to a png
file for use with a material_map but this is like digging a hole with a
brush (poor brush)...
