POV-Ray : Newsgroups : povray.general : Long time, no see.. Server Time
5 Mar 2026 06:52:15 EST (-0500)
  Long time, no see.. (Message 1 to 7 of 7)
Subject: Long time, no see..
Date: 24 Jan 2002 12:15:06
Message: <3C504118.7030500@ida.utb.hb.se>
Hi!
After a hard year in the business world, I'm back at the university
again (God knows for how long :) )
Anyway, this means I get some spare time again, and spare time means
hobbies (and hobbies means - you guessed it - POV).
Things have changed quite a bit since then, in that I have converted
completely to Linux (all 3 machines at home run some distro now).
Progeny's Debian is a favourite (too bad they stopped developing it),
but I'm looking forward to the Debian "Woody" release as it will
probably contain some of the features of Progeny. Too bad we also sit so
firmly in m-softs knee at the uni..I'll do my best to change that.
Well, as I fired up POV at the uni for the first time in a while (3.5
beta10, Win version) and checked to see how 3.5 worked with my old
SmokeGen include, I noticed something strange when doing one of the
animation demos (SplFile2.ini in the SplFile demo directory).
It seems as the initial clock value passed from the ini file gets
slightly altered by POV3.5 - the ini file reads
Initial_Clock=0.2
but debugging the value at the first frame, I get
0.20000000298023224000000000000000 (str:ing the clock value with 32
decimals)
..which means the file used to store the values from previous runs won't
be opened WRITE and thus not overwritten when re-rendering the scene.
Is this a known "problem"? I.e. has there been a change in how the clock
value gets calculated in v3.5?
- Mikael
Subject: Re: Long time, no see..
Date: 24 Jan 2002 12:34:55
Message: <3c5045bf$1@news.povray.org>
In article <3C5### [at] idautbhbse> , Mikael Carneholm
> Initial_Clock=0.2
> decimals)
Floating-point numbers are not precise.  You should never assume they are.
    Thorsten
Date: 24 Jan 2002 12:58:56
Message: <3C504B5E.7050505@ida.utb.hb.se>
That's not a problem..the problem is that both Initial_Clock and the
value it gets compared with in the include file (SceneStartClock) should
have the same value (at the first frame), as they are both set to
exactly 0.2 at frame 1 (actually, SceneStartClock is set to this during
the whole animation, to be exact :) ).
Debugging both values (at frame 1) gives me this:
Clock=0.20000000298023224000000000000000
SceneStartClock=0.20000000000000001000000000000000
How come they are not both 0.20000000298023224000000000000000? (Or
0.20000000000000001000000000000000 for that reason, doesn't matter as
long as they get the same value if one sets them to 0.2, each)
Seems to me that there has been a change in how the clock value is
calculated - and also notice that +KC (cyclic animation) was not used.
But on the other hand - I may have forgot some important detail, as this
is the first time I use POV in about a year :)
- Mikael
Date: 24 Jan 2002 22:02:35
Message: <3c50cacb@news.povray.org>
"Mikael Carneholm" <mik### [at] idautbhbse>
wrote in message news:3C5### [at] idautbhbse...
are.
But the differences are so minute, it might be.  If you're comparing floats,
you should compare them within a small range, for instance,
if (fabs(a-b) < 0.001)
rather than
if (a == b)
Or something along those lines.
(Sorry, I've been using c++ lately, so the POV SDL equiv escapes my mind,
but it's not too different).
...Chambers
Subject: Same params, different values (Was: Long time, no see..)
Date: 25 Jan 2002 09:49:02
Message: <3C51705E.9040807@ida.utb.hb.se>
Hi again!
Said and done, I took the bull by the horns and fired up POV 3.1g to
verify my suspission that something has changed from 3.1 to 3.5 (could
it be the change of compiler?)
And, to my relief, 3.1g gave me the "correct" values and verified that
this is something that _used_ to work.
clock=0.20000000000000000000000000000000 :
SceneStartClock=0.20000000000000000000000000000000
Same scene, same ini file, same params, different behaviour.
Is it the compiler, or _has_ there been a change in the animation clock
value formula?
- Mikael
Subject: Re: Same params, different values (Was: Long time, no see..)
Date: 25 Jan 2002 14:16:47
Message: <3c51af1f@news.povray.org>
> value formula?
As said, it is a precision issue.  It is irrelevant what 3.1 would output
because it is a precision issue and thus it really doesn't matter if
something changed or not.  Just get used to it.
    Thorsten
Date: 25 Jan 2002 14:43:49
Message: <3C51B6A2.5BDB3366@hotmail.com>
> Initial_Clock=0.2
> decimals)
I won't answer that question, but I do know a work-around.
I simply define the start clock at 0, the end clock at 100, the
start frame at 0, and the end frame at 100.  This gives me 24 frames
per second.  If don't want all 2401 frames, I used the subset frame
feature.
Very early in the scene code I have this:
#declare Frame=floor(clock*24+.5);
#declare Clock=Frame/24;  // note capitalization!
This gives me the exact frame number, and as near to the clock as
floating point can represent.
John
ICQ: 46085459
