POV-Ray : Newsgroups : povray.general : mesh in povray3.1/3.5 Server Time
23 Aug 2025 15:58:03 EDT (-0400)
  mesh in povray3.1/3.5 (Message 1 to 7 of 7)
Subject: mesh in povray3.1/3.5
Date: 4 Sep 2001 12:59:07
Message: <3B95089F.C85B19CE@gmx.de>
Hy,
I try 3dwin to convert raw-files to pov-meshes, but I do not understand
the result, but I need to do this because I want to write a programm
that converts special results into pov-files for vizualisation.
What's an "udo" ? Is it necessary in pov3.1/3.5 ?
There seem to be different numbers of vertex-vectors and normal-vectors.
Why this ? What are "normal_indices" and "face-indices" (what's the
number "0" in <0, 1, 2>, _0_ "? How is the format of the "mesh-file" in
3.5 ?
Thanks a lot
Subject: Re: mesh in povray3.1/3.5
Date: 4 Sep 2001 13:14:26
Message: <Xns9112C3B9B606Cseed7@povray.org>
in news:3B95089F.C85B19CE@gmx.de Ursula wrote:
> What's an "udo" ?
A file for use with the Moray modeller.
No.
> normal-vectors. Why this ?
If two or more vertex' have the same normal, the normal is written only
once
> "face-indices" (what's the number "0" in <0, 1, 2>, _0_ "?
You can see the combination normal_index + normal as a kind of array,
the normal index points to the normal that has to be used for a vertex.
The face_indices point to the three vertex_vectors to be used for a
triangle.
> How is the format of the "mesh-file" in 3.5 ?
3.5 supports the mesh and mesh2 format (the latter is the format you
exported to).
Ingo
Date: 4 Sep 2001 17:52:57
Message: <3B954D7E.E42491F3@gmx.de>
> once
That means: the normal is calculated for each triangle, then the normals of
all triangles sharing one vertice are averaged (--> normal of vertice),
then all normals are compared and all tsame normals are deleted...right ?
> triangle.
face-indices: <0, 1, 2>, x,     what does the x(=0) mean ?
face-indice: I do not really understand, what <2, 2, 2> means. Shouldn't be
one value enough (for example "normal vector nr. 4"). What does the vector
(normal vector x, normal vector y, normal vector z ?) mean ?
> exported to).
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
Date: 4 Sep 2001 18:10:02
Message: <3B955132.60203@xlstudio.com>
the averaging is not always done...it is named 'smoothing group' in 3DS
MAX. if your object is not smoothed, the normal of the vertices are the
same as the face's one.
0 is : the first vertex of the face is the vertex number 0 in the vertex
array
1 is: the second vertex of the face is the vertex number 1 in the vertex
array
                 David
Date: 4 Sep 2001 18:18:21
Message: <3B955372.F8B21CD4@gmx.de>
Thanks
but I had an error in my last posting..
this should be "normal_indices"...--->
normal-indice: I do not really understand, what <2, 2, 2> means. Shouldn't be
Sorry...
Date: 4 Sep 2001 18:22:00
Message: <3B955400.8050307@xlstudio.com>
If I understand well, the answer is:
the same as face-indices !
<2, 3, 4>
the normal of the first vertex of the face is the normal number 2 in the
normal_vectors array
the normal of the secone vertex of the face is the normal number 3 in
the normal_vectors array
Hopes it's the good answer this time !!
                David
Date: 5 Sep 2001 06:44:26
Message: <Xns9113819AFEC8Cseed7@povray.org>
> understand the result,
As my answer wasn't clear and there still is need for a piece on mesh2
for the docs, here is an attempt:
Mesh2
The mesh2 is a representation of a mesh that is much more like the
internal mesh representation than the standard mesh. As a result it
parses faster and it file size is smaller.
<0,0.5,0>___________<1,0.5,0>
<0,0,0>   <0.5,0,0>  <1,0,0>
We will write the mesh sketched above as a mesh2 object.
The mesh is made of 4 triangles, each with 3 vertices, many of
these vertices are shared among the triangles. This can be
used to optimise the mesh. First we will do it straight forward.
In mesh2 all the vertices are listed in a list named vertex_vectors{}.
A second list, face_indices{}, tells us how to put together three
rtices to create one triangle, by pointing to the index number of a
vertex. All lists in mesh2 are zero based, the number of the first
vertex is 0. The very first item in a list is the amount of vertices,
normals or uv_vectors it contains.
Lets go through the mesh above, we do it counter clockwise. The total
amount of vertices is 12 (4 triangle * 3 vertices)
mesh2 {
   vertex_vectors {
      12,
Now we can add the coordinates of the vertices of the first triangle:
mesh2 {
   vertex_vectors {
      12,
      <0,0,0>, <0.5,0,0>, <0.5,0.5,0>
Next step is to tell the mesh how the triangle should be created:
mesh2 {
   vertex_vectors {
      12,
   face_indices {
      4,
      <0,1,2>
There will be a total of 4 face_indices (4 triangles). The first
point of the first face points to the first vertex_vector (0: <0,0,0>),
the second to the second (1: <0.5,0,0>), etc...
The complete mesh:
mesh2 {
   vertex_vectors {
      12,
      <0.5,0,0>,   <1,0,0>  , <0.5,0.5,0>
      <1,0,0>,     <1,0.5,0>, <0.5,0.5,0>
      <0.5,0.5,0>, <0,0.5,0>, <0,0,0>
   face_indices {
      4,
      <0,1,2>
      <3,4,5>
      <6,7,8>
      <9,10,11>
   pigment {rgb 1}
As mentioned earlier, many vertices are shared by triangles. We can
optimise the mesh by removing all duplicate vertices but one. In the
example this reduces the amount from 12 to 6
mesh2 {
   vertex_vectors {
      6,
      /*as 1*/  <1,0,0>  , /*as 2*/
      /*as 3*/  <1,0.5,0>, /*as 2*/
      /*as 2*/  <0,0.5,0>, /*as 0*/
Next step is to rebuild the list of face_indices, as they now point
to indices in the vertex_vector{} list that don't exist anymore.
mesh2 {
   vertex_vectors {
      6,
   face_indices {
      4,
      <0,1,2>
      <1,3,2>
      <3,4,2>
      <2,5,0>
   pigment {rgb 1}
In case we want a smooth mesh, the same steps we did also apply to the
normals in a mesh. For each vertex there is a normal vector listed in
normal_vectors{}. If the number of normals equals the number of
vertices then the normal_indices{} list is optional and the indexes
from the face_indices{} list are used instead.
mesh2 {
   vertex_vectors {
      6,
      <0,0,0>,  <0.5,0,0>, <0.5,0.5,0>,
       <1,0,0>, <1,0.5,0>, <0,0.5,0>
   normal_vectors {
      6,
      <-1,-1,0>, <0,-1,0>, <0,0,1>
      /*as 1*/   <1,-1,0>, /*as 2*/
      /*as 3*/   <1,1,0>,  /*as 2*/
      /*as 2*/   <-1,1,0>  /*as 0*/
   face_indices {
      4,
      <0,1,2>
      <1,3,2>
      <3,4,2>
      <2,5,0>
   pigment {rgb 1}
When a mesh has a mix of smooth and flat triangles a list of
normal_indices{} has to be added, where each entry points to what
vertices a normal should be applied.
mesh2 {
   vertex_vectors {
      6,
   normal_vectors {
      6,
       <1,-1,0>, <1,1,0>, <-1,1,0>
   face_indices {
      4,
      <0,1,2>
      <1,3,2>
      <3,4,2>
      <2,5,0>
   normal_indices {
      2,
      <1,3,2>
      <3,4,2>
   pigment {rgb 1}
Ingo
