POV-Ray : Newsgroups : povray.general : More height_field texturing Server Time
11 Sep 2025 19:46:54 EDT (-0400)
  More height_field texturing (Message 1 to 10 of 10)
Subject: More height_field texturing
Date: 27 Jul 2001 06:38:16
Message: <3B61453C.50686B50@pp.htv.fi>
This time old boards. http://www.pp.htv.fi/kkivisal/woody.jpg
The bump map isn't just a channel/combination from the original. I had
to actually write down what I did because it wasn't simple. High-pass
filtering, histogram tweaking and layers in multiply mode were involved.
The final texture is, as before, a combination of multiple offset layers
in lighten mode. With aa it renders very slowly.
_____________
Kari Kivisalo
Subject: Re: More height_field texturing
Date: 27 Jul 2001 08:25:21
Message: <3b615db1@news.povray.org>
You really have to write a proper tutorial with pictures and screenshots
from whatever graphics program you're using. This is outstanding! :)
Date: 27 Jul 2001 18:21:39
Message: <3B61E9E7.47200E62@unforgettable.com>
The HF looks almost photographic. (Well, it WAS to start with, but
still, excellent job.)
-Xplo
Date: 27 Jul 2001 21:09:08
Message: <3b6210b3@news.povray.org>
Just curious:
  If you use a bump_mapped box instead of a heightfield, what is the render
speed difference and how does the image look like?
Date: 28 Jul 2001 02:49:54
Message: <3B626137.C600D2AC@pp.htv.fi>
From this angle and light source position the bump_map looks quite
good and when applied to a low polycount mesh would look just as good
as the HF. I could propably use mesh with bump_map for most of the
wooden board objects. I had to use bump_size 1000 which is quite odd
since all the other times I have used bump_maps bump_size higher
than 10 didn't do any good.
http://www.pp.htv.fi/kkivisal/bump.jpg
HF:                  17 min, 15 MB
bump_map:             5 min,  5 MB
bump_map, normal_on: 38 min,  5 MB (takes less blue color from the sky)
+am2 +a0.5
global_settings{
  assumed_gamma 1.0
  ini_option "+qr"
  radiosity{
    pretrace_start 0.04
    pretrace_end 0.02
    count 100
    recursion_limit 2
    nearest_count 2
    error_bound 1
    //normal on
_____________
Kari Kivisalo
Date: 28 Jul 2001 16:25:12
Message: <3b631fa8@news.povray.org>
I thought that it would look that good. Bump maps can sometimes give
surprisingly good results with a lot less overhead than a real surface
displacement.
Date: 30 Jul 2001 14:43:56
Message: <3b65aaec@news.povray.org>
It looks to me like you loose some detail when the bump_map method is used.
The HF image seems more realistic.  The grain seems to be deeper and more 3D
in the HF.  The differences are subtle, though.
Cris
"Kari Kivisalo" <kki### [at] pphtvfi> wrote in message
news:3B626137.C600D2AC@pp.htv.fi...
render
> HF:                  17 min, 15 MB
> +am2 +a0.5
> global_settings{
>   assumed_gamma 1.0
>   ini_option "+qr"
>   radiosity{
>     pretrace_start 0.04
>     pretrace_end 0.02
>     count 100
>     recursion_limit 2
>     nearest_count 2
>     error_bound 1
>     //normal on
> _____________
> Kari Kivisalo
Date: 30 Jul 2001 21:02:45
Message: <3b6603b4@news.povray.org>
Cris Williams <wor### [at] netscapenet> wrote:
: It looks to me like you loose some detail when the bump_map method is used.
: The HF image seems more realistic.  The grain seems to be deeper and more 3D
: in the HF.  The differences are subtle, though.
  Are you aware of what exactly does a bump_map do? Your text sounds a bit
like you may not be completely sure. I (or someone else) can explain it if
you want (it's rather interesting).
Date: 31 Jul 2001 05:30:37
Message: <3B667B2E.723691B2@gmx.de>
Apart from the obvious differences, it's also important to adapt normal
accuracy or heightfield resolution so results are comparable.
Date: 1 Aug 2001 15:24:03
Message: <3b685753$1@news.povray.org>
It is my understanding that the bump_map simulates the grain and cracks in
the wood on a flat surface using lighting tricks, and the height field
actually creates a true 3D surface (virtually, of course).  It seems as if
both methods should yield similar results, but the HF image just looked
sharper (more detailed) to me.  And I would be very happy to receive any
additional information, clarifications, observations, tips, etc. that you
(or anyone else) would care to send my way.  :-)
news:3b6603b4@news.povray.org...
used.
more 3D
