This time old boards. http://www.pp.htv.fi/kkivisal/woody.jpg
The bump map isn't just a channel/combination from the original. I had
to actually write down what I did because it wasn't simple. High-pass
filtering, histogram tweaking and layers in multiply mode were involved.
The final texture is, as before, a combination of multiple offset layers
in lighten mode. With aa it renders very slowly.
_____________
Kari Kivisalo
You really have to write a proper tutorial with pictures and screenshots
from whatever graphics program you're using. This is outstanding! :)
The HF looks almost photographic. (Well, it WAS to start with, but
still, excellent job.)
-Xplo
Just curious:
If you use a bump_mapped box instead of a heightfield, what is the render
speed difference and how does the image look like?
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
From this angle and light source position the bump_map looks quite
good and when applied to a low polycount mesh would look just as good
as the HF. I could propably use mesh with bump_map for most of the
wooden board objects. I had to use bump_size 1000 which is quite odd
since all the other times I have used bump_maps bump_size higher
than 10 didn't do any good.
http://www.pp.htv.fi/kkivisal/bump.jpg
HF: 17 min, 15 MB
bump_map: 5 min, 5 MB
bump_map, normal_on: 38 min, 5 MB (takes less blue color from the sky)
+am2 +a0.5
global_settings{
assumed_gamma 1.0
ini_option "+qr"
radiosity{
pretrace_start 0.04
pretrace_end 0.02
count 100
recursion_limit 2
nearest_count 2
error_bound 1
//normal on
_____________
Kari Kivisalo
I thought that it would look that good. Bump maps can sometimes give
surprisingly good results with a lot less overhead than a real surface
displacement.
It looks to me like you loose some detail when the bump_map method is used.
The HF image seems more realistic. The grain seems to be deeper and more 3D
in the HF. The differences are subtle, though.
Cris
"Kari Kivisalo" <kki### [at] pphtvfi> wrote in message
news:3B626137.C600D2AC@pp.htv.fi...
render
> HF: 17 min, 15 MB
> +am2 +a0.5
> global_settings{
> assumed_gamma 1.0
> ini_option "+qr"
> radiosity{
> pretrace_start 0.04
> pretrace_end 0.02
> count 100
> recursion_limit 2
> nearest_count 2
> error_bound 1
> //normal on
> _____________
> Kari Kivisalo
Cris Williams <wor### [at] netscapenet> wrote:
: It looks to me like you loose some detail when the bump_map method is used.
: The HF image seems more realistic. The grain seems to be deeper and more 3D
: in the HF. The differences are subtle, though.
Are you aware of what exactly does a bump_map do? Your text sounds a bit
like you may not be completely sure. I (or someone else) can explain it if
you want (it's rather interesting).
Apart from the obvious differences, it's also important to adapt normal
accuracy or heightfield resolution so results are comparable.
Christoph Hormann <chr### [at] gmxde>
It is my understanding that the bump_map simulates the grain and cracks in
the wood on a flat surface using lighting tricks, and the height field
actually creates a true 3D surface (virtually, of course). It seems as if
both methods should yield similar results, but the HF image just looked
sharper (more detailed) to me. And I would be very happy to receive any
additional information, clarifications, observations, tips, etc. that you
(or anyone else) would care to send my way. :-)
"Warp" <war### [at] tagpovrayorg> wrote in message
news:3b6603b4@news.povray.org...
used.
more 3D
