POV-Ray : Newsgroups : povray.general : Specular mapping Server Time
12 Sep 2025 03:05:44 EDT (-0400)
  Specular mapping (Message 1 to 5 of 5)
Subject: Specular mapping
Date: 17 Apr 2001 04:35:30
Message: <3ADC0116.A5F82888@snafu.de>
Does one of the inofficial versions or even POV 3.5 support specular
mapping (i.e. controlling the reflectivity of a surface through the grey
value of an image file, analogous to height fields)? Would be nice,
wouldn't it?
Subject: Re: Specular mapping
Date: 17 Apr 2001 07:41:45
Message: <3ADC2AB2.B73FCB9B@videotron.ca>
> wouldn't it?
Yes and no.  Reflection and specularity are controlled by the finish{}
block and you can't use an image_map in the finish{} block.  However,
you can define multiple textures that have different finishes and apply
a material_map.
Francois Labreque | Make you a deal, I'll show you mine if you show
    flabreque     | me yours.
   videotron.ca   |   - Pandora.
Date: 17 Apr 2001 09:59:08
Message: <3ADC4C2B.1139B9E6@gmx.de>
> wouldn't it?
That would be possible with a finish_map, similar to normal_map and
pigment_map - an often discussed suggestion.
It is not yet implemented, but it should be possible although it is
probably quite a lot of work.
Date: 18 Apr 2001 07:13:30
Message: <3ADD7773.494BE3A8@student.met.fu-berlin.de>
The specific instance, where this problem cropped up was: I wanted to create
a shiny metal sphere with pitted rusty areas scattered over the surface. I
used a layered texture for the shiny metal and rust respectively, but the
raytrace used only the finish values of the uppermost layer. So either I had
a dull metal or shiny rust, both of which was unsatisfying. If one could
control reflectivity with a grey image, one could overlay a corresponding
image-map and hopefully achieve much better results.
Date: 18 Apr 2001 08:39:03
Message: <3add8ae7@news.povray.org>
Jakob Tendel <jak### [at] studentmetfu-berlinde> wrote in message
news:3ADD7773.494BE3A8@student.met.fu-berlin.de...
create
had
The answer in that case would be to use a texture map instead of
layers
 bozo // or whatever
 texture_map {
  [0.0 texture {Metal}]
  [0.7 texture {Metal}]
  [0.8 texture {Rust}]
  [1.0 texture {Rust}]
That said, I'd also like to have a finish map.
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
