POV-Ray : Newsgroups : povray.general : subdivision surfaces and patches Server Time
24 Apr 2026 21:07:59 EDT (-0400)
  subdivision surfaces and patches (Message 1 to 8 of 8)
Subject: subdivision surfaces and patches
Date: 3 Mar 2001 06:25:53
Message: <3AA0D441.BE1898C4@skynet.be>
I keep reading everywhere about "subdivision surfaces", which are
currently the "bing thing" in modelling software.  However, from the
explanations I gathered, they seems not much different from bezier
patches.  Can someone clarify this ?
Fabien.
Subject: Re: subdivision surfaces and patches
Date: 4 Mar 2001 17:44:09
Message: <3aa2c539@news.povray.org>
I've done a tiny bit of reading into them and from what I gather subdivision
is a function (to be applied on) of polygons.  In the software that supports
it a shape is made (and at the last minute) a subdivision is applied, where
everything is smoothed.  Depending on the settings a cube for example would
look like a sphere.  Its ideal for faces etc as you can create a low poly
mesh and subdivide at the end (which hugely increases the number of
polygons).
...Its not suitable directly for POV-Ray though someone could write a
macro/prog that could subdivide a mesh...
Peter Cracknell (.com)
"Fabien Mosen" <fab### [at] skynetbe> wrote in message
news:3AA0D441.BE1898C4@skynet.be...
> Fabien.
Date: 4 Mar 2001 22:34:19
Message: <3AA3097D.F9D87D7F@pacbell.net>
> macro that could subdivide a mesh...
Someone already has :)
http://users4.50megs.com/enphilistor/sss.htm
Date: 5 Mar 2001 01:59:31
Message: <3AA339E1.8AF14932@hotmail.com>
> > a macro that could subdivide a mesh...
Unfortunately, it does not handle sharp edges or border edges (although
there is a way to work around that), and it is not terribly fast.
My modeler, which is currently in an ultra-slow rewrite, will be
supporting them.  However, that is waiting until I've got the
articulation
the way I want it (which will include a way to export a model as an .INC
file so that POV script code can animate it).
Once that work, the subdivision surface support will be added, then
UV-mapping.
John
Date: 5 Mar 2001 12:43:14
Message: <chrishuff-9A7656.12395305032001@news.povray.org>
In article <3aa2c539@news.povray.org>, "Peter Cracknell"
What do you mean? Subdivision could be very useful for POV-Ray...and I
don't see anything about it that isn't "suitable". You can't even use
the "POV is a renderer, not a modeller" argument with it, since
subdivision isn't a modeller specific feature.
> though someone could write a macro/prog that could subdivide a
> mesh...
As Ken mentioned, someone already has. ;-)
Christopher James Huff
Date: 7 Mar 2001 06:08:25
Message: <3aa616a9@news.povray.org>
> > mesh...
Fair point, but when I picture subdivision in action I picture a modeller
actually in control and view of a mesh which then gets 'subdivided', POV-Ray
could subdivide therefore, but in general the subdivision will be of
imported mesh's won't it anyway?  So yes it could be used, just not as
ideally as people would like.
Date: 10 Mar 2001 11:20:18
Message: <chrishuff-178997.11163210032001@news.povray.org>
In article <3aa616a9@news.povray.org>, "Peter Cracknell"
> POV-Ray could subdivide therefore, but in general the subdivision
> will be of imported mesh's won't it anyway?  So yes it could be used,
> just not as ideally as people would like.
I'm not sure I understand...subdivision would be used on meshes, height
fields, and other mesh-based objects, and a lot of meshes are generated
within scene files...and I don't see why it wouldn't be useful for
imported meshes. You could get away with much smaller files, and get
much lower RAM usage. (At the cost of some render time, though it could
also be more efficient, by only subdividing triangles when necessary.
And if you really want speed, you could subdivide the entire mesh before
rendering.)
In fact, to get the best out of subdivision surfaces, you *have* to have
it built into the renderer...there's no way around it.
Sure, you could also use a modeller, but then you are restricted to
externally generated meshes, huge files, and high RAM requirements.
Date: 10 Mar 2001 15:08:12
Message: <3aaa89ac@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-178997.11163210032001@news.povray.org...
modeller
> rendering.)
Obviously subdivision on imported meshes would be useful, but from what I've
read (and therefore reckon) is that the process of creating a mesh with
subdivision is a cycle of mesh editing, subdivision preview, mesh editing
repeat etc.  To do this with POV-Ray you would have to export subdivide
check, go back to your modeller edit and repeat.
To be fair I think my modeller bias is coming through so I'll probably leave
it there.  All in all subdivision is an extremely powerful tool that can
according to previews put many hours of work on organic objects to shame
very quickly.
