POV-Ray : Newsgroups : povray.general : Merge is not working as expected Server Time
12 Sep 2025 13:04:43 EDT (-0400)
  Merge is not working as expected (Message 1 to 5 of 5)
Subject: Merge is not working as expected
Date: 22 Jan 2001 11:54:44
Message: <3A6C65A3.7CCD5C6D@netvision.net.il>
I have a complicated shape, and it is critical to become one object,
instead of some objects, because it is glass. when I try it, it also
shows
internal divisions. how do I get rid of them?
for more details: image / sourcecode contact me by ICQ: 1515298
Subject: Re: Merge is not working as expected
Date: 22 Jan 2001 13:32:30
Message: <3A6C7CBC.D74D684F@gmx.de>
> shows
Without the code we can rarely tell what's wrong, so maybe post it to
povray.text.scene-files.
Date: 22 Jan 2001 16:21:03
Message: <chrishuff-78A218.16221022012001@news.povray.org>
In article <3A6C65A3.7CCD5C6D@netvision.net.il>, Eitan Tal
> shows internal divisions. how do I get rid of them?
Is WindowGlass supposed to be the merged shape? It is "union" in your
code...
I changed RawMaterial to a merge object and didn't see any lines, but
making WindowGlass a merge probably won't work as expected since most of
the pieces are meshes, and as far as POV is concerned, meshes don't have
a separate "inside" and "outside"...you might want to try MegaPOV, which
has a method of figuring out an "inside" for most meshes.
I did see a lighter colored area at the bottom, but it looks like a
reflection...could that be the "internal division" you were talking
about? Or was it the "gems" in the window?
Christopher James Huff
Date: 23 Jan 2001 12:26:17
Message: <3A6DBE84.448183F@netvision.net.il>
thank you for replying, but the code had changed since then.
should I post the update? I already changed it to merge,
and those lines (not the gems) still appear.
if you want to remove the gems, just comment all: object {BigGem? / Gem??
translate <...>}
under WindowGlass, or just change from object {WindowGlass .....} to:
object {RawMaterial scale <0.5,0.5,0.25> translate <-5.25,-6.0,Size>}
> code...
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 23 Jan 2001 14:38:59
Message: <3A6DDD8A.1A9E9CD5@netvision.net.il>
well, that was one dumb question!!!
I could simply fill it out with a most complicated object called "Box"!
union {
//  object {RawMaterial texture {G_Background}}
  box {<0,0,0>,<25,30,1> texture {G_Background}}
heheh, thank you for your help, anyways :-)
> shows
