POV-Ray : Newsgroups : povray.general : patch object? Server Time
11 Sep 2025 13:26:30 EDT (-0400)
  patch object? (Message 1 to 5 of 5)
Subject: patch object?
Date: 22 Dec 2000 19:10:36
Message: <3A43ED7C.C0C24218@ij.net>
I successfully did a
#declare thing = difference
	union { object list 1 }
	superellipsoid
	but
#declare another_thing = difference
	union { object list 2 }
	superellipsoid
	informs me that a patch object is not permitted and does not render
another_thing.
	A little trial and error should solve the general problem. Am I correct
in guessing a patch object is an old name for a CSG object?
Life's too short and death's too long
to take this all that seriously.
	-- The Iron Webmaster, 372
Subject: Re: patch object?
Date: 22 Dec 2000 19:30:31
Message: <3a43f227@news.povray.org>
> superellipsoid
> but
> superellipsoid
> another_thing.
There should be no problem using superellipsoids in CSG, as they are a
well-defined solid object (unlike triangles, polygons, bicubic patches,
discs, etc).  I have no problem rendering the difference of a union minus
another union and a superellipsoid.  Is it possible there is such a patch
object in your object list 2?  Perhaps some more detailed code might help
track the problem down...
Date: 22 Dec 2000 19:35:20
Message: <3A43F348.237D156F@ij.net>
> > superellipsoid
> > but
> > superellipsoid
> > another_thing.
	Literally a patch? No, attached is what it objects to being added.
Gore will spend the next for years training Democrats
how to punch holes in pieces of paper.
	-- The Iron Webmaster, 389
Download 'us-ascii' (2 KB)
Date: 22 Dec 2000 20:25:58
Message: <3a43ff26@news.povray.org>
Well, not quite literally a patch.  What you do have is light sources inside
the union, which is valid.  But how can POV-Ray determine the result of
differencing a light source from an object (OK - I guess one possibility
would be to use the negative of the light's colour...).  In this case,
however, POV-Ray light sources are defined with patch objects as those
elements which may not be used negatively in CSG, hence the error you are
getting.
The solution is to remove the light sources from the ship2 object, if you
want to be able to difference ship2 from other objects.  If you want the
light sources to be where they would be in the differenced result, simply
declare and use them separately:
   #declare ship2 = union {...}
   #declare ship2lights = union {light_source ... }
   union {
      difference {
         object {object1}
         object {ship2 translate x*4}
         superellipsoid {...}
      object {ship2lights translate x*4}
Date: 24 Dec 2000 04:39:24
Message: <3A45C44B.7B6C314F@ij.net>
> getting.
>    union {
>       difference {
>          object {object1}
	I will give it a try, thanks. The lights are not the issue rather the
spheres are as they go through an object composed of text. So I could
care in the least about them. I just want a subtraction and I realize
the problem with creating informative error messages.
	Worst case, see you on ITRC animations. :)
It you drink too much whiskey you are likely
to shoot at liberals and miss.
	-- The Iron Webmaster, 261
