POV-Ray : Newsgroups : povray.general : convert from dxf! Server Time
25 Aug 2025 23:21:46 EDT (-0400)
  convert from dxf! (Message 1 to 4 of 4)
Subject: convert from dxf!
Date: 12 Dec 2000 17:58:11
Message: <3A36AE2F.E605A1DC@gmx.at>
Hallo!
I have a problem. A friend of mine did some drawings in Autocad 2000
and he wants me to render it in povray
does anyone out there know how to convert these dxf or dwg files to
povray.
Because all my converters (like croosroads) can't read the files.
Maybe first converting it to some different file like vrml and then to
povray.
    ALIL
Subject: Re: convert from dxf!
Date: 12 Dec 2000 23:15:57
Message: <3A36F8E3.8B63A97C@pacbell.net>
Alois Zoitl wrote:
> Hallo!
> povray.
> povray.
The Autocad guys probably changed the dxf format, again. You could
try having your friend resave the .dwg file as an earlier version
such as r14 then export to dxf and see if that works. If it doesn't
you may try using 3DWin which is newer than crossroads. I have r14
and have never had any problems with the dxf export but I have no
idea how Acad 2000 operates or if saving to an earlier version will
effect the dxf export type. It's worth at try anyway. Another
possiblity would be to resave the .dwg file to r14 and then find
someone with r14 to export to .dxf. A little round about but it
should work.
3DWin - http://www.stmuc.com/thbaier/
Date: 14 Dec 2000 09:01:14
Message: <3A38D2B3.C44948AA@gmx.at>
I can't start 3DWin.
When I double-click on the exe nothing happens.
Ken wrote:
> Alois Zoitl wrote:
> > Hallo!
> > povray.
> > povray.
> should work.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 16 Dec 2000 05:32:29
Message: <qvgm3t0kdeltir0a98skv7bklgn0pi5dj7@4ax.com>
  The Readme.txt included with 3DWin says this, along with other
information:
"Installation:
1. Start 3DWin_Setup.exe.
2. Start Demo_Reg_Setup.exe and install into the 3DWin installation
directory.
3. Double Click on "3DWin.reg"
  If the above procedure isn't followed, nothing happens when you try to
open 3DWin.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
