POV-Ray : Newsgroups : povray.general : Forgot to mention, faricy.net is back up Server Time
17 Jul 2026 22:36:57 EDT (-0400)
  Forgot to mention, faricy.net is back up (Message 1 to 9 of 9)
Subject: Forgot to mention, faricy.net is back up
Date: 14 Nov 2000 00:57:08
Message: <3A10D3D2.FE1AB2A1@faricy.net>
Been for about a week. So the 1% of you who visit my site...
Subject: Re: Forgot to mention, faricy.net is back up
Date: 14 Nov 2000 04:18:30
Message: <3A1103B5.B185A6EB@hotmail.com>
It seems that
http://davidf.faricy.net/adjust.gif & .html
http://davidf.faricy.net/polywad/poly.html
don't exist?
Bye
Pabs
http://zip.to/pabs3 -> http://www.crosswinds.net/~pabs3
Date: 17 Nov 2000 18:16:21
Message: <3A15BBD8.9CBFDB51@faricy.net>
Pabs wrote:
> It seems that
Fixed, URL should have had images/adjust.gif
> don't exist?
That was just my laziness. It's all uploaded now.
Date: 17 Nov 2000 22:33:46
Message: <3A15F8EA.985E2E05@hotmail.com>
David Fontaine wrote:
> Pabs wrote:
> > It seems that
in http://davidf.faricy.net/raygall.html there is a link to
http://davidf.faricy.net/adjust.html at the top of the page.
It also needs to be adjusted to images/adjust.gif
Also do you have a method for shearing along a plane defined by two axes
in 3D space?
eg
normal in same plane
^    axis 2
| /  sheared by this angle
|/------------------------------------> axis 1
Bye
Pabs
Date: 17 Nov 2000 23:42:02
Message: <3A16082F.F97C526E@faricy.net>
Doh!! Okay.
> in 3D space?
> eg
> ^    axis 2
Hmm... that might be my next macro then. :)
Axis 3 is perpendicular to both axis 1 and whatever axis is perpendicular to
1 and 2...
I orient axis 3 along z and axis 1 along x...
Then I shear z for x by a factor of tan(angle between 1 and 2)...
Then I reorient. :)
Date: 18 Nov 2000 05:12:32
Message: <3A16561F.6008DF36@kivisalo.net>
The link to this image is _adjust_your_gamma_, which is a bit misleading.
The image is for adjusting monitor brightness and contrast to optimise
the available dynamic range in current lighting conditions. It's not
related in any way to adjusting or estimating monitor gamma.
Monitor gamma can be adjusted in the display adapter software or
OS utility. The gamma.gif at povray.org helps to estimate the gamma.
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 18 Nov 2000 16:13:25
Message: <3A16F088.9E0B945E@faricy.net>
Bah! Fine, I'll fix it later.
Date: 20 Nov 2000 00:48:01
Message: <3A18BB61.CC7DFA7E@hotmail.com>
> > in 3D space?
> > eg
> > ^    axis 2
> 1 and 2...
and y along the normal
> Then I reorient. :)
Sounds about right :)
Bye
Pabs
Date: 21 Nov 2000 00:42:58
Message: <3A1A0AF6.A37DAEF@faricy.net>
> > 1 and 2...
Happens automatically...
