POV-Ray : Newsgroups : povray.general : modest problem Server Time
25 Mar 2026 19:58:28 EDT (-0400)
  modest problem (Message 1 to 10 of 20)
Subject: modest problem
Date: 2 Nov 2000 16:25:16
Message: <3A01DBB1.F6A1469D@ij.net>
I've had this before and faked it. The attached file has the only light
source at +Z and a camera at -Z. I can see the unilluminated side of the
sphere. Note all sources of reflections are commented out.
Always go through life a little bit hungry.
You never know when you might meet something edible.
	-- The Iron Webmaster, 139
Download 'us-ascii' (1 KB)
Subject: Re: modest problem
Date: 2 Nov 2000 16:43:46
Message: <chrishuff-71E179.16465202112000@news.povray.org>
In article <3A01DBB1.F6A1469D@ij.net>, Matt Giwer <jul### [at] ijnet>
Your indentation style is horrible. :-)
Also, "scale 1" doesn't do anything. And you use an image map...I
replaced it with "wrinkles color_map {[0 rgb 0][1 rgb 1]}" so I could
render the file.
I assume the problem is that you don't want to see the dark side of the
sphere? Give the sphere an ambient of 0. It is currently at 0.5, which
means the minimum illumination will be 0.5. You could also specify
ambient_light 0 in global_settings, this sets the ambient value of
everything in the scene to 0.
Christopher James Huff
Date: 2 Nov 2000 16:50:26
Message: <3A01E139.57CD995D@aol.com>
> finish {ambient .5}
Can't render it as you have it lacking the image map, but perhaps this is the
problem?
Date: 2 Nov 2000 16:51:55
Message: <3A01E1F5.B1D0A04@ij.net>
	Guilty as charged. Noodling around trying to correctly solve this
problem correctly.
> render the file.
	Playing with ambient is one of the ways of faking it. If there is no
illumination, why should anything be visible regardless of the ambient?
I just want things to behave according to the scene description.
	I have this image of the light reflecting off of the camera ...:)
Date: 2 Nov 2000 16:53:56
Message: <3A01E271.9B5205C6@ij.net>
MikeH wrote:
> > finish {ambient .5}
> problem?
	Stick in any image you have laying around. Put in a texture.
	How is it possible to see what is not illuminated?
Date: 2 Nov 2000 18:14:36
Message: <3a01f55c@news.povray.org>
"Matt Giwer" <jul### [at] ijnet> wrote in message
news:3A0### [at] ijnet...
... but that's the whole point of ambient. Its primary use is as a fake
radiosity - giving objects a visible colour when otherwise they would be in
pure shadow.
Time to rtfm?
Date: 2 Nov 2000 18:24:06
Message: <chrishuff-6D4B86.18271202112000@news.povray.org>
But there *is* illumination. You specified a 50% gray ambient lighting.
Think of it this way: there is a global ambient light source which
defaults to white. It has no direction or location, so it illuminates
the scene evenly, is not shadowed or shaded. The color of this light is
specified by the "ambient_light" keyword in global_settings. Textures
have an "ambient" component which specifies how much they are affected
by this ambient light, the two colors are multiplied together and the
result added to the illumination. The ambient_light keyword gives you a
way to globally change the ambient values, and the ambient finish
attribute allows you to control it on a per-texture basis.
Since the default is "ambient_light rgb < 1, 1, 1>", and you specified
ambient 0.5(which is the same as "ambient rgb < 0.5, 0.5, 0.5>"), what
you did is tell POV to add rgb < 0.5, 0.5, 0.5> to the illumination of
each point on the sphere.
Actually, the "ambient_light" keyword isn't even necessary, you can do
something like this:
#declare AmbLgt = color rgb < 1, 1, 1>;
    finish {
        ambient AmbLgt*0.5
However, variables may not have existed when ambient_light was added.
It is, I assure you. :-)
More like a fill light at the camera position that doesn't leave shadows
and isn't affected by the contours of the surfaces(no shading). Ambient
is actually intended as a quick-and-dirty way to simulate diffuse
illumination, light bouncing off of other objects, but radiosity does a
much better job of that. Since ambient light can be specified per-object
and is added to the ordinary illumination, it is often used to make
glowing objects.
Date: 2 Nov 2000 18:29:50
Message: <3A01F8AA.56E1D705@faricy.net>
Tom Melly wrote:
> Time to rtfm?
I think so...
Date: 2 Nov 2000 19:49:56
Message: <3A020BB2.1A7CFED7@ij.net>
> pure shadow.
> Time to rtfm?
	Oh. Guess so.
	It has always worked as though it were the purpose to make it seen
without a particular finish. Why read when it worked exactly as
expected? No excuse, Sir!
Here is the rule and read it clear, only the US government can
invoke god and no one else can.
	-- The Iron Webmaster, 167
Date: 2 Nov 2000 20:01:41
Message: <3A020F47.B09AA20D@hotmail.com>
Thats the Allman style
try an even worse style - Whitesmiths
or the tuxracer src for some v bad indentation
personally I like the K&R style
see  http://www.tuxedo.org/~esr/jargon/html/entry/indent-style.html for more.
Bye
Pabs
