POV-Ray : Newsgroups : povray.general : Optimizing CSG Server Time
28 Oct 2024 11:19:46 EDT (-0400)
  Optimizing CSG (Message 1 to 6 of 6)
Subject: Optimizing CSG
Date: 18 Aug 2000 09:45:44
Message: <399D3D0B.8BD1A06C@xs4all.nl>
I have an origami-object that is made with CSG. Every fold is a new sit of
clipping and rotating. I have made some aeroplanes this way and it works out
fine. The trouble is, they're terribly slow to render. I understand that since
each new manipulation cuts the object up in more parts the problem is here
somewhere. I have tried optimizing it but nothing seems to make a significant
difference. I think I'm overlooking something obvious, perhaps it would help if
I did something with bounding boxes but all the things I have tried didn't work
or at least not very well.
I have posted a scene file to binaries.scene-files hoping someone will check it
out and be able to make it work faster. I've commented out some light_sources
and that helps but not really very much.
Remco
Subject: Re: Optimizing CSG
Date: 18 Aug 2000 11:20:56
Message: <399D5491.EB373577@insectes.net>
I rendered the scene file, enough to see the folded shape in the middle anyway. I
see you're using very thin boxes, how about using polygons and/or triangles?
Date: 18 Aug 2000 11:27:47
Message: <399D5602.9BA8C132@atos-group.com>
Well, from a quick render and some reading of your code,
it seems you are multiplying the basic object, a union of two boxes,
inside more and more complex construct.
I noticed a lot of clipped_by and I'm pretty sure that you
may instead use an intersection , thus reducing the bounding boxes.
On the same way, given the pyramidal explosion of your construct,
I wonder if disabling the bounding box would not give some speed-up.
(with 8 stages using two objects, you have about 2^8 (=256) basic objects,
i.e. 512 real box and the whole hierarchy of bounding box:
512+256+128+64+32+16+8+4+2+1 = 1023 !!
Given the compactness of the object, when a ray it one box, it may
as well hit the others... so you probably end up doing 1023+512 box intersection
per ray. (may be not, but I do not remember that clipped_by was also
taken into account for the bounding box [source is too far away for me at this
time])
You could also accelerate the rendering of the background by
doing an intersection with a box in which you know your origami is in
(side effect on the top bounding box: it is smaller; The box should
of course never show itself, as the origami is smaller and inside.)
I let you do the experiments.
Date: 18 Aug 2000 15:28:36
Message: <399D8DC3.DF3088BB@xs4all.nl>
> time])
Thanks for your reply, also to Libellule.
I considered using triangles or a mesh, which would have been much faster were
it not that I want the front and back of the sheet to have a different pigment.
In fact, in the original object I use image_maps. That doesn't affect the speed
much.
I also thought about using triangles and alternating the pigment depending on
which side is face towards the camera but I couldn't figure out how to do that
in POV.
Two thin boxes seemed like the easiest way.
As J. Grimbert noted this means there are going to be a lot of parts (and this
isn't even the most complicated model) with their bounding boxes. I thought I
had tried everything, also experimented with bounding boxes with no effect.
However, after sending the message, I thought I'd try it once again and put the
whole object in one single bounding box. This way the largest part of the
background is rendered much faster. I had tried this before but didn't know how
large a box I should take so to be safe I used a large bounding box. Far too
large, so the effect was nil. Now it occured to me that the site of the sheet
you start with can be used to get a tight(er) fitting bounding box. It renders 3
times faster now, which still is rather slow. So if there's anything else I've
missed I'd like to know.
I didn't understand the suggestion about the intersection for the background.
Remco
Date: 19 Aug 2000 09:17:22
Message: <mGfiMCAnqkn5EwgU@econym.demon.co.uk>
>much.
>in POV.
Err, at the moment your object is actually the same colour on both
sides. I think you meant to write
  #declare origami=
  union{
    object{front}
    object{back}
instead of
  #declare origami=object{front}
  union{
    object{front}
    object{back}
In this version "origami" is #declared to be the red box, and then a
copy of the bi-coloured box is rendered.
It's possible to have meshes (or anything else) with different textures
on each side in MegaPOV, by using the "interior_texture" keyword.
>Regards,
>Remco
Mike Williams
Gentleman of Leisure
Date: 19 Aug 2000 09:56:39
Message: <399E916F.333D1264@xs4all.nl>
> >much.
> >in POV.
>   #declare origami=
>   union{
>     object{front}
>     object{back}
> instead of
>   union{
>     object{front}
>     object{back}
Yes, you're right. That was a remainder of my experiments.
I haven't tried that, I wonder if it would make a big difference, with the total
amount of sections being the same. I'll see if I can figure out how to follow
your suggestion. Thanks.
> Mike Williams
Remco
