POV-Ray : Newsgroups : povray.general : Image Map Tutorial? Server Time
26 Apr 2026 07:03:56 EDT (-0400)
  Image Map Tutorial? (Message 1 to 10 of 12)
Subject: Image Map Tutorial?
Date: 3 Apr 2000 10:06:18
Message: <38e8a55a$1@news.povray.org>
Is there any general image map tutorial / general strategies on placing
image maps on complicated objects?  I've found it quite difficult making a
transparent .gif, finding the transparent color so the base texture can be
seen, and then scaling and placing the image on the object to make this
"decal" effect look plausible.
Thanks,
-Chris-
Subject: Re: Image Map Tutorial?
Date: 3 Apr 2000 14:10:21
Message: <38E8DE4B.A17DD9EA@faricy.net>
Chris Spencer wrote:
> Hi,
Make an orthographic render perpendicular to the image map and use it as a
base to edit the map.
___     _______________________________________________
 | \     |_          <dav### [at] faricynet> <ICQ 55354965>
 |_/avid |ontaine        http://www.faricy.net/~davidf/
"The only difference between me and a madman is that I'm not mad." -Dali
Date: 4 Apr 2000 08:49:49
Message: <38e9e4ed$1@news.povray.org>
Thanks for the reply, but you lost me.  I searched the POV help file but  I
couldn't find a good description or implementation of an orthographic
camera.  How would this help placing an image map?
-Chris-
> > Hi,
a
be
Date: 4 Apr 2000 14:08:40
Message: <chrishuff_99-7BE489.13110604042000@news.povray.org>
In article <38e9e4ed$1@news.povray.org>, "Chris Spencer"
> I couldn't find a good description or implementation of an
> orthographic camera.
Section 4.4.2 "Types of Projection", in the manual. Not a real great
explanation, though. Also look at section 2.4.4.1 "Understanding The
Concept of Splines". That part of the tutorial has a short "spline
workshop" scene that includes an example of the orthographic camera.
And check out this demo scene:
POV-Ray:Scenes:camera:camera1b.pov
It doesn't really help in placing one, just in designing one and placing
the details. Well, it might help get the alignment right...
The idea is you render an image with the orthographic camera, and then
use that image to place the details on the image map. The image map is
projected like the orthographic camera by default, so you just have to
scale/translate it to the same position and size as the camera was.
To make a decal, take a view along one axis with the orthographic
camera, "paint" on the rendered image, making the overlay, and then
apply that image as the decal using an image_map.
Christopher James Huff - Personal e-mail: chr### [at] yahoocom
Date: 4 Apr 2000 23:27:16
Message: <38EAB254.324C5E88@faricy.net>
Chris, I never really understood this part: am I correct an assuming that the
width of the view at the look_at point is the same with an orthographic
camera? If not, how do you determine the width of the view?
Date: 5 Apr 2000 05:12:04
Message: <38EB080A.50CDBDC4@nanterre.marelli.fr>
Hi David.
I think that width and height of the view are determined by the length
of right and up vectors of the camera.
Bouf.
Date: 5 Apr 2000 05:19:04
Message: <38eb0508@news.povray.org>
news:38EAB254.324C5E88@faricy.net...
I just happen to be answering before Chris since I'm online at this time of
morning, so excuse me if I'm interrupting please.
'up' and 'right' define the dimensions of the orthographic view window, centered
on 'look_at' of course.
The good thing about it is you can use what will be your image map resolution
for the values, as in up 300*y right 400*x.
Watch out when positioning the camera so as not to put it right near <0,0,0> as
someone had pointed out a while back here at the newsgroups.  Seems that the
orthographic camera can break down at too small a range from the look_at.  You
should be able to safely put the camera at any typical distance (for
simplicity -10*z and looking to <0,0,0>).
This makes for a kind of hollow bar which runs a length away from the camera yet
stays the same width and height for the entire distance.
Date: 6 Apr 2000 08:11:45
Message: <38ec7f01@news.povray.org>
Ok, I understand everything up until the the part when I have to
scale/translate the image to the position corresponding to the ortho
camera's position.  Thanks for the help with the camera.
Here's my code, the maped texture is labeled ImagemapTex:
background { color <1.000,1.000,1.000> }
// lights
light_source {   // Light1
  <200.000, 200.000, 200.000>
  color rgb <1.000, 1.000, 1.000>
light_source {   // Light2
  <-10.000, 8.000, 100.000>
// camera, side view
  #declare Angle = 30;
  camera {  //  Camera SpotCam001
  // orthographic
  location  < 0,  50, 0>
  sky       < 0,  0,  1> // Use right handed-system
  up        < 0,  0,  1> //< 0,  0,  1*25> //  For orthographic camera
  right     <4/3, 0.0, 0.0> //<4/3*25, 0.0, 0.0> //       For orthographic
camera
  angle         Angle
  look_at   < 0,  0,  0>
// textures
#declare ImagemapTex =
  texture{
      color Blue
    finish{
      ambient 0
  texture{
    pigment{
      image_map{
        png "decal_rombot_nametag01.png" // the file to read
(iff/gif/tga/png/sys)
        map_type 0 // 0=planar, 1=spherical, 2=cylindrical, 5=torus
        interpolate 0 // 0=none, 1=linear, 2=bilinear, 4=normalized distance
        // [filter N V] // N=all or color index # (0...N), V= value
(0.0...1.0)
        // [transmit N V] // N=all or color index # (0...N), V= value
(0.0...1.0)
        // [use_color | use_index]
        once
        // image_map
        // rotate <0,50,0> translate <0,50,0> ??? <--- I think this is where
I need help.
// objects
plane
  z, // <X Y Z> unit surface normal, vector points "away from surface"
  -10.0 // distance from the origin in the direction of the surface normal
  texture { pigment { checker color rgb <1.0, 1.0, 1.0> color rgb <0.0, 0.0,
0.0>  }  }
sphere
  <0, 0, 0> // center of sphere <X Y Z>
  10       // radius of sphere
  scale <1, 1, .75>
  texture {ImagemapTex}
Date: 6 Apr 2000 18:29:20
Message: <38ed0fc0@news.povray.org>
Oh wow, confusing me  :-)
Anyway, all you're really needing is to center the image first then scale it to
the size you have set in the camera.  Since the image starts off as 1 unit
square with lower left corner at <0,0,0> then you want to do 'translate
<-0.5,-0.5,0>'  and then  'scale <25,25,1>' and finally 'rotate 90*x' for the
camera to see it.
That should be it I think.   That plane {z,-10 is not going to show up though.
The camera will be looking parallel along it and therefore see nothing of it.
If I'm understanding this right then you are trying to get a spherical image
which is actually mapped on as planar to be seen orthographically which then no
longer has any spherical quality.  Which is why I got confused.  Anyone else?
Date: 6 Apr 2000 22:35:33
Message: <38ed4975@news.povray.org>
it to
the
> camera to see it.
though.
it.
That worked out fine.  The checkered plane was there for a later 3D view,
when the ortho camera was commented out.
I tried mapping the image as a spherical type, but it became incredibly
distorted.  Planar seemed the best option and didn't distort much.
Thanks again,
-Chris-
then no
else?
