POV-Ray : Newsgroups : povray.general : How can you make a mesh object solid? Server Time
21 Jun 2026 20:31:39 EDT (-0400)
  How can you make a mesh object solid? (Message 1 to 4 of 4)
Subject: How can you make a mesh object solid?
Date: 25 Mar 2000 14:02:02
Message: <38dd0d2a@news.povray.org>
I have a somewhat complex mesh object (an Elefont mesh to create text.)  If
I use another object (say a sphere) to create a difference between the two
objects then the mesh "shows its insides" and appears hollow.   Is there
some method that can be done with a mesh object to make it solid?  I tried
using a difference with a box and then inversing it (hoping that somehow it
would fill the mesh) but that doen't work.  I have been using Elefont to
create font meshes and I really need someway to solidify them.  If I use
standard TTF text object in Povray that object IS solid but it does not have
any way to bevel the edges.   Help!
Subject: Re: How can you make a mesh object solid?
Date: 25 Mar 2000 14:47:32
Message: <38DD173D.A35CBF6D@pacbell.net>
The official version of POV-Ray will not allow you to use meshes in
CSG operations. Sometimes they will try to work but the results are
unpredictable (as you have witnessed) and most of the time will not
work at all. The alternative is to use the patched version of POV-Ray
called MegaPov. It will allow you to use meshes in CSG operations if
it is a well behaved mesh - i.e. the suface normals of the triangles
in the mesh are unified and the mesh object has no holes in it. I
have noticed in the past that Elefont's meshes are not always well
behaved but you may get lucky.
MegaPov - http://nathan.kopp.com/patched.htm
Date: 26 Mar 2000 16:12:22
Message: <38de7d36@news.povray.org>
BTW: What is Elefont ?? (from your words i can imagine it is a
3D-fontgenerator)
      where can I get it ??
Newer heard of that thing
Jan Walzer <wal### [at] informatikuni-hallede>
Date: 26 Mar 2000 16:18:25
Message: <38DE7D07.86F3C6E5@pacbell.net>
> 3D-fontgenerator)
It is a program that can produce 3D objects from ttf fonts. It has
several features that will allow you to manipulate the final shape
and extrusion of the font object before export.
Also check out Spiralizer while you are there. It is an interesting
little utility.
Elefont and Spiralizer can be found here - http://www.armanisoft.ch/
