POV-Ray : Newsgroups : povray.general : AutoBanking Server Time
27 May 2026 07:44:33 EDT (-0400)
  AutoBanking (Message 1 to 10 of 10)
Subject: AutoBanking
Date: 31 Mar 2000 17:37:36
Message: <38E52808.D80EB53F@spiritone.com>
I am continuing to develop my bezier spline macros, but I am currently
having a problem with banking the object to have a realistic motion
along the curve. Does anyonw have any suggestions?
Josh English
eng### [at] spiritonecom
Subject: Re: AutoBanking
Date: 31 Mar 2000 18:50:12
Message: <pTjlONnNNyI5gSblqK=WyaycOPwn@4ax.com>
On Fri, 31 Mar 2000 14:34:48 -0800, Josh English
Take the second derivative of the equation of motion you are using and
use (scaled to a proper range of course) to rotate the object around
the axis formed by the first derivative of aforementioned function. I
hope I know what I am talking about at this time of night :)
Peter Popov ICQ : 15002700
Date: 31 Mar 2000 22:59:36
Message: <38E576E8.58DBD751@erols.com>
Close enough for government work.  Take the 2nd derivative of the motion,
which will be a vector inward of the curve.  From this subtract a vector
representing the force of gravity; since gravity is down, the result will
be mostly up, tilted by the amount of acceleration.  Normalize the
result.  That's the new "up" vector for the object.
Since a bezier spline uses the equation
P(u)=(1-u)^3 * P_0 + 3*u*(1-u)^2 * P_1 + 3*u^2*(1-u) * P_2 + u^3 * P_3
The first derivative ought to be
dP/du= (-3+6*u-3*u^2) * P_0 + (3-12*u+9*u^2) * P_1
  +(6*u-3*u^2)*P_2 + 3*u^2 * P_3
and the second ought to be
d^2P/du^2 = (6-6*u)* P_0 + (-12+18*u) * P_1 + (6-6*u) * P_2 + 6*u * P_3
Now to get the object placed and banked, calculate the position along
the spline, and the first two derivatives, and place them in the variables
Location, Velocity, and Acceleration.
The velocity becomes your object's forward vector:
#local VecF=vnormalize(Velocity);
From the acceleration, you require only the portion that is perpendicular
to the direction of motion:
#local VecA=Accleration-VecF*vdot(VecF,Accleration);
From this, subtract the vector for gravity and normalize the result:
#local Gravity=<0,-9.8,0>; // gravity is down at 9.8 m/sec^2
#local VecU=vnormalize(VecA-Gravity);
Then you get your right-hand vector for a full transformation:
#local VecR=vnormalize(vcross(VecU,VecF));
And then recalculate the up vector (in case the forward motion is
going up or down a slope):
#local VecU=vnormalize(vcross(VecF,VecR));
and then invoke it wall with a matrix transform.  If your object
is modeled so that z is forward and y is up,
matrix < VecR.x, VecR.y, VecR.z,
         VecU.x, VecU.y, VecU.z,
         VecF.x, VecF.y, VecF.z,
         Location.X,Location.Y,Location.Z >
Hope this helps (and isn't full of bugs),
John
ICQ: 46085459
Date: 1 Apr 2000 02:14:40
Message: <E6HlOJSdA6LRZqisTH=feHnbpsqD@4ax.com>
On Fri, 31 Mar 2000 23:11:20 -0500, John VanSickle
What do you mean, 'gravity' :) I was talking with spaceships in mind.
Hope your math works, I'll try it as well.
Date: 1 Apr 2000 12:29:23
Message: <38E634B5.412D7425@erols.com>
A moving vehicle needs to bank into turns only if there is an upward force
involved in the turning.  This is indeed the case with airplanes and cars.
Whether it is true for a spaceship depends on how the spaceship is designed.
John
ICQ: 46085459
Date: 1 Apr 2000 14:03:46
Message: <slrn8eces5.7j3.hjp-usenet@teal.h.hjp.at>
Spaceships don't bank (unless they are in a movie :-)
	hp
|_|_) | Sysadmin WSR     \ Durchbruch in der Bionik, und Microsoft geht
| |   | hjp### [at] wsracat     \ Pleite und Gardena bringt organische PC's
__/   | http://www.hjp.at/ \ auf den Markt.           -- Stefan Schaefer
Date: 1 Apr 2000 14:29:40
Message: <P03mOB6Q1V6pxDEAoifGtvw+AXO7@4ax.com>
On Sat, 1 Apr 2000 20:10:13 +0200, hjp### [at] SiKituwsracat (Peter
The ones I've designed as a kid do. And they had to, because the
design of the thrusters was done so. I agree there's no need to bank
in zero gravity, but it sometimes helps :)
Date: 2 Apr 2000 09:47:32
Message: <38e74f74@news.povray.org>
"Peter Popov" <pet### [at] usanet> wrote in message
news:P03mOB6Q1V6pxDEAoifGtvw+AXO7@4ax.com...
Why is there no need to bank in no gravity?
The pilots will be pulled to the side when turning if they don't bank!
The centrifugal force still works in no gravity.
Greetings,
Rune
Updated March 15: http://rsj.mobilixnet.dk
Containing 3D images, stereograms, tutorials,
The POV Desktop Theme, 350+ raytracing jokes,
miscellaneous other things, and a lot of fun!
Date: 2 Apr 2000 12:02:39
Message: <slrn8eeptf.e85.hjp-usenet@teal.h.hjp.at>
Hmm, the ships I designed when I was a kid had their thrusters at the
back, just like a plane or the ships in Star Wars (I was ten years old
when that came out).
won't fly a curve, with the axis of the ship tangential to the curve.
the direction you are going now and the opposite of the direction you
want to go. Then you will fire your thrusters until you are flying in
that it points in the "right" direction.
Apart from the spins at the start and the end of the maneuver, the
g-force will always point straight to the back of the ship.
Of course you may have designed your ships differently.
	hp
Date: 3 Apr 2000 11:15:19
Message: <38E8B5A3.DB2E7518@spiritone.com>
Thank you for those formulas. Even though my University says I've passed two
terms of Calculus, I've had some difficulty differentiating the bezier spline
formula myself.
Josh
> John
> ICQ: 46085459
Josh English
