POV-Ray : Newsgroups : povray.general : a wet height field Server Time
26 Apr 2026 14:16:26 EDT (-0400)
  a wet height field (Message 1 to 7 of 7)
Subject: a wet height field
Date: 10 Feb 2000 15:39:59
Message: <38A322D5.E454418@pilot.msu.edu>
Does anyone have any ideas on how to make a height field looks like it
has standing water on it?  I took an output from leveller that went
throught the erode filter.  I want the ruts to be filled with water.  I
can't use a waterline because all of the ruts are at different heights.
I tried using two height fields but I am unsure on how exactly to do
it.  For example I want water to be on the bottom of a crater and I want
water running down the side of the crater.  Has anyone done this?  I
have a hard time explaining myself so hopefully someone will understand.
Subject: Re: a wet height field
Date: 10 Feb 2000 17:01:43
Message: <38A335A1.769B00AD@istar.ca>
What about making two heightfields, one with ruts and one without, but
otherwise identical. By translating the smooth one down a bit, it will only
be visible in the ruts of the upper field.
Not an ideal situation, but it may work...
Date: 10 Feb 2000 17:10:32
Message: <xzOjOOwlEK8gP47OlgswqsOZViRh@4ax.com>
On Thu, 10 Feb 2000 15:43:01 -0500, Nick Portelli
Make a height field in Leveller and save it. Erode it and save it
under a different name. Now, in your scene, overlap them (move the
non-eroded one a little down, say 0.0001*y). Give the eroded HF a
ground or rock texture and the smooth one a water texture. This should
do the trick.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 10 Feb 2000 17:28:31
Message: <=DqjOH2WVZ4G=OmgIZ8gtdsxlpn7@4ax.com>
On Fri, 11 Feb 2000 00:08:54 +0200, Peter Popov <pet### [at] usanet>
>do the trick.
Oh man, gotta love off-line reading! Simon has already answered in the
exact same way. D'oh.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 10 Feb 2000 20:23:14
Message: <38A36471.A8B3DD5D@taconic.net>
HF-Lab should be able to do that for you. If you are already working
with leveller, you can get the HF-Lab plugin. The relavent command is
"fill n" where n is the number of cycles (try about 50 for starters).
Abe
Date: 10 Feb 2000 22:10:38
Message: <38A37E66.39C5054E@pilot.msu.edu>
I tried that.  But it does not work very well.  I eroded the one height
field.  The other one is not eroded and not the same, the heights are
different.  So just translating down does not produce very good results.
Date: 10 Feb 2000 22:14:38
Message: <38A37F50.AAAD90D9@pilot.msu.edu>
fill n huh?  I have not bothered to read the HF-lab stuff.  I will try
that.  The lowering of one HF does not work all that well.
> Abe
