POV-Ray : Newsgroups : povray.general : spherical light math help ... Server Time
1 May 2026 01:09:15 EDT (-0400)
  spherical light math help ... (Message 1 to 10 of 10)
Subject: spherical light math help ...
Date: 7 Jan 2000 12:02:20
Message: <38761c1c@news.povray.org>
I am working on a spherical light, so far it looks something like this:
#declare STEP=0.2;
#declare M=-1;
#while (M<=1)
    #declare N=-1;
    #while (N<=1)
        #declare O=-1;
        #while (O<=1)
            #if ( (M*M+N*N+O*O) <= 1 )
                light_source
                    < M, N, O> color White/DIVISOR
        #declare O=O+STEP;
    #declare N=N+STEP;
#declare M=M+STEP;
Only problem is, I don't know what to set DIVISOR to, in order for the
overall brightness to equal that of a single light_source.  I know it has
something to do with the volume of a sphere, and the value of STEP. Does
anyone know what formula to use?
Paul Vanukoff
van### [at] primenetcom
Subject: Re: spherical light math help ...
Date: 7 Jan 2000 12:45:49
Message: <chrishuff_99-2957B8.12455907012000@news.povray.org>
In article <38761c1c@news.povray.org>, "Paul Vanukoff"
> #declare STEP=0.2;
> #declare M=-1;
> #while (M<=1)
>     #declare N=-1;
>     #while (N<=1)
>         #declare O=-1;
>         #while (O<=1)
>                 light_source
>             #end
>         #declare O=O+STEP;
>         #end
>     #declare N=N+STEP;
>     #end
> #declare M=M+STEP;
> #end
Hmm, is this a spherical area light? I had planned on making a macro for
this someday, I never got around to it. I would use a slightly different
way of doing it, though.
There is a patch in MegaPOV that does something similar(circular area
lights and reorienting area lights), and you might want to ask in
povray.advanced-users for more help, since this seems to be a math
question. I will look at this code later and see what I can do.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 7 Jan 2000 12:53:21
Message: <chrishuff_99-2D8216.12533107012000@news.povray.org>
In article <38762474@news.povray.org>, "Lance Birch"
<lan### [at] usanet> wrote:
> But what you've got there isn't spherical in the first place is it?
Not completely spherical, but the line
makes sure all of the light sources are within the sphere.
Chris Huff
Date: 7 Jan 2000 12:55:08
Message: <3876287c@news.povray.org>
I realised that shortly after posting and cancelled the message :)
Lance.
The Zone - http://come.to/the.zone
Chris Huff <chr### [at] yahoocom> wrote in message
news:chrishuff_99-2D8216.12533107012000@news.povray.org...
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 7 Jan 2000 13:22:32
Message: <chrishuff_99-F7EACC.13224207012000@news.povray.org>
I don't know how to solve that problem, other than storing all the
possible positions in an array and counting the ones inside the sphere.
So here is an alternate method:
#declare rsA = seed(7892983);
#macro SphereLight(SourceNum, Center, Rad, Color)
   #local J=0;
   #while(J<SourceNum)
      #local Pos = < rand(rsA)*2*Rad - Rad,
               rand(rsA)*2*Rad - Rad>;
      #if(vlength(Pos)<=Rad)
         light_source {Pos color Color/SourceNum translate Center}
         #local J=J+1;
The light sources are placed randomly inside the sphere, which makes any
patterns or banding less visible. Be careful, though, large numbers of
light sources can really slow things. I tested it with this little scene:
   location <-3, 5, -8>
   look_at < 0, 0, 0>
   angle 35
#declare T_Green = texture {pigment {color Green}}
SphereLight(100, < 0, 5, 0>, 1, White)
sphere {< 0, 1, 0>, 1
   texture {T_Green}
box {<-100, 0,-100>, < 100, 0, 100>
   pigment {color Gray80}
Chris Huff
Date: 7 Jan 2000 13:28:25
Message: <38763049@news.povray.org>
That's pretty cool ... a lot better than my idea ... thanks!
Paul Vanukoff
Chris Huff wrote in message ...
[... snipped ...]
Date: 7 Jan 2000 16:02:39
Message: <3876546f@news.povray.org>
Another method... if you can deal with a slight increase in parse time.  Take the code
you have and copy it so it appears twice in a
row.  Then take the first occurance and change it like this (I commented the "ADDED"
lines to show which ones they were):
#declare STEP=0.2;
#declare NumLights = 0;  // ADDED
#declare M=-1;
#while (M<=1)
    #declare N=-1;
    #while (N<=1)
        #declare O=-1;
        #while (O<=1)
            #declare NumLights  = NumLights + 1; // ADDED
            #declare O=O+STEP;
    #declare N=N+STEP;
#declare M=M+STEP;
Then you can divide by NumLights.  Just make sure STEP is the same in both sets of
loops.
-Slime
Paul Vanukoff <van### [at] primenetcom> wrote in message
news:38761c1c@news.povray.org...
> #declare STEP=0.2;
> #declare M=-1;
> #while (M<=1)
>     #declare N=-1;
>     #while (N<=1)
>         #declare O=-1;
>         #while (O<=1)
>                 light_source
>             #end
>         #declare O=O+STEP;
>         #end
>     #declare N=N+STEP;
>     #end
> #declare M=M+STEP;
> #end
> Paul Vanukoff
Date: 7 Jan 2000 16:18:01
Message: <chrishuff_99-11B8FA.16181107012000@news.povray.org>
> Take the code you have and copy it so it appears twice in a
> the "ADDED" lines to show which ones they were):
> #declare STEP=0.2;
> #declare M=-1;
> #while (M<=1)
>     #declare N=-1;
>     #while (N<=1)
>         #declare O=-1;
>         #while (O<=1)
>             #declare O=O+STEP;
>         #end
>     #declare N=N+STEP;
>     #end
> #declare M=M+STEP;
> #end
> both sets of loops.
That won't work, you have to increment NumLights only for those
positions inside the sphere:
#declare M=-1;
#while (M<=1)
    #declare N=-1;
    #while (N<=1)
        #declare O=-1;
        #while (O<=1)
            #if (vlength(<M,N,O>) <= 1 )
            #declare O=O+STEP;
        #declare N=N+STEP;
    #declare M=M+STEP;
Then you can use NumLights as the divider in the loop that places the
lights.
Chris Huff
Date: 7 Jan 2000 17:57:28
Message: <38766f58@news.povray.org>
Now why didn't I think of that .. it's so simple, it just might work! :)
Thanks!
Paul Vanukoff
>> #declare STEP=0.2;
>> #declare M=-1;
>> #while (M<=1)
>>     #declare N=-1;
>>     #while (N<=1)
>>         #declare O=-1;
>>         #while (O<=1)
>>             #declare O=O+STEP;
>>         #end
>>     #declare N=N+STEP;
>>     #end
>> #declare M=M+STEP;
>> #end
>> both sets of loops.
>#declare M=-1;
>#while (M<=1)
>    #declare N=-1;
>    #while (N<=1)
>        #declare O=-1;
>        #while (O<=1)
>            #end
>            #declare O=O+STEP;
>        #end
>        #declare N=N+STEP;
>    #end
>    #declare M=M+STEP;
>#end
>lights.
>Chris Huff
Date: 10 Jan 2000 08:55:42
Message: <3879e4de@news.povray.org>
> #declare STEP=0.2;
> #declare M=-1;
> #while (M<=1)
>     #declare N=-1;
>     #while (N<=1)
>         #declare O=-1;
>         #while (O<=1)
>                 light_source
>             #end
>         #declare O=O+STEP;
>         #end
>     #declare N=N+STEP;
>     #end
> #declare M=M+STEP;
> #end
    Might I suggest something? Firstly, the existing adaptive area-light
saves greatly on number of sources for a given quality; I believe the
circular area light implements this
too.  Secondly, the eye does not infer details of light shape well from
illumination except in unusual cases such as a pinhole camera (that's why
you cannot look *away* from a partial eclipse of the sun & see what's
happening.) And, thirdly, with this scheme the number of point lights grows
with the cube of the linear density.  Sloooooooow.   Could you use two or
three area lights,one in the xy plane, one in the yz plane, and one in the
xz plane - or a circular light "trained" via a macro to follow the camera -
to get the same effect?
    -Robert Dawson
