POV-Ray : Newsgroups : povray.general : Can I set... Server Time
21 Jul 2026 13:52:20 EDT (-0400)
  Can I set... (Message 1 to 3 of 3)
Subject: Can I set...
Date: 30 Dec 1999 16:38:09
Message: <386BD0C3.2320C859@sydcom.net>
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Some of the commands and (system) variables inside my pov file. I am trying
to do a simple method of changing a variable to vary the "Quality" figure.
I put it in a file as a #declare but it made no difference. The other thing
I want to do is direct the graphics file output to a folder I specify in
my pov file.
<p>Does this make sense? Can anyone help?
<br>--
<br>Take care,
<p>Jack
<p>Be sure to visit my website at <A
HREF="http://www.jaxsoft.com">http://www.jaxsoft.com</A>
<br> </html>
Subject: Re: Can I set...
Date: 30 Dec 1999 17:17:24
Message: <386bd9f4@news.povray.org>
If I understand you correctly, the answer is no. You can set those things in
an .ini file, but not in the .pov file.
I made up a bunch of template .ini files with some of the specifics I want
and then use them to make individualized files for the project I am working
on.
"Jack" <omr### [at] sydcomnet> wrote in message
news:386BD0C3.2320C859@sydcom.net...
to do a simple method of changing a variable to vary the "Quality" figure. I
put it in a file as a #declare but it made no difference. The other thing I
want to do is direct the graphics file output to a folder I specify in my
pov file.
Take care,
Jack
Be sure to visit my website at http://www.jaxsoft.com
Date: 30 Dec 1999 18:29:24
Message: <386bead4@news.povray.org>
Actually MegaPOV patch might be able to; not sure, since it doesn't allow
for everything that could be put into an Ini file.  However the +QR switch
(radiosity on) is valid so perhaps any other quality setting is valid also.
Someone else here would know, especially Nathan Kopp.
The keyword 'ini_option' goes into the 'global_settings' and is described in
the misc.htm file which comes with the MegaPOV distribution at:
http://www.nathan.kopp.com/patched.htm
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:386bd9f4@news.povray.org...
in
working
> on.
trying
I
I
> pov file.
> Take care,
> Jack
