POV-Ray : Newsgroups : povray.general : POV and alpha channel Server Time
16 Jan 2026 15:55:30 EST (-0500)
  POV and alpha channel (Message 1 to 10 of 11)
Subject: POV and alpha channel
Date: 9 Dec 1999 09:24:22
Message: <384FBB37.F263E00D@usit.net>
I'd like to do some compositing with images from POV-Ray using the
alpha channel in the TGA file. Unfortunately (and I can't believe
I'm the first to notice this, so I assume it's something I'm either
not understanding or doing wrong), it seems that the alpha channel
in the rendered image file is "reversed" from what it should be
(i.e. 0 instead of 255 and vice versa). I rendered a simple test
sphere, no specified background, one light, very simple. When I
call the image up, I find that there is a hole in the middle of the
image right where the sphere ought to be... but I can see the black
background with no problem.
I thought perhaps it was something about TGAs, so I converted the
file to a GIF. Same thing... a black background with a hole in the
image where the sphere should be, exactly backwards from what I
expected.
(BTW, I'm using ImageMagick and POV3.1g on a RH6 Linux system do
do all this.)
Can someone tell me what I'm doing wrong?
Subject: Re: POV and alpha channel
Date: 9 Dec 1999 10:03:45
Message: <384fc4d1@news.povray.org>
The alpha value should be 0 if the pixel is fully transparent, 255 if
fully opaque, and the values in between for partial transparency -- is
this what you're getting?
(In other words, it's the opposite of the transparency component in an
rgbt colour specification.)
Jeff Lee         shi### [at] gatenet         http://www.gate.net/~shipbrk/
Date: 9 Dec 1999 11:36:24
Message: <384FDA88.4564009F@spiritone.com>
I had the same issue. Reverse the alpha channel and it will work just
fine.
> expected.
> do all this.)
Josh English
eng### [at] spiritonecom
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen
asleep yet."
Date: 9 Dec 1999 17:23:32
Message: <oCpQOGIVlzZBcLgmBwlFsSHRKap1@4ax.com>
On Thu, 09 Dec 1999 09:22:47 -0500, Steve Martin <sma### [at] usitnet>
Nothing. POV treats alpha channels in the exact opposite manner to
what paint programs do. A POV generated image with an alpha channel
will work perfectly in POV but to use it properly in a paint program
you'll have to invert the alpha channel.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 9 Dec 1999 22:14:24
Message: <38506FB8.94BD7AD8@usit.net>
Okay. Thanks. I'm glad it wasn't me. Is inverting the alpha channel
something I can do in POV-Ray, or am I going to have to figure out
how to do that in ImageMagick?
Date: 10 Dec 1999 00:25:02
Message: <5IxQOGQxD+3xYzelszHJqrt9e89C@4ax.com>
On Thu, 09 Dec 1999 22:12:56 -0500, Steve Martin <sma### [at] usitnet>
You can do it in POV but it will be a hack. Get all your scene in one
big union and give it a black pigment. Then render the scene. You'll
get... nothing :) Well, black is black, but at least the alpha channel
will be intact. Next thing to do is put this image on a plane of
ambient 1 and make it face an orthographic camera positioned so that
the transformed image_map fits perfectly. Put a white plane of ambient
1 behind this plane and render this scene in the resolution of the
original scene. This will make all "transparent" objects white.
If what you need is exactly the opposite (I don't remember by heart...
no, please people no, ok, I'll re-read jut leave me alooooone...
OUCH!), then the union I mentioned in the beginning should be of
pigment { White } and finish { ambient 1 } , and there should be no
need of the plane behind the image (because the default background is
black anyway).
Of course, if you're uing Linux, why not use the GIMP to do this? :)
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 10 Dec 1999 07:39:31
Message: <3850F42D.4F6004B8@usit.net>
Yeah, that's pretty much a hack, all right. Guess I'll have to
get my lazy carcass in gear and learn Gimp. <grin>
Date: 10 Dec 1999 07:51:19
Message: <chrishuff_99-DF7B6E.07514310121999@news.povray.org>
Maybe an invert_alpha command would be useful. I rarely use image_maps,
though, and have never used the alpha channel.
I will have to look at the source to see how hard it would be.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 10 Dec 1999 12:50:56
Message: <38513E1F.4679D761@merlin.net.au>
> fine.
> > expected.
> > do all this.)
> Josh English
> ICQ: 1946299
> asleep yet."
I've used the alpha channel with PNG output and it worked fine.
The PNG file format allows for the alpha channel to represent
either transparency or opacity.
Cheers, PoD.
Date: 10 Dec 1999 19:57:25
Message: <3851A11F.93274C23@usit.net>
Well, how 'bout that! I rendered out to a PNG file (no other
changes), and it worked like a charm. That solves my problem!
