![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm posting this because I'm sure it is a simple trig thing and that was too
many years ago for me to remember it.
I have an object... let us assume it is a picture for simplicity....
camera -----> picture
In this scenario, the picture is perpendicular to the viewing angle of the
camera. What I want is the formula that will tell me how much to rotate the
picture to keep the picture perpendicular when I MOVE the camera.
For example, if the camera is at <0,0,0> and the picture is at <10,0,0> and
then I move the camera to <0,0,5>, how much do I need to rotate the picture
to get it back to a 90 degree angle respective to the camera? X,Z
coordinates are fine, I don't need any 3-D solutions to this problem.
Robert J Becraft
aka cas### [at] aol com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Regards,
> Robert J Becraft
The inverse tangent of (5/10): 26.565051 degrees, about the y-axis. <0,
26.565051, 0>. Unless I'm misreading the problem.
-Mark Gordon
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And the formula is??????????? The sample was for clearification... I need
the general formula that would be used to solve this problem.
>>-Mark Gordon
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There is a simple matrix tranformation you can use to orient everytthing. It
goes like this:
#declare Cam_Loc = wherever the camera is
#declare Obj_Loc = whereve the object
#macro Orient_Z(v1,v2)
#local nz = vnormalize(v2 - v1);
#local nx = vnormalize(vcross(nz,y));
#local ny = vcross(nz,nx);
matrix <nx.x,nx.y,nx.z,
ny.x,ny.y,ny.z,
nz.x,nz.y,nz.z,
v1.x,v1.y,v1.z>
box { <0,0,0> <1,1,0.01>
pigment { image map details go here *** }
transalate <-0.5,-0.5,0>
scale appropriately
Orient_Z(Obj_Loc, Cam_Loc)
This version of the orient macro assumes something is designed along the Z
axis.
As far as the trig goes, it can be messy. Assume the camera stays at <0,0,0>
and the painting is at <10,0,0>, and limit it's movement only by translating it
along z, such as your example, then you have to remember that rotating an
object not located at the origin will move it as well as rotating it. Here I
will assume the painting setup as above, without the Orient_Z macro.
you have point p at <x,0,z> which is the final position of the painting.
rotate arctan(p.z,p.x)*y
translate p
Okay, simple, but if you want to move the painting in 3d space, use the Orient
macro, it's safer
> Regards,
> Robert J Becraft
Josh English
eng### [at] spiritone com
ICQ: 1946299
"Stress is when you wake up screaming and realize you haven't fallen asleep
yet."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I had a simular problem with eyes and looking
at one spot. this is a solution.
given P1,P2 are location vectors
angle functions return radian values
degrees() accepts radians and returns degrees
Use the function vnormalize(P2-P1) to return a vector of
unit lingth that points from P1 to P2.
Use -degrees(asin(z componant)) and degrees(asin(y componant))
to return the amount of degrees that the object must be
rotated while at P2 to face P1.
This assumes that the object is "facing" in the -x direction.
I have used a macro to keep the intent of the code clear.
I hope this helps. It gave me good results in making a
mannequin look at the camera.
#macro v_lookat(P1,P2)
#local Norm=(vnormalize(P2-P1));
<0,-degrees(asin(Norm.z)),degrees(asin(Norm.y))>
#declare CameraPosition <-35,67,-16>;
#declare PicturePosition <2,-1,3>;
object {
rotate v_lookat( CameraPosition , PicturePosition )
translate PicturePosition
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The matrix page helps here also:
http://users.erols.com/vansickl/matrix.htm
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Robert,
I used this kind of stuff few months ago to place eyes looking at the
viewer
(the camera location).
Just let let few seconds to find this in my hard drive. hem... hem....
hem....
ok, I get it !
Instead of a copy/paste piece of scene, I give you a small complete one,
totally FREE of charges. Lucky guy !! It's in the p.b.s-f group.
And for the same price, I gave you my prism eyes.
It was something I was working on for the Horror round, but I didn't
managed to finish the scene before the end of the competition.
You can change camera position and camera look_at to be sure that the
eyes follow the camera.
A+
Rico.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
was too
the
rotate the
<10,0,0> and
If you are looking for a more general purpose solution to this problem,
you could try a custom lens effect using the Lens Effects include file
(http://www.geocities.com/~ccolefax). This will allow you to position
an object (such as an image-mapped disc/polygon) perpendicular to the
camera, given the camera location and look_at, and the object position.
Further to that, you can create the effect as part of the scene (so it
is centred where you declare the object to be) or as an overlay (so it
appears to be centred where you declare the object to be, but actually
overlays the rest of the scene). And you don't have to worry about any
of the math!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I tried to use this approach but unfortunately I need a more generalized
solution.
All I need.. is the angle (direction) between 2 vector locations..
but I need to ensure that it works in any and all quadrants.
My objects can always be rotated at origin prior to any move.
Surely there must be an easy solution sitting somewhere.
mr.art <mr.### [at] gci net> wrote in message news:38469CB9.D481A3FA@gci.net...
> #end
> object {
> Picture
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
generalized
> solution.
If the vehicle is travelling on flat ground, and only rotating around
the y-axis, then the solution should indeed be fairly simple. Let's say
you've declared the vehicle pointing towards the +z direction, so its
base (wheels or whatever) touches y=0 and it is centered at x=0 and z=0.
Given any direction we can calculate the rotation using the arc-tangent:
object {Vehicle
rotate y*degrees(atan2(Direction.x, Direction.z))
translate Location}
The beauty of the atan2 function is that it works in all four quadrants,
and also works for the cases +z (0 degrees), +x (90 degrees), -z (180
degrees), and -x (-90 degrees). However, it will not work when the
Direction vector is <0, 0, 0>, so if the vehicle is stationery during
the animation you will still need to supply a Direction.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
