POV-Ray : Newsgroups : povray.general : Imagemap MapType Server Time
27 May 2026 17:59:49 EDT (-0400)
  Imagemap MapType (Message 1 to 10 of 15)
Subject: Imagemap MapType
Date: 17 Nov 1999 18:27:02
Message: <383339c6@news.povray.org>
Hello,
I'm trying to apply an imagemap to a box but there isn't an box maptype
avaible.
If I use planar maptype the other faces aren't mapped correctly.
How can I do this?
How can I suggest to the PovTeam a new feature?
Thanks
Sergio
Subject: Re: Imagemap MapType
Date: 17 Nov 1999 19:04:33
Message: <mUEzOF3mImSBF9jIKGp4hPfR34+N@4ax.com>
On Wed, 17 Nov 1999 23:20:06 -0000, "Sergio" <ine### [at] esotericapt> wrote:
>avaible.
  Probably some form of uv_mapping is what you are looking for. Nathan
Kopp's UVPov v6.1 (unofficial POV-Ray for Windows, source provided) has such
mapping for some objects but I don't think the box was among them. Check it
out for yourself at:
http://www.nathan.kopp.com/patched.htm
  This a fairly popular request. The problem is finding the person to
*write* the new feature :)
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 17 Nov 1999 19:15:34
Message: <383344E6.AE6A62F5@pacbell.net>
Sergio wrote:
> Hello,
> avaible.
> How can I do this?
Easy :) Make a box out of 6 flat boxes or an intersection of 6 planes.
This will allow you to map an image to each face individualy. It is the
only method that I know of.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 17 Nov 1999 19:25:34
Message: <383346a0.1203823@news.povray.org>
On Wed, 17 Nov 1999 16:14:30 -0800, Ken <tyl### [at] pacbellnet> wrote:
>Sergio wrote:
>> Hello,
>> avaible.
>> How can I do this?
Chris Colefax posted a gargantuan texture to do this to CGRR sometime
in the past year.  Someone has it archived on a website somewhere, or
I might have copied it to this server somewhere.  I wish I remembered
better.  Peter?
Date: 17 Nov 1999 19:46:48
Message: <38334C4E.2514557E@enst.fr>
> better.  Peter?
	You should be able to do it with a composition of to radial texture
maps...
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 17 Nov 1999 19:54:29
Message: <38334E06.921E3DA4@pacbell.net>
> better.  Peter?
I just sent him an email asking him if he still has the source for that.
Wait............
Date: 17 Nov 1999 22:02:58
Message: <38336c62@news.povray.org>
> better.  Peter?
that.
> Wait............
But not for too long (despite appearances I generally check all the
relevant news servers on a daily basis).  A direct quote from the
message posted to c.g.g.r:
Solution 1, as previously recommended:
   #declare Face = plane {-z, .5
      pigment {image_map {tga "Image"} translate -.5}}
   #declare Box = intersection {
      object {Face} object {Face rotate y * 90}
      object {Face rotate y * 180} object {Face rotate y * 270}
      object {Face rotate x * 90} object {Face rotate x * -90}}
The box is created from <-.5, -.5, -.5> to <.5, .5, .5>, which you can
transform as you like.  You can also use the Box object in CSG
operations, but the texture itself is not actually solid, which brings
us to solution 2:
#macro cube_map (base_pigment)
   #local I = pigment {base_pigment translate <-.5, -.5, -.5>}
   #local I2 = pigment {radial pigment_map {
      [.125 I rotate <90, 0, -90>]
      [.125 I rotate <0, 0, -90>] [.375 I rotate <0, 0, -90>]
      [.375 I rotate <-90, 0, -90>] [.625 I rotate <-90, 0, -90>]
      [.625 I rotate <0, 180, -90>] [.875 I rotate <0, 180, -90>]
      [.875 I rotate <90, 0, -90>]}
      rotate z * 90}
   #local I3 = pigment {radial pigment_map {
      [.125 I rotate <-90, 0, 90>] [.125 I] [.375 I]
      [.375 I rotate <-90, 0, 270>] [.625 I rotate <-90, 0, 270>]
      [.625 I rotate <180, 0, 0>] [.875 I rotate <180, 0, 0>]
      [.875 I rotate <-90, 0, 90>]}
      rotate x * 90}
      [.125 I3] [.125 I2] [.375 I2] [.375 I3]
      [.625 I3] [.625 I2] [.875 I2] [.875 I3]}
Save this macro to a file, and then include that file into your scene.
Now you can create a genuinely solid texture with the image arranged in
a cube, eg:
   box {-.5, .5
      pigment {cube_map (pigment {image_map {tga "Image"}} ) }
      scale <1, 2, 3> rotate <15, -35, 0> translate <-5, 10, 3>}
The advantage of this method is that you're not restricted to boxes -
you can apply the pigment to any object (including CSG differences and
intersections), and you can actually use *any* pigment in place of the
image_map.  The pigment is basically like six pyramids with their apexes
(or apices, if you prefer) stuck together to form the cube.
The image covers the base of each pyramid, but note that the joins
between the diagonal sides of each pyramid will be visible if you apply
the pigment to a non-cube surface - so we turn to Carl Perkins'
suggestion, ie. to use a warped image with spherical mapping.  Start by
creating a scene containing only a cube created using either of the
above methods, and given a finish {ambient 1} (eg. add the finish to the
Face plane above, and create a scene with object {Box}).  Now, add this
camera to the scene:
   camera {panoramic angle 180 right x up y rotate y * clock * 180}
and render a two frame animation at a square resolution (eg.
Final_Frame=2 Width=300 Height=300).  Join the resulting two frames
together, side by side (using DTA, or another image manipulation
program), and you will have a suitable, spherically-warped image, eg:
   box {-1, 1
      pigment {image_map {tga "Joined" map_type 1 interpolate 2}}
      rotate <45, -45, 0>}
Date: 17 Nov 1999 22:08:06
Message: <FGwzOPgm66ziikQc1K1+3BAnQjk7@4ax.com>
  Yeah, that's how I've done it in the past, Ken. Works well. I mapped
different image maps of a girl who worked as a model for a photographer in
Hawaii (he granted permission, as long as it was uploaded to CompuServe,
only). Rotated the box and placed a reflective sphere in the background so
one could see the backside of the box. Fun to look at but it's all gone when
my Pentium 200 died :(
Date: 18 Nov 1999 00:52:58
Message: <383393FA.E0109DEC@pacbell.net>
  One of my favorite Christmas gifts to family and friends is a rotating
picture cube of family members and pets. It's a big hit and very personal.
Date: 18 Nov 1999 04:17:32
Message: <3833C3EC.6670945D@pacbell.net>
Chris Colefax wrote:
> > Wait............
...and we appreciate your continued support.
Thanks Chris,
