POV-Ray : Newsgroups : povray.general : Why doesn't this work (some #declare stuff) Server Time
27 Apr 2026 01:22:48 EDT (-0400)
  Why doesn't this work (some #declare stuff) (Message 1 to 6 of 6)
Subject: Why doesn't this work (some #declare stuff)
Date: 30 Oct 1999 11:57:38
Message: <381b1572@news.povray.org>
I can't get thit to work... anyone know why??
I get an error : RValue to declare expected but cubic_spline found instead.
But why does it pass linear_spline? This works if you #declare font names..
why not this? I'm trying to make some system for making test renderings
easy. I'm not very good at povray, so I would appreciate a easy to
understand answer, not that I usually don't get it.. Thanks!
Btw.. anyone got  a nice plastic finish? Like the one on computers.
#declare Test = 0;
#if (Test)
        #declare screen_text = texture {pigment {White}}
        #declare Spline = linear_spline;
#else
        #declare screen_text = texture {pigment {White} finish {diffuse 0.3
reflection 0.3 specular 0.7}
        #declare Spline = cubic_spline;
camera{
location <20,60,-50>
look_at <20,22,0>
light_source{<20,50,-100> White}
box{<0,6,0>,<40,44,6> texture{screen_text}}
prism{Spline 6,44,6 <0,0>,<0,0>,<40,0>,<20,-1.5>,<0,0>,<0,0> texture
{screen_text}}
Subject: Re: Why doesn't this work (some #declare stuff)
Date: 30 Oct 1999 12:16:03
Message: <381b19c3@news.povray.org>
Missing curly brace, perhaps?
Replace the following declaration:
with this one:
reflection 0.3 specular 0.7}   }
(Note the last curly brace to close the texture block.)
rc
Date: 30 Oct 1999 12:37:37
Message: <381B1F66.422D3F9F@yahoo.com>
It passes by the line that declares linear_spline because of the #if
statement.
#declare Test = 0;//0 is the same as false
#if (Test)
        //because Test is 0, all this stuff is ignored and the #else
block is used instead.
        //You can't declare a variable as linear_spline! But this block
is ignored, so it doesn't matter.
#else
0.3
        //You can't declare a variable as cubic_spline!
Subject: SV: Why doesn't this work (some #declare stuff)
Date: 30 Oct 1999 13:53:09
Message: <381b3085@news.povray.org>
I have to write it like this then... makes it a bit more difficult, but
thanks a lot..
well...  I use an include file, so I just added the finish in the mail
manually without test rendering.. that's why the last } weren't there :)
#declare Test = 1;
#if (Test)
#else
        #declare screen_text = texture {Plastic_White}
camera{
look_at <20,22,0>
#if (Test)
prism{linear_spline 6,44,4 <0,0>,<40,0>,<20,-1.5>,<0,0> texture
{screen_text}}
#else
prism{cubic_spline 6,44,6 <0,0>,<0,0>,<40,0>,<20,-1.5>,<0,0>,<0,0> texture
{screen_text}}
Subject: Re: SV: Why doesn't this work (some #declare stuff)
Date: 30 Oct 1999 14:19:43
Message: <381B3754.B974ACCE@yahoo.com>
Why not something like this instead of duplicating all that prism code?:
prism{
    #if (Test)    linear_spline #else    cubic_spline #end
    texture {screen_text}
Subject: SV: SV: Why doesn't this work (some #declare stuff)
Date: 31 Oct 1999 08:58:24
Message: <381c4b00@news.povray.org>
won't work... I think spline have to be at the start of prism..
Chris Huff <chr### [at] yahoocom> wrote in message
news:381B3754.B974ACCE@yahoo.com...
> prism{
