POV-Ray : Newsgroups : povray.general : torus "bug"? Server Time
21 Jul 2026 23:32:34 EDT (-0400)
  torus "bug"? (Message 1 to 10 of 16)
Subject: torus "bug"?
Date: 16 Oct 1999 21:12:35
Message: <380922BD.C98E15DF@isd.net>
If you have a torus with minor>major, you get a big ugly hole chopped
out of the center. Shouldn't it just be like a torus without a hole,
like a red blood cell sort of thing?
Subject: Re: torus "bug"?
Date: 17 Oct 1999 03:38:01
Message: <38097cd9@news.povray.org>
It should.
A torus created by a "quartic"-statement renders ok.
Since "torus" uses the same polynomial root solver, the problem
probably lies in the intersection calculation of the bounding volume.
(I had no time to take a peek at the source, but the docs say a cylindrical
ring is used; maybe the author of the code forgot to make provisions for
the case of minor > major.)
Gerald
Date: 17 Oct 1999 06:05:58
Message: <38099f86@news.povray.org>
I have not tested it, but I would bet that the problem is in the bounding.
  If I remember correctly, a torus is bounded with the difference of a
cylinder and a smaller cylinder. If the minor radius of the torus is greater
than the major radius, the inner cylinder will have a negative radius (instead
of havin a radius 0 as it should).
Date: 17 Oct 1999 07:56:29
Message: <rrgJOH+hG7x+O4Gs5wAoM5U2xvX0@4ax.com>
On 17 Oct 1999 06:05:58 -0400, Nieminen Juha
A torus is bounded by two open cylinders and two capping discs with
holes. If minor > major then the hole of a capping discs would be
greater than its radius. Also, the inner bounding cylinder would
become outer and vice versa, which might pose some "insidedness"
problems.
Peter Popov
ICQ: 15002700
Date: 17 Oct 1999 14:04:19
Message: <380A1201.4566173C@merlin.net.au>
I have seen this and as others have suggested, it is a bounding problem.
Simply bound it with sphere{ 0,major+minor }
Cheers, PoD.
Date: 17 Oct 1999 21:29:48
Message: <380a780c@news.povray.org>
In article <380922BD.C98E15DF@isd.net> , Larry Fontaine <lfo### [at] isdnet>
Yes, I can reproduce your problem, here is a sample scene. It should show a
strange dark spot near the center of the torus. (Crossposted to POV-Ray
bugreports.)
#version 3.1;
camera
  location  <0.0, 5.5, -0.5>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.0,  0.0>
light_source
  <-30, 30, -30>
  color red 1.0  green 1.0  blue 1.0
plane { y, -1 pigment {color rgb <0.7,0.5,0.3>}}
torus
  0.8,
  1.0
  texture {pigment {radial frequency 8} finish{specular 1}}
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 17 Oct 1999 21:33:58
Message: <380A78B9.C9B4BE1B@pacbell.net>
> bugreports.)
Is it really a bug when you try to make a torus something other than a torus ?
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 17 Oct 1999 22:27:35
Message: <380A85C8.442C8AE9@isd.net>
How is that not a torus? A torus is defined simply as the solid formed by rotating
a circle around a circular path which is perpindicular to the plane of the circle.
> > bugreports.)
Date: 17 Oct 1999 22:37:44
Message: <380A87A8.5A11B57E@pacbell.net>
Tell me oh bright young one what advantage if any is there in trying
to make the lesser radius larger than the greater radius ?
What do you hope to achieve anyway ?
Why are you bucking the system ?
Where is my other sock ?
Got milk ?
Date: 17 Oct 1999 22:43:26
Message: <380a894e@news.povray.org>
> Got milk ?
Or, as the slogan ran when translated (into Spanish I think): "Are you
lactating?"
