POV-Ray : Newsgroups : povray.general : Non-rolling rotations Server Time
11 Aug 2024 01:22:08 EDT (-0400)
  Non-rolling rotations (Message 1 to 10 of 10)
Subject: Non-rolling rotations
Date: 12 Oct 1999 10:47:01
Message: <38034951.5372EA25@my-dejanews.com>
I have noticed that when I use the standard reorient macros, my actors
roll along their axis of movement as they travel in a complete circle.
For example,
1) I develop and algorithm that changes the velocity of an actor so that
it moves in a circle.
2) I then use the calculated velocity to reorient an object such as
reorient (x, new_velocity).
3) I find that as I watch the actor complete a full circle, it has also
rotated about its axis of travel. (In other words, the guy inside the
craft had better be wearing a seat belt!)  Or, if I use this macro on
the camera, the ground spins as one travels around in the circle.
Is there a way to make a change or two to the reorient macro so that
this does not occur?
If  yall don't understand what I'm talking about, I can post a small
animation with the phenomenon...
Subject: Re: Non-rolling rotations
Date: 12 Oct 1999 11:40:01
Message: <3803567E.4817F34B@xs4all.nl>
> For example,
I don't know if I understand it correctly (probably not), but wouldn't it be
possible to do a negative rotation at 0 before anything else?
Remco
Date: 12 Oct 1999 13:55:10
Message: <380375fe@news.povray.org>
Perhaps translate<Radius*cos(radians(Angle)),0,Radius*sin(radians(Angle))>
would do it.
Date: 12 Oct 1999 15:37:52
Message: <38038D7B.8636A6D0@my-dejanews.com>
The rub comes in determining the angle.  I have vectors that can be pointing in
any which way.  I am not making a merry go round, but having particles
(spacecraft, birds)  interact with hundreds of other particles via forces which
are in 3d.  I want the "orientation" to be correct but with minimum or no
"roll".
A fish or bird in a swarming school might "point" its nose in any direction, but
I'm sure that it maximizes the amount of time its feet are below its body:
minimum roll.  The plain ol' reorient macro gives a roll as one reorients around
a circle.  My hunch is that I could just change a sign or two in one of the
matrices and be all right.
> would do it.
Date: 12 Oct 1999 16:15:36
Message: <380396D9.CFE93D1A@enst.fr>
> "roll".
	Provided you stay in a x-z plane, and provided velocity is normalized,
you can replace your call to reorient by:
matrix <velocity.x, 0, -velocity.y,
            0,      1,       0,
        velocity.y, 0,  velocity.x,
            0,      0,       0>
	If you don't stay in the x-z plane, there is no real way to do it, you
can still try this if you don't go on too steep slopes:
#local u = vnormalize (<v.x, 0, v.z>);
matrix <v.x, v.y*u.z-v.z*u.y, u.x,
        v.y, v.z*u.x-v.x*u.z, u.y,
        v.z, v.x*u.y-v.y*u.x, u.z,
         0,         0,         0>
	(There might be a sign problem in the middle column wich would cause a
"mirror effect", and i might have mixed lines and columns wich would
cause very strange behavior...)
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 12 Oct 1999 16:41:29
Message: <38039cf9@news.povray.org>
In article <3803567E.4817F34B@xs4all.nl> , Remco de Korte
I understand his question the same way, it should work. Of course you need
to make sure you have the correct "center" to rotate in place if the object
is a bit more complex.
     Thorsten
e-mail: tho### [at] trfde
Date: 12 Oct 1999 18:15:02
Message: <3803B69E.FBD867C3@erols.com>
> pointing in any which way.  I am not making a merry go round, but
> having particles (spacecraft, birds)  interact with hundreds of other
> particles via forces which are in 3d.  I want the "orientation" to be
> correct but with minimum or no "roll".
> direction, but I'm sure that it maximizes the amount of time its feet
> are below its body: minimum roll.  The plain ol' reorient macro gives
> a roll as one reorients around a circle.  My hunch is that I could
Now that you have stated your problem with more precision, I can help.
As a rule, I design objects so that x is right, y is up, and z is
forward, and what I consider to be the "center" is at the origin.
If I want to have it face a given direction, with its top as close to
up as possible, and located at a given place, I do the following:
// sample code
// assumes that Direction= the direction the object needs to face
//              Sky = the direction that's up in your world
//              Location = where it needs to go
#local vZ=vnormalize(Direction);
#local vX=vnormalize(vcross(Sky,vZ));
#local vY=vnormalize(vcross(vZ,vX));
object { MyObject Matrix(vX,vY,vZ,Location) }
// end of sample code
Hope this helps,
John
ICQ: 46085459
Date: 12 Oct 1999 20:03:31
Message: <3803CC11.48349ADC@pacbell.net>
> For example,
Came across a new calculator today you might be interested in:
Spin Doctor - This is a calculator that operates on 3D vectors and
rotations, making it an invaluable tool for 3D content and application
developers. A wide variety of operations are provided, from simple
vector addition, to scaling, rotation, and calculation of angles
and lengths.
http://www.vapourtech.com/news.html
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 14 Oct 1999 21:24:46
Message: <3806825e@news.povray.org>
Wait. You've suddenly put in a matrix only defined by "Matrix."  Is this a
capital M??
> // sample code
> Hope this helps,
> John
> ICQ: 46085459
Date: 14 Oct 1999 23:17:22
Message: <3806A07E.698A449C@erols.com>
> > // sample code
> this a capital M??
I assumed you were using my macros file (which contains the Reorient
macro); it also has a Matrix() macro, which makes it easier to build
a matrix transform out of a bunch of vectors.
Note that there are round brackets in the statment instead of angle
brackets; it's a macro call.
ICQ: 46085459
