![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It seems angle has no effect with panoramic projection (at least ver 3.1g and
Superpatch 3.1e codebase).
Is my observation correct? Is it a bug?
Example code:
camera{panoramic location <0,1,-6> angle 300 look_at 0}
light_source{<10,10,-20> color 1}
box{-1,1 pigment{rgb 1}}
box{-1,1 pigment{rgb 1} translate -x*4}
box{-1,1 pigment{rgb 1} translate x*4}
plane{y,-1 pigment{rgb .7}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Example code:
Pov docs say:
Panoramic projection: This projection is called "cylindrical equirectangular
projection". It overcomes the degeneration problem of the perspective
projection if the viewing angle approaches 180 degrees. It uses a type
of cylindrical projection to be able to use viewing angles larger than
180 degrees with a tolerable lateral-stretching distortion. The angle
keyword is used to determine the viewing angle.
I say:
I can see no difference when a different angle is specified.
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The code appears to fix the angle at 180 degrees wide and 90 degrees high,
ignoring the angle. How it's supposed to work, I don't know.
Have you tried ultra_wide_angle?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Pov docs say:
equirectangular projection". It overcomes the degeneration problem
of the perspective projection if the viewing angle approaches 180
degrees. It uses a type of cylindrical projection to be able to use
viewing angles larger than 180 degrees with a tolerable lateral-
stretching distortion. The angle keyword is used to determine the
viewing angle.
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 16 Sep 1999 14:21:50 -0700, Ken wrote:
>Pov docs say:
>viewing angle.
Yes, I know what the docs say. But what do they mean? :) Which
viewing angle is one setting? what does it mean by "a type" of
cylindrical projection?
I suspect that the code just forgets to multiply x0 and y0 by
angle/180, but I'm not 100% sure of that.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sorry Ron - my twisted sense of humor again.
Rearrange the camera statement thusly and it works as advertized
- up to a point:
Before > camera{panoramic location <0,.1,-6> angle 160 look_at 0 }
Now ---> camera{location <0,.1,-6> angle 160 look_at 0 panoramic }
Only problem with this change is that when you specify an angle larger
than 180 an error is returned warning you to specify an angle of less
than 180 which seems to be in conflict with what the docs say.
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, and neither will really do, due to the distortion of straight lines
at large angles. OTOH, the standard camera gives distorted
perspective...
Anyway, it was just an observation.
Margus
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Angle and panoramic projection
Date: 18 Sep 1999 18:25:49
Message: <37e4116d@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> >Pov docs say:
<snip...>
Perhaps this has been a misunderstanding between the person who wrote
the doc and the one who wrote the code?
The code seems to have been set up for a fixed horizontal angle of
180 degrees from the onset (watch how x0 is initialized from 0.0 to 1.0
instead of -0.5 to 0.5 as in, i.e., the cylindrical camera #1;
so the horizontal angle is measured from FCR, the right vector,
not relative to FCD, the direction vector; to get a variable horizontal
angle symmetric to FCD one would have to change this, too).
And the type of projection?
At the end of the panoramic routine FCD is multiplied by sin(x0),
FCR by cos(x0), FCU by tan(y0).
We can get rid of the tangens by scaling the vector by cos(y0),
getting
FCD*sin(x0)*cos(y0),
FCR*cos(x0)*cos(y0),
FCU*sin(y0),
which is, keeping in mind from where the horizontal angle is starting
(and if I'm not entirely in error about all this), a spherical projection.
Gerald
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
