POV-Ray : Newsgroups : povray.general : lighting help - room edges, area lights, shadows Server Time
27 Mar 2026 20:04:35 EDT (-0400)
  lighting help - room edges, area lights, shadows (Message 1 to 10 of 21)
Subject: lighting help - room edges, area lights, shadows
Date: 31 Aug 1999 22:23:42
Message: <37cc8e2e@news.povray.org>
I'm rendering a artist's studio that has sunlight coming in from the glass
roof.  Leaving that as the only light source and cranking up the ambiant on
the contents of the room doesn't look real at all.
Putting a fill light off to one side makes shapes look better (not "flat")
but adds shadows that are wrong.
Putting a large area light to one side looks great, for the major elements
of the scene.  Objects don't cast distinct shadows from this light source
but do show the vague darkening on the floor and close walls that we see in
a real room full of ambient light.  The =illumination= is still a point, not
a large surface, but it looks fine in this case.
However, I'm still getting stray shadows.  I got a sharp shadow from a small
object onto a nearby flat surface, which I presumed was because the
"adaptive" fails when the object is smaller than the light.  Hmm, on second
thought that's not right at all, as this would make =no= shadow (all four
corners of the light are unblocked when the object is in the middle), not a
sharp shadow with no prenumbra.
I tried turning off adaptive, and I still get a sharp shadow, even though
there are 25 sublights.  I'm trying a much larger number of sublights now,
but it's taking a long time to render.  If that shows no change, I don't
understand what's happening.
Anyway, I found that the "darkening" effect does a great deal toward making
a room look real.  If this isn't the best way to acheive that in an ambient
light situation, what is?  Would radiosity be the answer here, or does it
not help with this effect?
--John
Subject: Re: lighting help - room edges, area lights, shadows
Date: 31 Aug 1999 22:40:52
Message: <37cc9234@news.povray.org>
I've never encountered what you mention is wrong, and it sounds
peculiar. Did you use more than 'adaptive 1'?  I'm sure you must be
using 'jitter' in that too, aren't you? But what it almost sounds like
is a 'area_light' whose plane is aligned with the small object
somehow.
John M. Dlugosz <joh### [at] dlugoszcom> wrote in message
news:37cc8e2e@news.povray.org...
glass
ambiant on
"flat")
elements
source
see in
point, not
a small
second
four
middle), not a
though
sublights now,
don't
making
ambient
does it
> --John
Date: 31 Aug 1999 23:36:47
Message: <37cc9f4f@news.povray.org>
Bob Hughes <inv### [at] aolcom> wrote in message
news:37cc9234@news.povray.org...
> somehow.
It turns out that the shadow in question is correct, not generated by this
area light.  When I tested the image without the light to see if that shadow
went away, I must have used the wrong options, as the shadow went away <g>.
I'm still interested in general ideas for the "room edge" effect, or the
transition from ambiant to directional light.  I think my idea is OK for
some scenes, but because the illumination isn't an area (it only affects the
shadows) it can cause unwanted highlights too.
--John
Date: 1 Sep 1999 00:57:17
Message: <37ccb22d@news.povray.org>
John M. Dlugosz wrote in message <37cc9f4f@news.povray.org>...
>> somehow.
shadow
the
Try using radiosity -- it has a much greater effect in this situation than
you'd expect.
Mark
Date: 1 Sep 1999 04:15:37
Message: <37cce0a9@news.povray.org>
John M. Dlugosz <joh### [at] dlugoszcom> wrote:
: I'm rendering a artist's studio that has sunlight coming in from the glass
: roof.  Leaving that as the only light source and cranking up the ambiant on
: the contents of the room doesn't look real at all.
  If you want real interreflection of light, you need to use radiosity.
  See http://iki.fi/warp/pics/Radiosity_test2/
Date: 1 Sep 1999 20:31:13
Message: <37cdc551@news.povray.org>
Mark Wagner <mar### [at] gtenet> wrote in message
news:37ccb22d@news.povray.org...
> you'd expect.
I did try it, briefly.  I'm sure I could twiddle the parameters a LOT, but
off hand I saw that it didn't illuminate metal the way I wanted.  When
backlit by the key light, it looked just like a high ambiant -- no curves or
shape visible.
Physically, the other end of the room is a light source, and lambert shading
applies.  And in the case of metal, more spectral highlights are noticable
as well.  Turning up ambiant light levels didn't give the objects any
=shape=, and my try at using radiosity was no different.  Would adjusting
the parameters help with that specific effect?
Also, I may be on the "painting" rather than "photo" side of things, making
it look like the way I see it in my mind, which is not necessarily the way a
camera sees it.  So I need some kind of "modeling light" in localized areas,
as well as the room-edge effect.
More than once I've wished that it was possible to declare that specific
light sources interact only with specific objects.
--John
Date: 1 Sep 1999 22:03:34
Message: <37CDDB35.26A5@unforgettable.com>
> > you'd expect.
> shape visible.
Some 3D effects look best when animated (though you wouldn't necessarily
think so offhand); your brain uses the movement to see how an object's
appearance reacts to the objects around it. Metal and glass are probably
the best examples of this, as movement helps you perceive reflection and
refraction. (The ability to see different sides of an object, or to
judge its distance relative to other objects, also require movement, but
are based on perspective rather than interactivity.)
Of course, you don't sound like you're planning to animate this.
The next thing, then, would be to take a careful look at exactly what
you're illuminating, and how. With some thought and tweaking, you can
probably get it to look how you want. (I can't offer any more specific
suggestions, since I have almost no idea what the scene's supposed to
look like or what's in it.. I must have missed the first post.)
Ambient lighting (effectively) hits an object from every angle, so no,
obviously it wouldn't produce shadows that would help define the shape
of the object. In fact, it would do the opposite, by fading or
eliminating those shadows.
I don't think you can do this.. but in some cases, a carefully-placed
spotlight will do the trick, similar to the way that photographers use
reflectors to subtly illuminate a model's face (if you've seen an
outdoor photo shoot, you know what I'm getting at).
-Xplo
Date: 1 Sep 1999 23:38:09
Message: <37CDF0EC.8CEA2118@gci.net>
<snip>
> --John
If you don't mind using a patch, the SuperPatch will allow light sources that
only interact with specific objects. It might be worth a try.
Mr.Art
Date: 2 Sep 1999 16:58:53
Message: <37cee50d@news.povray.org>
Xplo Eristotle <inq### [at] unforgettablecom> wrote in message
news:37C### [at] unforgettablecom...
That's basically what my 1m-square area "fill light" off-stage is doing to
the main figure, in addition to providing edge-effect radiosity-like
shadows.
See http://www.dlugosz.com/POV/dryad_dreams.html for my notes.
--John
Date: 2 Sep 1999 17:09:17
Message: <37cee77d@news.povray.org>
Am am indeed using the SuperPatch!  Thanks for the tip.
... reading txt file ...
So, are the lights nominated by the light_group for a specific object the
only lights to contribute to the illumination of that object?
I suppose I can make a modeling light by excluding it from every other
object (looks rather intrusive, since I can't change the meaning of "all"
... maybe can change the defaults) and also making it have no_shadow for
that object.
I'll have to experiment with that feature, or find a better
description/tutorial somewhere.  Any pointers?
--John
Mr. Art <mr.### [at] gcinet> wrote in message news:37CDF0EC.8CEA2118@gci.net...
> <snip>
> > --John
that
> Mr.Art
