POV-Ray : Newsgroups : povray.general : Stone and Brick on non-flat surfaces Server Time
28 Mar 2026 13:59:02 EDT (-0400)
  Stone and Brick on non-flat surfaces (Message 1 to 10 of 19)
Subject: Stone and Brick on non-flat surfaces
Date: 11 Aug 1999 03:26:50
Message: <37b125ba@news.povray.org>
I've got two projects (just for starters) that would use stone or brick on
non-flat surfaces...
I was thinking a bitmap wrapped around a cylinder should work (with a little
bump mapping) but both projects I have in mind are conical rather than
cylindrical.
On the slanted surface of a cone the image should get stretched or squished
right?
The current project would be painted brick (if I don't just go with a stucco
surface), but the other project would be stone. I've seen a tutorial on the
web for creating good looking stone textures, but I'm not sure how they would
work for a slanted surface.
Along the same lines I also have a cone shaped roof that I would like to tile,
but I may be changing the cone roof to a dome of glass, so that might not be
an issue (but the other project it will be, so I still would like to know how
to do that also).
Any help in pointing me in the right direction would be great....
Thanks in advance.
PHIL
-----[ to reply, the domain name is "concentric.net" ]-----
Spelling mistakes brought to you courtesy of the
Allentown Public School System.
Subject: Re: Stone and Brick on non-flat surfaces
Date: 11 Aug 1999 06:45:17
Message: <37B1545F.EE910B4F@compuserve.com>
Probably an image map with the bricks at the top larger in width than
the ones at the bottom would be the best idea. There is no way to escape
the distortion effect, other than to distort the image first so that it
looks right.
Date: 11 Aug 1999 07:28:40
Message: <37B14FB0.69812049@panama.phoenix.net>
This type of problem has been brought up plenty of times. I think it is time to
add conical mapping, just like we have spherical, cylindrical, and boxed. Can this
be done?
Anthony L. Bennett
http://welcome.to/TonyB
Non nova, sed nove.
Date: 11 Aug 1999 15:33:02
Message: <37b1cfee@news.povray.org>
In article <37B1545F.EE910B4F@compuserve.com>, Chris Huff <Chr### [at] compuservecom>
>looks right.
I'll have to give it a try, but I'm not sure how well that'll look... maybe I
should just model each piece of stone... hmmm...
<GRIN>
PHIL
Date: 11 Aug 1999 17:22:34
Message: <37b1e99a@news.povray.org>
Here's a simple tiled roof
#macro Make_Tiles(NTiles,Height,Rad,Rot,Peak)
  #local dTheta = 360/NTiles;
  #local Pt1 = vrotate(<0,Height,Rad>,dTheta/2*y);
  #local Pt2 = <-1,1,1>*Pt1;
     union{
       #local T=0;
       #while(T<360)
           triangle{Pt1,Peak,Pt2 rotate T*y}
           cylinder{Pt1,Peak,0.05 rotate y*T}
       #declare T = T + dTheta;
    rotate y * Rot
#declare Roof = union{
Make_Tiles(16, -1, 1.325, 0, 0)
Make_Tiles(16, -2, 2.325, 360/16/2, y*-0.15)
Make_Tiles(16, -3, 3.250, 0, y*-0.35)
Make_Tiles(16, -4, 4.250, 360/16/2, y*-0.95)
Make_Tiles(16, -5, 5.30, 0, y*-1.65)
pigment{color rgb<.37,.62,.62>}
file://normal {wrinkles scale 0.25}
normal{facets  coords .75}
finish{crand 0.2 specular 0.5 }
With thanks to Dan Connelly
Hope this is of some use.
Mick
Philip Bartol <phi### [at] REMOVEMEconcentricnet> wrote in message
news:37b125ba@news.povray.org...
little
> cylindrical.
squished
> right?
stucco
the
would
tile,
be
how
> to do that also).
> Thanks in advance.
> PHIL
Date: 11 Aug 1999 19:55:57
Message: <37B20DB0.A066697A@compuserve.com>
What would this conical mapping be like? I think it would be exactly the
same as cylinderical(You can't wrap a rectangular image around a cone
without distortion.).
Date: 11 Aug 1999 20:20:31
Message: <37B21335.1F6D1D75@pacbell.net>
Hmmm... I wonder if you can sheer an image map... If I didn't have this
69 day render in process I would check it out myself.
Ken Tyler
See my 700+ Povray and 3D Rendering and Raytracing Links at:
Date: 11 Aug 1999 20:41:07
Message: <37B21846.B498F8E8@compuserve.com>
Sure, any transform can be applied to an image map-including a matrix.
Date: 11 Aug 1999 20:59:53
Message: <37B21CF0.F2E8FBD9@enter.net>
Yup, that sounds about right. Like trying to map a rectangular image
onto a sphere and wanting to avoid it getting pinched at the poles.
Cylindrical or conical mapping; Either way, it's gotta come to a
point somewhere if its on a cone.
There are two approaches to this problem, depending on the look the
poster wants... either accept that the map is going to shrink near
the top... a geometrically conical stack of bricks would have to
have each brick cut to narrow approaching the top, and get smaller
with each level anyway... or make a map of a single row of bricks
and fit this to each in a stack of cylinders which just happen to
get smaller near the top, making it more like a pseudo-cone out of
ever narrowing rings of bricks, which to my mind would look more
like what you'd be most likely to do if you were really trying to
shape bricks into such a structure.
Charles
http://www.enter.net/~cfusner
"...Then darkness took me, and I strayed out of thought and time,
 and I wandered far on roads that I will not tell..."
                              -The Two Towers, JRR Tolkien
Date: 12 Aug 1999 00:40:28
Message: <37b2503c@news.povray.org>
In article <37b1e99a@news.povray.org>, "Mick Hazelgrove"
I'll have to give it a render to see what it does, I've got an idea from
looking at the code, but....
Thanks, I'll let you know how it works out...
PHIL
