POV-Ray : Newsgroups : povray.general : How to engrave text on a ring Server Time
23 Nov 2025 21:01:53 EST (-0500)
  How to engrave text on a ring (Message 1 to 10 of 10)
Subject: How to engrave text on a ring
Date: 13 Sep 1999 13:31:27
Message: <37DD3533.933DB877@Weizmann.ac.il>
Great PoV gurus,
I am a green, yet eager PoV novice. Here's a bunch of questions:
1. How do I engrave text on the side of e.g. a torus object?
difference {
 torus { 2, 0.75
 texture { pigment { P_Gold2 } finish { F_MetalC } }
   text { ttf "timrom.ttf" "TEXT" 1, 0
      pigment { color Red }
      finish { reflection .25 specular 1 }
      translate <-1,-0.3,2.4>
 scale  < 6, 2, 4 >
 rotate  < 20, -10, 20 >
 translate  < -1.5, 0.0, -10.0 >
[Image]
In the picture I made it obvious that I can't do it right; I only
differenced the text
object from the ring but the text should first flow with the ring
curvature.
2. How do I get a laser beam, then curve it along a torus object then
get a
lens flare at one end of it ? I know, these are three questions...
3. Is there a place I can go and find all sorts of source files that
could
possible answer some/all my above basic questions?
Many many thanks,
Gitay
Gitay Kryger, Ph.D.                         Phone:  +972-8-934-3759
Dept. of Structural Biology                   Fax:  +972-8-934-4159
The Weizmann Institute          Cellular/VoiceMail:  +972-52-494725
Rehovot, 76100, ISRAEL         E-mail:  Git### [at] Weizmannacil
Download 'us-ascii' (4 KB) Download '/tmp/nsmail37dd353320f6a19.jpeg.png' (6 KB)
Preview of image '/tmp/nsmail37dd353320f6a19.jpeg.png'
Subject: Re: How to engrave text on a ring
Date: 13 Sep 1999 15:51:04
Message: <37DD5592.6334AE0F@skynet.be>
 If you don't need very deep-loking engraving, you might consider
using a bump-map mapped onto the torus, is faster and easier.
 Many ways to do it : bright cylinder, cylindrical spotlight
with media (harder)
 Well, you'd better take the cylinder option, and use a portion
of torus for the curved part of the laser.
> get a
 Look for lensflare includes files by Nathan Kopp or Chris Colefax.
> could
 Wait for Uncle Ken to jump and say "visit my links page"...
Fabien.
Date: 13 Sep 1999 15:53:43
Message: <37DD55E3.B3B42887@pacbell.net>
Fabien Mosen wrote:
> > get a
Which you can find on my links page.
> > could
> Fabien.
Follow the link below to wonderland...
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 13 Sep 1999 16:24:28
Message: <jerry-1309991324230001@cerebus.acusd.edu>
>curvature.
I have an example you might find useful at
http://www.hoboes.com/html/NetLife/POV/. It engraves text on the bottom of
a spent bullet casing.
The technique I used--doing the text a letter at a time--might not work
for you if the curvature of the ring is significant compared to the width
of the text.
I've also been experimenting with slicing up text and "curving" it in that
way. This pretty much requires a lot of patience or the max_extent keyword
of the superpatch. Something like the following should give you
   perspective
   location < 0.0, 0.0, -5 >
   look_at < 0.0, 0.0, 0.0 >
light_source {
   < -100.0, 100, -100 >
   color rgb White
background  {
   color White
//the amount of curvature is determined by the radius
//the 'quality' of the cutting is determined by the fineness.
//the smaller the fineness, the finer the cut
#declare curveradius = 1.5;
#declare fineness = .05;
#declare mytext = text  {
   ttf "timrom.ttf",
   "POV-Ray"
   0.1, 0
#declare textExtent = max_extent(mytext);
#declare textMintent = min_extent(mytext);
#declare currentstep = 0;
#declare archangle=degrees(asin((fineness/2)/curveradius))*2;
#declare currentangle = 0;
/* #declare curvedText = */ union {
   #while (currentstep < textExtent.x)
      intersection {
         object { mytext }
         box {
            <currentstep,textMintent.y,0>,
            <currentstep+fineness,textExtent.y,textExtent.z>
         translate <-(currentstep+fineness/2),0,0>
         translate <0,0,curveradius>
         rotate <0,currentangle,0>
         #declare currentangle = currentangle + archangle;
      #declare currentstep = currentstep+fineness;
   rotate <0,-currentangle/2,0>
   pigment { color Green }
Date: 13 Sep 1999 17:07:01
Message: <37DD6249.7EC46392@hotmail.com>
You could also try using individual heightfields for each letter and
differencing each letter from the torus. You could then control the
softness of the letter edges by playing with anti-alias and blur functions
when creating the heightfield images.
David
Date: 13 Sep 1999 20:44:33
Message: <jerry-1309991744330001@cx38767-a.dt1.sdca.home.com>
In <jer### [at] cerebusacusdedu>, I wrote:
>   color rgb White
That should, of course, be "color White".
Jerry
http://www.hoboes.com/jerry/
Date: 14 Sep 1999 00:39:03
Message: <37DDD139.3D8D5E7F@gci.net>
Gitay Kryger wrote:
> Great PoV gurus,
I have a SuperPatch solution for this one. See "20 Years" on 2 Aug 99 in
the ng p.b.i
If you want this code, I can post it in  p.t.s-f
Mr. Art
Date: 14 Sep 1999 13:32:45
Message: <37DE7C6A.AF9FBF8E@Totalise.co.uk>
Mmmmnn, that's given me an idea.....<wonders off in a daze>....
	Graham Redway.
The chances of anything coming from
Mars are a million to one, he said.
Gitay Kryger wrote:
> Great PoV gurus,
> difference {
>  torus { 2, 0.75
>  scale  < 6, 2, 4 >
> [Image]
> curvature.
> get a
> could
> Many many thanks,
> Gitay
Date: 23 Dec 2019 08:55:00
Message: <web.5e00c6ec29ef247fe78d13410@news.povray.org>
Someone made an engraving?
>  Graham Redway.
> Gitay Kryger wrote:
> > Great PoV gurus,
> > difference {
> >  torus { 2, 0.75
> >  scale  < 6, 2, 4 >
> > [Image]
> > curvature.
> > get a
> > could
> > Many many thanks,
> > Gitay
Date: 23 Dec 2019 13:20:01
Message: <web.5e01049a29ef247f54809c2a0@news.povray.org>
The way I did it in Pov was to create your ring at the origin. Then create a
single letter text object at the origin. Next scale the text object so that is
about the right size with respect to the ring. Translate the text object out to
intersect the ring, for engraving. Copy the text object, change the letter to
the next letter in the word and rotate it about the origin to its correct
position. Rinse and repeat until finished. (This is laborious unless you use a
mono-spaced font.) Put all the text objects in a union and difference that from
the ring.
I found it looked better and was easier when I made a mesh in blender out of a
box with the text differenced and that object deformed into a circular ring.
Then rendered it in Pov. :)
