POV-Ray : Newsgroups : povray.general : Media Smaller than Container? Server Time
1 Dec 2025 09:24:26 EST (-0500)
  Media Smaller than Container? (Message 1 to 6 of 6)
Subject: Media Smaller than Container?
Date: 23 Jul 1999 21:24:02
Message: <379914D0.1428CC0@geocities.com>
I'm fairly new to media, but the recent post "The Mummy...." has got me
thinking and interested in particle type effects. If I make sphere, I
can make the sphere hazy, the *whole* sphere hazy. That's not what I
want to do though, I don't want the media to be fully visible throughout
the entire object. I don't want the media to fill the entire container,
all the way to the edges. I would like it to be blobby....ya know?
Here's an example of what I'm trying to do.
http://www.newtek.com/products/lightwave/hv2/images/comet_440.jpg
Is this even remotely possible to achieve in PovRay? Can this be done
with 1 object and 1 media? Any advice,
code, or ridicule is welcome.
	Kyle Stamper
Subject: Re: Media Smaller than Container?
Date: 23 Jul 1999 22:45:40
Message: <37992848.CBF4D555@pacbell.net>
>         Kyle Stamper
  On June 30 1999 I posted source in povray.text.scene-file for a multiple
density pattern. Take a look at this and after the spherical pattern try
something like a bozo or granite pattern and see if this is what you are
looking for.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 24 Jul 1999 03:15:23
Message: <3799674d.2479992@204.213.191.228>
On Fri, 23 Jul 1999 21:20:16 -0400, Kyle Stamper
>	Kyle Stamper
This is possible in POV. Use a blob with threshold 0.0001 as a
container (thanks Chris :) ) and place a spherical media in each blob.
It works just fine for smoke and other pyrotechics.
Peter Popov
ICQ: 15002700
Date: 24 Jul 1999 10:28:35
Message: <3799cd93@news.povray.org>
Kyle Stamper <joe### [at] geocitiescom> wrote in message
news:379### [at] geocitiescom...
Just in case I know what you are talking about (not a good bet), are you
saying that your media goes all the way to the edges of your container, but
you only want them to go part way? So that the shape of the container is not
seen?
If so, have you tried scaling down the media? Scale should be the inverse of
your turbulence or thereabouts.
Date: 24 Jul 1999 11:40:16
Message: <3799E12D.6A3E66DA@erols.com>
If your density looks like this:
density { spherical turbulence .5
  density_map { [0 rgb .1] [1 rgb 1] }
The media will appear throughout the entire container object.  If, on the
other hand, your density looks like this:
  density_map { [.001 rgb 0] [.001 rgb .1] [1 rgb 1] }
The pattern will fade to nothing at its edges.
Hope this helps,
John
Date: 24 Jul 1999 18:51:17
Message: <379A428C.F2DEA8E1@geocities.com>
Ahh yes, thank you very much everyone, I believe I have a good idea of
what I need to do now. Thanks again.
	Kyle Stamper
>         Kyle Stamper
